multi function inverter welders
/ multi function inverter welders
I don't know which unit of yours I would need, but I would want a machine to tig alum, steel, HF lift start, pre flow /post flow, flow meter, foot pedal/ switch on the torch, pulse (possibly flex head torch) 220/110 capable, and be able to weld 6010/6011 or at the least 6011 and a good duty cycle, with IGBT's Not mosfet
I don't weld for a living, so I'm in no hurry. I like to take time and make sure I buy what I need, instead of getting in a hurry and regret I didn't buy something else.
So, let me know which mod will fit my needs /wants and I'll look it up and read on it and ask any questions before I decide to purchase
/ multi function inverter welders #33
If you don't want a MIG unit, then the PowerTIG 255EXT unit would be the one you want.
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
7021 (A55851)
7021 (A55851)
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
