Akita Pool
/ Akita Pool #201
The ceiling will be tongue and groove. On top of the OSB decking is 30lb roofing paper, and on top of that will be the R panels. Insulation crossed my mind, but I didn't think it would accomplish anything out on a porch. Should I rethink that?
I don't see the point. The more the structure can breathe the better IMO.
/ Akita Pool #202
I've wondered this myself, would a bit of insulation substantially drop the temps on the porch in the summer? In my case it's a full width porch on the front of our house that gets sun most of the day. Nice setup Eddie.
/ Akita Pool #203
Maybe a layer of something reflective but not so much for insulation. I would try and stop the heat transfer especially if the roofing is dark colored.
/ Akita Pool #204
Agreed, light colored/reflective is a good idea but maybe too late?
/ Akita Pool
Just to add to the insulate or not to insulate question. The porch faces East, so I get some morning sun, but there are a bunch of trees that block most of it. As soon as the sun passes my house and it becomes afternoon, and the heat of the day, the porch is in the shade of the house. It is significantly cooler under the porch then just under the shade of a tree.
/ Akita Pool #206
for an exterior porch insulation is not going to do much for you.......if you wanted to cut down on heat build up in the attic area you could install an attic ventilator fan on a thermostat......I have found that dropping the temp in the attic makes a world of difference to the space below.......Jack
/ Akita Pool #209
Don't know if they are popular down your way but what about water 'misters'? We don't get much heat in the PNW but I rimmed my gutters around our small deck with misters and it is wonderful for us on the rare hot days.
/ Akita Pool #210
I would say only insulate if temps up there are high. I would go for good ventilation first.
/ Akita Pool
Thinset arrived yesterday, so I might start tiling next weekend. If not, the following weekend for sure. My metal is also in for the porch roof. I might pick that up this afternoon if I get done with the job I'm on in time, or I'll go tomorrow morning to get it. We are having a birthday party for Karen's youngest grandson. He just turned 2. He loves to play on the steps in the pool!!!
This will be the last time it's used until the tile is done. My supplier told me that the biggest reason for failure on swimming pool tile is from filling the pool too soon. The thinset needs at least two weeks to cure, with a month being better. I plan on doing a custom mosaic on the back wall, so that's going to take a lot of time, along with working on the porch, so it might be winter before I'm ready to fill it again.
Here are a few pics from last night. My wife and I really enjoy sitting out there under the ceiling fans, and listening to the water fall into the pool. Then when it gets dark, the view of the pool all lit up, along with the tiki torches, is just very relaxing.
/ Akita Pool #212
Just another very cool project, Eddie!!! Do you know what your mosaic will be?
/ Akita Pool
Yes. It's an Akita that I will create out of cut stones.
/ Akita Pool #214
I love the Akita pool. Is it just for the dogs, or do you and Karen use it too? We have a 6' round by 2' high galvanized water trough with a filter and chlorine tabs that we use as a soaking pool. We really enjoy sitting in it in the evenings after a long day, or jump in it after working in the yard. It's just right for cooling off.
With our new patio, I'm going to make a water feature using a 8' round x 2' tall (4 person) galvanized water trough that will double as a soaking pool. It'll have lights inside and I'll insulate it and clad it with cedar to match some of the patio cedar trim. I haven't decided on the water feature, but I'm leaning towards one of the old cast iron well pumps running water out the spout. I'm also looking to tie it in with a solar pool heater. My roof is facing south and would work perfectly for mounting one.
/ Akita Pool #215
Be careful with chlorine tabs and galvanized sheet metal.
/ Akita Pool #216
How will you finish the T&G?
/ Akita Pool #217
We haven't had an issue with our existing one, although it was already oxidized if that makes a difference. What's the concern? The next tank we plan to coat the inside with a paint used for swimming pools or potable water tanks, so that should make it a non-issue anyway, I hope.
/ Akita Pool
My wife has a stain color that she likes. I forget what it is right now, but will post when we get to that point. I'm debating if I want to do anything else to it or not. I'm not a fan of a shiny, glossy look. I've thought about oil, but haven't really compared what's out there. I have a few different brands on my shelf, so I'll read the labels and see which is best, and then do a test to see if we like the results. Or maybe a sealer that doesn't have much of a sheen designed for the outdoors.
I'm going to build the cabinets too, and will probably stain them darker then the ceiling, and probably put a couple coats of sealer on them to protect them, so maybe the ceiling will get the same treatment.
/ Akita Pool
This was last night. We are having a birthday party today and expect to have about 20 people here. Half will be in the pool. Where it begins at the porch is all stairs, so it's a great spot or the little kids to splash around, or for adults to sit and relax. We call it the Akita Pool because of the mosaic that I am going to create on the back wall. A full sized Akita with traits of all four of ours that will be done in cut stones. Half of the year, the pool will be empty, and we wanted something attractive to see other then just a square hole in the ground, so I'm going all out on the tile job. In my mind, it's really gonna be something. Hopefully I can create what I'm imagining.
Akita's are not water dogs. They will get their feet wet, but that's about it.
One of the nice surprises that we've discovered is that the skimmer works great at catching pine needles. A real concern that we had was constantly cleaning them out of the pool. But with the three jets set at each corner, the water circulates so that anything floating on the water ends up getting sucked into the skimmer. The basket in the skimmer catches all the debris, and it's super easy to take out and dump.
The water feature was a spur of the moment idea that we really like. Originally I was planning on buying a couple of spitters and putting one at each corner. I ran electrical to turn them on from the house that we might use for something else. I put in a 3/4 drain line to drain my pipes for winter, and then added a T with a valve to run water up to the blue ceramic pot. Then in the koi pond section at Lowes, I found this water fall thing that fit nicely into the pot with a piece of PVC cut to support it. We really like the way it's turned out.
/ Akita Pool #220
Thanks, when i built my house i put 1/4" plywood for my porch ceiling, painted. Always meant to go back and redo with something else, and add a couple ceiling fans.1535206538937.jpeg
This is side porch, porch turns and goes 42' down the front.
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2024 John Deere TX (A64119)
2024 John Deere TX...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
