Solar Battery tender for dump trailer
/ Solar Battery tender for dump trailer #2
I would opt for the 15 watt panel.
At 830 milliamps you'll have that added reserve for those cloudy days.
/ Solar Battery tender for dump trailer #3
I’d like to do this also, that is the panel I use for my genny. Works well.
On the trailer how would you mount it so it wasn’t likely to succumb to breakage?
I was just gonna mount it on top the pump box. Maybe make a cover on a hinge so when trailer parked and not in use you just flip it up to charge
/ Solar Battery tender for dump trailer #5
/ Solar Battery tender for dump trailer #6
Deltran is high quality products.
/ Solar Battery tender for dump trailer #7
/ Solar Battery tender for dump trailer #8
Also to orient it to teh prevailing sunlight regardless where it was parked/stored.
/ Solar Battery tender for dump trailer #9
Mine is mounted flat facing up on the tongue box. I got a 20 watt panel which is overkill. On most RVs & trailers it's way easier & cheaper to go overkill on panels & just flat mount them. Sun tracking systems, or even just making a mount so you can angle them is complex & expensive. At least compared to a fixed mount.
2023 Unused Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
2023 Unused...
2019 Ford F-150 (A64911)
2019 Ford F-150...
Billy Goat DL2500S Debris Vacuum (A64912)
Billy Goat DL2500S...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A67714)
TWO PALLETS OF HYD...
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
