Rotary Cutters Fling Hazard
/ Rotary Cutters Fling Hazard #21
I look at the construction of a flail cutter and wonder just how badly those blades will fare against a 4 stone? For rough work, I still think a rotary cutter is best.
I've hit everything from 1"-8" rocks with our flair mower and the blades just bound off of it since they weight almost nothing. Just sounds like running over something with a dremel tool :laughing:.
/ Rotary Cutters Fling Hazard #22
Flail mower and rocks kind of depends on the type of fastener used on the rotor. The shackle type of fasteners allow the blades to fold back a lot better than the fasteners that have the blades bolt directly: the bolted-on blades cannot fold back as far.
As suggested, pay someone to mow it several times (put the liability on them) and then once things are exposed (and likely leveled out some) do it yourself.
/ Rotary Cutters Fling Hazard #23
I've been doing a lot of brush hogging lately, on many different properties. None very close to homes or vehicles, but occasionally near roads. When cars go by or pedestrians walk by, I simply stop and drop or raise the cutter. I always ask the property owners to stay indoors or safely away.
Dieselbound - your suggestion explains why I'm so busy working for people with their own tractors!
/ Rotary Cutters Fling Hazard #24
Yup! If one isn't comfortable doing something then best to have someone who is do it. I do this with cutting trees: many I can/will do, but there are some that I will not do (ones close to the house or to the road and require climbing up in the tree(s)) so I hire it out.
If one IS going to do this themselves then a quick check of one's homeowners insurance policy might be in order. (give some peace of mind- if you're too nervous you're more inclined to mess up)
/ Rotary Cutters Fling Hazard #25
You can research blade velocity of various width Rotary Cutters. Wider cutters have much higher blade velocity.
A BX will likely have 48" width R/C.
Blades within a BX Rotary Cutter will not be nearly as heavy, therefore will not store nearly as much energy, as thicker, wider blades on wider cutters.
In short, throw damage from a Rotary Cutter behind a BX is minimal.
The 3 blade 60" (~20" blades) finish deck on my JD430 Garden Tractor will throw a baseball-sized piece of riprap 15 yards easy, through the chute.
If you are worried, add some rubber skirts or short chain pieces to the sides to slow down anything that gets thrown. Pick up as much as you can before you mow and make sure your blades are on tight and the bolts and bushings are in good shape.
/ Rotary Cutters Fling Hazard #26
The duck foot/hammer/forestry cutter style, would probably take a beating, but still be contained and safe. The knife style has such a low mass, they just bounce off.
/ Rotary Cutters Fling Hazard #27
Those are attached with shackles, which, from my limited understanding, are going to give way a lot better than those that bolt directly to the rotor. But, it doesn't take a lot to dull a more fine-edged blade, one that's spinning at a fairly high rate of speed: kind of like a chain saw chain (though not quite that extreme). Regardless, I have no doubts that a flail offers greater safety: whether it would be essential in the OP's case is hard to say (it all comes down to risk mitigation).
/ Rotary Cutters Fling Hazard #28
You should see the rotary cutters we use over here to realize what fling hazard is. :D
We use chains instead of blades. It will eat more HP but will also deal with pretty much anything you throw at it and handles rocks better than blades, so less maintenance. The chains also spreads the shredded stuff better and doesn't get clogged up.
I remember old-timers doing this back in the 70s. Do the chains do a decent job on grass, too? Or is this cutter mostly for ripping heavy brush?
/ Rotary Cutters Fling Hazard #29
Yep, we have 4', 5', 6' and 10' and heavier, faster blades are going to throw heavier, faster objects...
/ Rotary Cutters Fling Hazard #30
But, it doesn't take much to crack a window/glass (which is one of the primary concerns).
/ Rotary Cutters Fling Hazard #31
Hi all. I bought a rotary cutter for my subcompact to keep the weeds down until I can landscape on my two acre lot. I'd like to get as close to the house as much as possible. I plan to put 4 by 8s in front of windows and patio doors (I have a lot of windows) when cutting by house and then check the area for rocks and objects ahead of cutting.
My question. Do rotary cutters fling in all directions? I've read that the rear should be set higher to allow for material to escape so I was going to avoid driving directly away from the house and do most of the cutting runs in parallel.
My thoughts:
1. Check the area for objects that may fling.
2. Set the cutter high (no need to cut flush to the ground).
You don't have to raise the rear...just keeps grass from clumping if in heavy stuff and lots of clippings to discharge. Chains are usually available from the mower mfgr for front (to protect your tires) and rear to protect things behind you. If not make your own, not a hassle, I have done it many times. Lot less throwing than my drum mower that i use for cutting hay for sure and blade tip speed is slower so there isn't as much energy in missiles propelled by it as regular 2 and 3 blade conventional and ZT mowers.
/ Rotary Cutters Fling Hazard #32
I can tell you that even a 21" push rotary mower can fling a small rock all the way to at least 50 feet, and cause a severe injury too!..
/ Rotary Cutters Fling Hazard #33
For grass, can't really beat the blades or flails. It will work, but doesn't really leave a smooth finish. It's really meant for heavy brush like we have a lot.
Here is a before and after example. The brush was as high as the tractor in some spots and I've done this in one pass on 540E in my 35 HP Branson.
/ Rotary Cutters Fling Hazard #34
you wouldn't want to use that for grass you want to keep!. you'd get ragged edges, which promotes disease, and it wouldn't give a nice cut, either, basically, the grass would be just pulled at the level of the chain..
I bought a Landpride 42" rotary cutter for my BX. PTO HP wise, the dealer said I could go with a 48" but I plan to plant grapes vines and space the rows at a distance where I can go through with the tractor and cutter.
The flail cutter the dealer had was $3500. Looked impressive and that's what they used to clear their own practice field. If I were to do this on a regular basis, I might have considered it.
I did have someone do the lot in the late spring with a 60" cutter. He piled all the rocks he hit or saw in the center of the picture I attached... which I have now set aside on one place in the lot in preparation.
I will be extra careful, go slow and pre-inspect.
Thanks all for the info.
/ Rotary Cutters Fling Hazard #36
The county (local government next step up from city government), uses just that to keep the roadsides cleared. They have a tractor with a counter weight on the road side and that type cutter is on a long arm, like a backhoe arm with hydraulics to positon the deck in most any attitude from below the horizon to straight up. Works great and yessiree it throws stuff big time.....but as you say, cuts anything including tree limbs hanging over the road, because in the several trips they make along the road, a lot of them are trimming overhanging tree limbs.
/ Rotary Cutters Fling Hazard #37
I would not worry about it unless you are in a very confined spot. A 4 foot cutter is so close to the back of a small tractor that it is mostly blocked. If you keep the cutter close to the ground (8 inches or so), you will be fine. A 6 foot cutter behind a utility tractor can be a different story.
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2013 Chevrolet Traverse AWD SUV (A59231)
2013 Chevrolet...
2020 Club Car Carryall 700 Gas Utility Cart (A59228)
2020 Club Car...
