Land plane opinions
/ Land plane opinions #1
TxBigRed
Hemphill Texas
kubota 3240
So I saw this land plane on Craig's list for $300, had it listed as a box blade. Not sure if it is home made or not. The guy said it was 6'. I noticed that the cutters appear to be straight across instead of diagonal, would that make alot of difference in it's operation? Seems like a good deal for $300.
/ Land plane opinions #2
If you watch Youtube movies of them in operation, you will see there is almost no sideways movement of gravel on the angled blades.
If that was here, it would be mine already. :)
Bruce
/ Land plane opinions #3
i would go for it! Looks nice and heavy
/ Land plane opinions #4
I'd grab that in a heartbeat for the price.
/ Land plane opinions #6
DaveView attachment 547262View attachment 547263View attachment 547264
I don't even like the land plane use concept....but.....
I would run .... with CASH..... to buy that!
Ok, here's the deal. I just went and looked at it, but it looks to be cat2, and I have a l3240 cat1. The holes for the lower arms are about 28" center to center and are around 1.25 inches in diameter. Can this be used on my tractor with some type of bushings?
He's going to hold it for me until noon tomorrow. And it is one heavy piece of gear!
/ Land plane opinions #8
You can bush it. The issue is will it be too heavy for your tractor?
/ Land plane opinions #9
You can also install bolt on pins and have them pointing towards the center. Not ideal, but it would work to get your mounting width narrower. That or weld on 2 ears and get the long cat 1-2 pins for that type of hitch.
Buy it and figure the mounting out later. That is a "REAL" deal. :thumbsup: :thumbsup:
That's what I'm hoping the experts here can tell me.
/ Land plane opinions #11
Yep - can pin it. Worse case try it and if you don't like it sell it for $600 and someone will jump on it!
Ok, I'm getting it.Like you guys said, even if it's too heavy for my tractor could always sell and get my and then some!
/ Land plane opinions #13
If it is too heavy for your 3pt, but you have room to turn:
Bruce
/ Land plane opinions #14
Your 3pt lift capacity is 2646lbs at 24" back of lift point. I doubt that you will have any lifting issues. ;)
That's what I was thinking. Maybe traction issues, and getting it modified for cat 1
/ Land plane opinions #16
I can't tell if that has replaceable cutting blades or not. If not, it would be a good/easy/cheap add. Similarly for skids.
It definitely has cutting edges added to it, didn't look close enough to see how they we're attached.
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
Challenger 65 Parts and Service Manuals (A63117)
Challenger 65...
2016 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
AUCTION STARTS HERE @ 9AM (A64276)
AUCTION STARTS...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
