Hitch and pin configuration
/ Hitch and pin configuration #1
mongobird
Ford 1510
I have a Ford 1510, with a three point hitch, and a core plug aerator similar to a DLA60. For coupling with the lower arms of the hitch, there are three tabs, which accept a pin through them. Holes in the tabs are a bit over 1", 1", and on the outside most tab 1 1/8"
Can anyone tell me what style and size of pin I might use to link to the lift arms?
I have seen similar mounts on newer and heavier implements, but do not know what that style is called. Thanks.
/ Hitch and pin configuration #2
That sounds like a category 2 size. It should be 1 1/8” pins on the lift arms (side/bottom arms) and a 1” pin on the top link. Are the tabs with the holes that you are talking about on the implement or the tractor?
/ Hitch and pin configuration #3
If your unit is similar to the one that comes up on a search, then it is set up for 2 different categories of 3 point.
Such as one or two, the outer ears being cat 2 and the inner ears being cat 1, usually they use a long stepped pin that is a cat 1, 2. Also the top link bracket is set similar the upper mount being cat 2 and the lower cat 1.
Such as this one
The top link has two holes. The smaller one on the bottom takes a 7/8" pin which is what my top links have.
Such as this one
So this might be it! It looks similar to what I can kind of see in the product pictures for similar implements.
Do you have a pert # or source? I can probably use something similar, but these will keep the holes from pounding out as much.
