Solar Battery tender for dump trailer
   / Solar Battery tender for dump trailer #2
I would opt for the 15 watt panel.
At 830 milliamps you'll have that added reserve for those cloudy days.
   / Solar Battery tender for dump trailer #3
I’d like to do this also, that is the panel I use for my genny. Works well.
On the trailer how would you mount it so it wasn’t likely to succumb to breakage?
I was just gonna mount it on top the pump box. Maybe make a cover on a hinge so when trailer parked and not in use you just flip it up to charge
   / Solar Battery tender for dump trailer #5
   / Solar Battery tender for dump trailer #6
Deltran is high quality products.
   / Solar Battery tender for dump trailer #7
   / Solar Battery tender for dump trailer #8
Also to orient it to teh prevailing sunlight regardless where it was parked/stored.
   / Solar Battery tender for dump trailer #9
Mine is mounted flat facing up on the tongue box. I got a 20 watt panel which is overkill. On most RVs & trailers it's way easier & cheaper to go overkill on panels & just flat mount them. Sun tracking systems, or even just making a mount so you can angle them is complex & expensive. At least compared to a fixed mount.
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
Pallet Fees (A50775)
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2023 John Deere 410R Sprayer (A53342)
2023 John Deere...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
