Yt359 cat I hitch?
   / Yt359 cat I hitch? #1
Macinnis
Gold Member
St. Louis/Old Mines MIssouri
LS MT3 57 Cab
Is the 59hp yt359 really a cat 1 hitch?
It痴 on my list of top three tractors, and one of the implements I plan on using most is cat II only.
If I can稚 get that implement, then I may as well downgrade to a 50hp tractor and save on some implements.
Thanks,
   / Yt359 cat I hitch? #2
Itç—´ on my list of top three tractors, and one of the implements I plan on using most is cat II only.
Thanks,
it is category 1
   / Yt359 cat I hitch? #4
How can Implement be cat 2 only? Can you specify?
   / Yt359 cat I hitch? #6
The main difference between a cat 1 and a cat 2 is the PIN size. The pin holes for the three-point on cat 1 are smaller than cat 2. You cannot fit the larger pin of a cat 2 into the smaller ball ends of a cat 1 tractor. However, you CAN fit the smaller pin of the Cat 1 into the Cat 2 implement mounting holes. You'll use bushings in the holes of the Cat 2 implement so that the smaller Cat 1 pins aren't "loose" when you mount the flail.
So... Yes, you can certainly use that Cat 2 flail on a Cat 1 tractor.
However, your issue might come down to HP. I run a 90" Ford 918h flail on my Massey 1652. I "might" be able to run a 96" flail, but this size tractor is better suited to 7'ish feet instead of 8'ish feet of width.
If you're going to be doing a lot of mowing with that flail, I would recommend you step up to the next size machine.
   / Yt359 cat I hitch? #7
So... Yes, you can certainly use that Cat 2 flail on a Cat 1 tractor.:confused3: You can use Cat 1 on a Cat 2 NOT Cat 2 on Cat 1
   / Yt359 cat I hitch? #8
raybender, really like that Yanmar tractor, did you buy in Geneva? Easily convert CAT2 implement to CAT1 lower links w/ reducer bushing.
EDIT: My error, reversed the scenario. Mea Culpa. Fortunate to be in the company of infallible and graciously perfect folks.
   / Yt359 cat I hitch? #9
You can NOT mount category 2 implements on a category 1 tractor. Unless the pins on the category 2 implements can be changed to category 1 pins.
But you can mount category 1 implements on a category 2 tractor, with the use of bushings.
   / Yt359 cat I hitch? #10
raybender, really like that Yanmar tractor, did you buy in Geneva? Easily convert CAT2 implement to CAT1 lower links w/ reducer bushing. I do it frequently.
How do you put a smaller bushing on a bigger diameter pin :confused3: CAT 2 WILL work on CAT 1 with a bushing BUT Cat 2 WILL NEVER FIT IN A CAT 1 LOWER ARM
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
