New bridge 4 new tractor
/ New bridge 4 new tractor #1
Jacksonvly
Member
Kioti CK 2610
Last springs heavy rains washed out my old bridge.
This run off is 4-5 feet deep and only 8 feet across. Dry except for rains , then it's a raging torrent.
Used beams made of 4 sandwiched 2×10.
They sit on top of 36 inch utility pole sections buried. Three beams total.
Rough cut hemlock deck
Field stone accent on earth ramps.
/ New bridge 4 new tractor #2
Very nice looking bridge. Did you cover the sides before the bridge to prevent washouts?
/ New bridge 4 new tractor #3
Looks great.
My insurance company would probably make me put a rail :laughing:
/ New bridge 4 new tractor #4
Looks nice. I need more details and pictures so I can duplicate it :)
/ New bridge 4 new tractor #5
I have no idea what you take across your bridge,
when we put in culverts or bridges we also have a creek crossing that we use for heavy and or wide loads,
gentle slopes down in and out with large rock lining the bottom 8-12 inch rocks driven in smooth.
also, very nice looking bridge
/ New bridge 4 new tractor #6
A rail? Are you kidding? Pedestrian walkways, bike lanes and load limit signs. And a Government TROLL to collect taxes. (Needs Air conditioned hut and lunch room). Don't forget cameras.
Very nice bridge!
/ New bridge 4 new tractor #7
Very nice bridge Jackson! Want to come and build me a 30ft clear span footbridge? Apparently a non insured driver decided my existing one was ugly and took it out..
Probably add a railing , still debating styles.
/ New bridge 4 new tractor #9
Looks great. I really like the rock that you used!!!
/ New bridge 4 new tractor #11
Looks great -- almost too nice for a tractor!
/ New bridge 4 new tractor #12
Nice...very nice :thumbsup:
/ New bridge 4 new tractor #13
Mind sharing how much total cost you have into it? I need to make something similar for my creek.
I got 10 foot pieces on new utility poles from a lineman buddy.
The pressure treated lumber and the hemlock came from a mill nearby. It and the hardware, bolts, screws etc was a bit under $300.
Not near as much as I had expected.
I need to seal the decking, when it ever dries out....
/ New bridge 4 new tractor #15
Thanks! very reasonable indeed.
Can you describe a bit (or show more & bigger pics?) of how the utility poles are oriented? like driven in to the ground as posts?
Posts in the ground 3 feet. I used a post hole digger and ground bar, lots of cussing too. The beams rest on top of the utility poles. I cut them level once in with a chainsaw. 10 inch poles, it was like cutting iron!
/ New bridge 4 new tractor #18
Used beams made of 4 sandwiched 2ラ10.
Great JOB...
/ New bridge 4 new tractor #19
Very nice! Did you screw the beams to the utility poles so this one won't wash away? What size screws?
/ New bridge 4 new tractor #20
Nice looking bridge. Did you treat the hemlock or is it rot resistant? Don't have hemlock around here.
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
Cattle Feeder (A65640)
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
LOOK! (A63109)
LOOK! (A63109)
3 Bottom Plow (A65640)
John Deere 12ft pull-type cultimulcher, Orion, IL (A65640)
John Deere 12ft...
