Solar Battery tender for dump trailer
   / Solar Battery tender for dump trailer #2
I would opt for the 15 watt panel.
At 830 milliamps you'll have that added reserve for those cloudy days.
   / Solar Battery tender for dump trailer #3
I’d like to do this also, that is the panel I use for my genny. Works well.
On the trailer how would you mount it so it wasn’t likely to succumb to breakage?
I was just gonna mount it on top the pump box. Maybe make a cover on a hinge so when trailer parked and not in use you just flip it up to charge
   / Solar Battery tender for dump trailer #5
   / Solar Battery tender for dump trailer #6
Deltran is high quality products.
   / Solar Battery tender for dump trailer #7
   / Solar Battery tender for dump trailer #8
Also to orient it to teh prevailing sunlight regardless where it was parked/stored.
   / Solar Battery tender for dump trailer #9
Mine is mounted flat facing up on the tongue box. I got a 20 watt panel which is overkill. On most RVs & trailers it's way easier & cheaper to go overkill on panels & just flat mount them. Sun tracking systems, or even just making a mount so you can angle them is complex & expensive. At least compared to a fixed mount.
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
