MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,373
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Hmmm...... I wonder what the cut-off year is between modern tractors that can't flip and those that can is? Maybe a '95 tractor can flip, but a '96 can't? I guess knowing the year your tractor was made is VERY IMPORTANT, your life could depend on it!
How could it do that? It's fixed below the axle.
Not to dampen the lively dialogue, but I'm going to post a link to a HOSTA - Hazard Occupation Safety Training in Agriculture - PDF that explains the many ways to connect implements to your tractor. It has helped me to better comprehend the various risks associated with each method.
https://articles.extension.org/sites/default/files/NSTMOP Task Sheets Section 5 2013.pdf
juan
The longer the drawbar is behind the axle the more pronounced is the "chain line" above the axle. Really needs an illustration to show this but just picture a line drawn thru the chain and passing above the axle.
Shorten the chain and attach it to the load down low to the ground. Might have to lengthen the drawbar a little also to get the chain line above the axle.
Like this:
OK, I see now, if the drawbar is long enough, the load attachment point low enough, and the chain short enough, you can get the line of the chain above the axle until the tractor tips up enough. Then, if it tips past the position in the lower sketch the chain begins to pull the front end down.
I can see that drivers in tractor pulls might rig this way to increase traction. I suppose that's why drawbars on real tractors aren't that long.
Can't be - it is stated in the document:Oh CRAP, my tractor is defective, "chassis" draw bar is only 8 inches off ground, according to page 2 of document it should be 15 (+/-) inches and my drawbar material is a lot smaller in dimension than specified in chart....Guess none of what document says will apply for me....
Dale
"Figure 5.1.d. Tractor drawbars are
designed at the correct height from
the ground to keep the pull forces
below the center of gravity."
Have you checked your tire pressure?
It's a MF GC 1715 (SCUT) everything is low to ground....And yes it advertises as a CAT 1 hitch which implements seem to fit.... Picture soon ... Done ..
Guess your next comment will be "its not a real tractor"...
Dale
It was a joke.
