New bridge 4 new tractor
   / New bridge 4 new tractor #11
Looks great -- almost too nice for a tractor!
   / New bridge 4 new tractor #12
Nice...very nice :thumbsup:
   / New bridge 4 new tractor #13
Mind sharing how much total cost you have into it? I need to make something similar for my creek.
I got 10 foot pieces on new utility poles from a lineman buddy.
The pressure treated lumber and the hemlock came from a mill nearby. It and the hardware, bolts, screws etc was a bit under $300.
Not near as much as I had expected.
I need to seal the decking, when it ever dries out....
   / New bridge 4 new tractor #15
Thanks! very reasonable indeed.
Can you describe a bit (or show more & bigger pics?) of how the utility poles are oriented? like driven in to the ground as posts?
Posts in the ground 3 feet. I used a post hole digger and ground bar, lots of cussing too. The beams rest on top of the utility poles. I cut them level once in with a chainsaw. 10 inch poles, it was like cutting iron!
   / New bridge 4 new tractor #18
Last springs heavy rains washed out my old bridge.
This run off is 4-5 feet deep and only 8 feet across. Dry except for rains , then it's a raging torrent.
Used beams made of 4 sandwiched 2ラ10.
They sit on top of 36 inch utility pole sections buried. Three beams total.
Rough cut hemlock deck
Field stone accent on earth ramps.
Great JOB...
   / New bridge 4 new tractor #19
Very nice! Did you screw the beams to the utility poles so this one won't wash away? What size screws?
   / New bridge 4 new tractor #20
Nice looking bridge. Did you treat the hemlock or is it rot resistant? Don't have hemlock around here.
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
Krause Dominator 4850-18ft (A55301)
Krause Dominator...
2014 Jeep Cherokee Latitude SUV (A55758)
2014 Jeep Cherokee...
2004 CATERPILLAR D5N XL HIGH TRACK CRAWLER DOZER (A52705)
2004 CATERPILLAR...
CATERPILLAR 255 SKID STEER (A52705)
CATERPILLAR 255...
2015 Caterpillar 314E L CR (A53314)
2015 Caterpillar...
