Digging Trench with Pressure Washer
   / Digging Trench with Pressure Washer #1
nimblemotors
Sacramento, California
Case 530 CK Sold, Ford Ranger DIY Project
So I needed to run power cable from the utility box to the barn, and this time I made a shortish video on
doing it using a pressure washer.
I had not seen anyone make one, though lots of people asked on forums about doing it.
I think I've had a whole 10 views on this video, so maybe worth letting more people know. or not. :)
Digging a Trench with a Pressure Washer - YouTube
   / Digging Trench with Pressure Washer #2
Not to rain on your parade but no way would I bury a power wire that shallow. My well has a ground rated wire buried but it was done by the electrician and I wasn't there so I don't know how deep it is. If I were doing it I would go at least 3 feet down and put it in conduit.
   / Digging Trench with Pressure Washer #3
I have shot a hole with a pressure washer under a sidewalk to run a conduit but I've never used it to dig a trench to bury wire.
   / Digging Trench with Pressure Washer #4
A-men on that.
Anyone taking bets that wire will need to be replaced in less than 2 years?
B. John
   / Digging Trench with Pressure Washer #5
I had gophers chew through the insulation of 6 gauge aluminum wire running to pump house. Had the original installation been put in conduit, (by others), I'd be 1k richer.
   / Digging Trench with Pressure Washer #6
You might want to check codes in your state. Here power cables must be underground rated, at least 18" deep and in conduit.
   / Digging Trench with Pressure Washer #7
I've hand dug channels for UF wire to out buildings. Just a few inches. Just a few problems once where it crossed the barnyard. I reburied the portion that popped up. I once also ran UF wire across a lawn to get electricity where I wanted it. I found the wire lay flat and was covered over by the turf. I know it's there - electricity still runs, but I can't see it anymore. I run the mower over it all of the time. It holds up to rain, snow, frozen ground, tractor traffic.
Now I don't recommend this to anyone! But it has worked for me! Good thing the safety police are not doing their job via hi-resolution satellite imagery!
   / Digging Trench with Pressure Washer #8
Reminds me of the trench I dug and encountered bedrock close to the surface. Tried a 7.62 FMJ NATO round or two! That didn't work at all, but it would be more fun than the ungodly mess of using a pressure washer.
I saw a huge vaccumme truck yesterday doing excavation. My thought is always how long it takes those guys.
   / Digging Trench with Pressure Washer #9
He did dig to 18". Not sure what type of wire used or if conduit was also used. I do like the idea of how you can cross other pipes or wires with no damage.
   / Digging Trench with Pressure Washer #10
18" deep hare also, **** I used and hose with a screw type nozzle duct taped to a broom handle to run pex under our sidewalk for a lawn sprinkler 25 years ago when we lived in suburbia.
2013 Ford F150 4X4 Pickup Truck (A55788)
2013 Ford F150 4X4...
2015 CHEVROLET SILVERADO 3500HD CC (A55745)
2015 CHEVROLET...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2015 Toyota Prius (A55758)
2015 Toyota Prius...
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
