Akita Pool
/ Akita Pool #221
We haven't had an issue with our existing one, although it was already oxidized if that makes a difference. What's the concern? The next tank we plan to coat the inside with a paint used for swimming pools or potable water tanks, so that should make it a non-issue anyway, I hope.
Mostly if will just aggressively rust out your tank. There are probably a few insignificant fumes released. You would have to have it in an enclosed room with zero ventilation to even measure them.
/ Akita Pool #222
My wife has a stain color that she likes. I forget what it is right now, but will post when we get to that point. I'm debating if I want to do anything else to it or not. I'm not a fan of a shiny, glossy look. I've thought about oil, but haven't really compared what's out there. I have a few different brands on my shelf, so I'll read the labels and see which is best, and then do a test to see if we like the results. Or maybe a sealer that doesn't have much of a sheen designed for the outdoors.
I'm not a fan of the glossy look either. My dad went with a marine varnish on the T&G undersides of the roof on our cabin and I hated it once I had to maintain it. I think an oil that doesn't build up would be good.
/ Akita Pool #223
I may use a small horse trough for my Great Pyrenees-Anatolian Shepherd mix puppies. They are Central Texas dogs but get plenty hot.
/ Akita Pool
We had a birthday party on Saturday with over 20 people, and it turned out great. The pool was a lot of fun, especially with the little kids who played on the stairs most of the time. The big discovery, and change that I'm going to have to address is that when lighting the grill, the ceiling fans pull the smoke into them. This created a very smokey area under the porch that needs to change. We turned off the fans and the smoke when away, but having to leave the fans of when lighting the grill doesn't seem like a good option.
I've been looking out outdoor hood vents, and what others have done. Seems like almost all of them are stainless steel. We don't care for that look. The other models that we've found online are a lot more money if you don't go stainless steel. Even the inserts that go into a home made vent box are crazy expensive, and stainless steel.
My current plan is to buy a normal 36 inch, best quality from Lowes, range vent and then build a metal box around it that tapers to a smaller square tube that goes into the attic area of the porch. I'm thinking that I'll run 7 inch round ducts from the top of the range vent up into the attic area, then turn it out the side of the porch and up to the height just above the second story of my house, kind of like a chimney.
Has anybody tried to do this before? My plan is to use angle iron and then tack in sheet metal inside the angle iron so I have clean edges as viewed from the outside. I'll post pics once I start to do this. I need to buy some angle iron. I'm thinking 1 1/2 inch should look the nicest.
/ Akita Pool #225
The chimney sounds good. What about putting copper sheeting over the vent you buy? You then can age and/or color it with mutliple colors of "patinas" like here....http://www.colorcopper.com/pages/copper-countertops
or here........ Patina Formulas for Brass, Bronze and Copper
When I build my house, I'll do my copper countertops with one of the shades of patina.
hugs, Brandi
/ Akita Pool #226
/ Akita Pool
hugs, Brandi
Thanks Brandi!!! That's an interesting look. We have been searching for ideas, and I really like how "natural" copper looks.
/ Akita Pool #228
I may be preaching to the choir, but 2 90 degree bends in the exhaust stack will seriously reduce the CFM capacity of the vent hood. Can you vent straight up with a suitable roof termination?
/ Akita Pool
I can, but that would mean getting a boot to go through the meal. My pitch is 2:12 for the porch, so that means I have be extra careful in getting it installed perfectly. It also means that if there is any movement in the porch, that's where my leak will be. While doable, I really prefer to avoid that for just a BBQ. How much do you think I'll lose with two 7 inch 90's on a vent rated at 300 cfm?
https://www.homedepot.com/p/NuTone-...18209?storeSelection=6514,6545,8540,6579,6817
/ Akita Pool #230
If you are going to build a box, why not put an extractor fan on the outside? Then you can just use the box and the fan outside. Just be sure to pitch it toward the hood and run the joints with the small end toward the hood so any grease runs back down the pipe and into the hood vs dripping on the deck.
Aaron Z
/ Akita Pool #231
It's wide open how your finish would come out. I can't wait to play around with it.
hugs, Brandi
/ Akita Pool
Aaron Z
This is why I post stuff on TBN. I never heard of an extractor fan before and would have never done a search to buy one. Now that I've done that search, I've learned that for a significantly less amount of money, I can get a much stronger fan that will pull more more air then I thought I could.
Thank you!!!
/ Akita Pool #233
Thank you!!!
Glad I could help, we had one of those on the range hood in the kitchen growing up and it was nice to have all that noise outside rather than in the kitchen.
Aaron Z
/ Akita Pool
On the thought of the extractor fan, I took a look at attic fans. This one at McCoys was $80 and it moves 1,050 CFM of air!!!! I honestly have no idea of how much air that I want/need to move, but I think I'll have it covered with this much power.
/ Akita Pool #235
Perhaps just mount one of those on the gable end of the porch with shutters over it in the wall?
Aaron Z
/ Akita Pool #236
If there is any way to check noise/decible ratings on fans. I know the greenhouse fan I bought moves a lot of air but it is a bit noisy if as it spins fast. In your relaxing area, I would want a very quiet fan. maybe a slow speed?
/ Akita Pool #237
That party sounds like it was a great time!
Not sure if it is appropriate, but would fans that could reverse direction be an option?
Hope your wife is doing well!
/ Akita Pool #238
If you are concerned about noise, there is a hood option where the fan is relocated in the attic just below the roof. So it sucks air up and out instead of being in a hood pushing it.
/ Akita Pool
Fan placement will have to be where I can get to it and replace it when it wears out. Ideally, I would want it as far away from everything as I can, but I kind of think that the only place that I will be able to change it will be right inside the vent hood. Whatever I decide to buy, I will test it first to see how loud it is.
I didn't think about green house vent fans. I'll look at them too!!!
/ Akita Pool
I put the metal roof on the porch this weekend. Heat and high humidity made this a painful project, but overall, it wasn't too hard.
2001 Pierce Pumper Fire Truck (A64556)
2001 Pierce Pumper...
11in. Bucket with Teeth Excavator Attachment (A64194)
11in. Bucket with...
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
1991 FREIGHTLINER FLA-89 T/A SLEEPER TRUCK TRACTOR (CABOVER) (A67148)
1991 FREIGHTLINER...
2009 Ford F-450 Ambulance (A64556)
2009 Ford F-450...
