Solar Battery tender for dump trailer
/ Solar Battery tender for dump trailer #2
I would opt for the 15 watt panel.
At 830 milliamps you'll have that added reserve for those cloudy days.
/ Solar Battery tender for dump trailer #3
I’d like to do this also, that is the panel I use for my genny. Works well.
On the trailer how would you mount it so it wasn’t likely to succumb to breakage?
I was just gonna mount it on top the pump box. Maybe make a cover on a hinge so when trailer parked and not in use you just flip it up to charge
/ Solar Battery tender for dump trailer #5
/ Solar Battery tender for dump trailer #6
Deltran is high quality products.
/ Solar Battery tender for dump trailer #7
/ Solar Battery tender for dump trailer #8
Also to orient it to teh prevailing sunlight regardless where it was parked/stored.
/ Solar Battery tender for dump trailer #9
Mine is mounted flat facing up on the tongue box. I got a 20 watt panel which is overkill. On most RVs & trailers it's way easier & cheaper to go overkill on panels & just flat mount them. Sun tracking systems, or even just making a mount so you can angle them is complex & expensive. At least compared to a fixed mount.
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2017 Mack Semi (A64047)
2017 Mack Semi...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
2008 FORD CROWN VICTORIA CAR (A66091)
2008 FORD CROWN...
