Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,721
I’m guessing the bucket weighs closer to 300 pounds. A 600 pound grapple for that size machine is a little heavy. With a properly sized grapple the weight difference isn’t substantial. And the loader is good for a lot more than 1100 pounds a couple feet high. The breakout force is pretty close to the ground level lift.
/ Grappling fun - A Picture Thread.... #1,725
Is that Everything Attachments 55" grapple available in BC Canada ? Shipping and Duty really bothers me for a single item. Not worth that extra expense, so I think I'd prefer getting via Kubota somehow where they can order a whole container of things.
/ Grappling fun - A Picture Thread.... #1,726
What would you end up paying? I assume you are talking about the EA 55” rake grapple?
/ Grappling fun - A Picture Thread.... #1,727
yes, that's the one. still checking for quotes, so I'm not sure yet
/ Grappling fun - A Picture Thread.... #1,728
/ Grappling fun - A Picture Thread.... #1,729
209 lbs, works great! Best Rated 55 Inch Wicked Root Rake Grapple from Everything AttachmentsView attachment 553847View attachment 553848
I suspect your bucket is more than 100 lbs. I think my 60" is about 220....
I really liked the Wicked 55" mainly cause of weight. I'm new to using a root rake grapple so excuse my ignorance. I've seen two main versions. The first is like the wicked and looks like its best for "grabbing" a pile of brush. The other kind has tines that are parallel to the ground and seam to work better at "scooping" up brush. How well does the wicked work for scooping up brush. I'm clearing my land with a dozer and root rake but will need to do the fine clean-up with my tractor. I plan to use my landscape rake and a grapple.
/ Grappling fun - A Picture Thread.... #1,730
The first type is often called a Rake Grapple, the second type is often called an L Grapple. I have both. I generally use the L grapple since it carries a lot of brush and debris as well as it is better all around for me. Ie carries more firewood, digs deeper, etc. The rake style I mostly use as a rake, often back raking, mine carries relatively little brush and even only one decent size log. The Rake style that EA has out has better lower teeth and looks to close the gap a little volume wise. Different grapples are going to change the dynamics of what you can lift and your mileage may vary.
I pulled this old smoke dragon out of my basement the other day....
The hardest part was moving it from it's original location to out the basement door, after that the grapple made easy work of it :D
I find that I end up using my grapple almost as much for these 'unique' one off jobs that I never anticipated, than I do for the more standard jobs I had planned for it, like land clearing and brush.
I'm not sure if I should send the woodstove to the scrap yard, or cut the top off it and make an evaporator for my maple syrup. :confused:
/ Grappling fun - A Picture Thread.... #1,732
View attachment 559866 View attachment 559867
NICE looking grapple, I find I also use mine for lots of other stuff also.
/ Grappling fun - A Picture Thread.... #1,733
Piston has a WR Long grapple shown in the pictures. I have a WR Long grapple (of my three grapples) and they are top notch grapples. I chose the WR Long over the EA largely due to vertical opening capacity.
/ Grappling fun - A Picture Thread.... #1,734
Yes me to as I recall it's got 46''plus of vertical opening capacity. I do think the Wicked are teeth are sharper & nicer looking. Don't know if it helps or not.P1010330.JPGP1010128.JPGP1010136.JPG
/ Grappling fun - A Picture Thread.... #1,735
I moved some eucalyptus rounds today and figured I would see if I could move a few large pieces I have as I want to use them for a barricade along the roadside of my pond. It was tight quarters so I removed my mower I use to keep the rear wheels on the ground. Well I got them out of the overgrown area. Load was not centered my left rear wanted to come off the ground when I stepped off the tractor to take the pictures, I jumped back on the tractor to lower the loader (wish I would remember to get my fingers out of the lens area). I have a lot of rear ballast on tractor rear wheels. I think if I had the load centered I would have been OK. I don't know if anyone is familiar with eucalyptus it is dense and very Heavy even when dry. This Euch log was cut down about 35 years ago so it is real dry. Extremely hard wood (it's almost as if these stumps have petrified instead of breaking down over the years) I think there are 4 more in the brush pile. The bushes and posion oak have grown up around the logs & covered them up. After I removed the stumps and some piles of rocks I will brush hog the area and reclaim it. I wanted to remove the brush years ago But my wife said Oh leave it as habitat for the wild animals! Last week she saw a coyote with her black cat hanging from its jaws. Now she wants me to remove all the brush. : (
That is a BEAST of a log there Case!
/ Grappling fun - A Picture Thread.... #1,737
14 foot long by 28" diameter EWP log for the sawmill. It lifted it just high enough to clear the fenders on my trailer. 20180709_180454.jpeg
/ Grappling fun - A Picture Thread.... #1,738
Nice log - that is starting to crowd 2000 lbs I would say. Will make some nice lumber.
gg
/ Grappling fun - A Picture Thread.... #1,739
I estimate it weights around 2900 lbs I needed the larger opening 42.5 " of the WR Long to grab it. I am impressed on the capacity of the Tractors loader if I didn't have 4 whl drive it would have been real difficult to move it without ballast on my 3 pt. Next time I move it i will be able to center the load should be a bit easier to lift and wheel it away to its final destination as a deterrent to the folks that want to pull over along my fence line wide spot to use their Cell phones I wouldn't mine except after they leave i usually find a few empty beer cans, or tissues grrr.
I used Timber and Lumber Calculators at WOODWEB to estimate the weight
/ Grappling fun - A Picture Thread.... #1,740
Nice! If you cut that in quarters I'd be able to roll them around with my little machine. :laughing:
2016 AUXILIARY POWER UNIT (A60736)
2016 AUXILIARY...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
John Deere 24in Digging Tooth Bucket Excavator Attachment (A60352)
John Deere 24in...
2014 CM TRAILER ENCOLSED CARGO TRAILER (A60736)
2014 CM TRAILER...
2013 Ram 1500 Pickup Truck, VIN # 1C6RR6GP1DS541918 (A61165)
2013 Ram 1500...
