Chimney Fire - Is it Possible with a Selaed Insert?
/ Chimney Fire - Is it Possible with a Selaed Insert? #21
For some reason my flue does not build up much but I do get a build up on the bottom (inside) of the flue cap. Have not figured that out yet.
Most likely you have one of the newer gassifier type stoves, they are extremely clean burning and produce very little creosote because they recirculate the smoke/gases and reburn them. But I've found the same thing....the problem area is the top cap. It only seems to happen in really cold (for here) weather...like teens and below. My theory is that cap is ice cold, and the only place for whatever is left in the exhaust to condense. Ours builds up to the point it shuts off the draw of the flue, and I know when to hit the roof because we start getting a smoke smell in the house.
/ Chimney Fire - Is it Possible with a Selaed Insert? #22
No exp. with chimney fires as I keep it fairly clean, but what does a guy do if he has one and throws some suppression material in it. I really doubt it will knock all the flames out so how would a guy deal with hot burning logs at that time. Just leave it and hope it all goes out then take care of it???
I've never had to use mine, but I understand that it will create enough CO2 to smother the chimney fire and cool down the stove fire. To ignite the creosote you generally have to be hotter than a moderate stove fire. You are supposed to throw in the suppressant, close the air intake damper and keep the stove closed.
/ Chimney Fire - Is it Possible with a Selaed Insert? #23
I've never had a chimney fire with the 3 fireplace stove inserts at my house. I do keep a chimfex and other bottle type extinguishers on each level of the house to cover any type fire. I had a SS liner inserted into the chimney which consisted of several sections screwed together and it went directly into the top of the various wood stove fireplace inserts we've had over the last 30 years. AND, a crucial point, the chimney is a prefab unit, and where the flue exited above the roofline on the gable peak, the dual flue outlets, one for oil furnace, one for wood stove, were separate. The furnace had a metalbestos flue, the wood stove insert had the SS, which terminated, and was sealed at the metal top of the chimney stack. The prefab chimney stack was cased in vertical wood planking and the top of the entire unit had a fabricated metal flashing to keep water and wind from getting down the two flues.
Caution if sealing SS pipe at joints with caulk, only use caulk that is fire rated to withstand high temps. It is usually red in color, and is meant to be used for sealing places where a fire could go from one floor to a higher floor via electrical penetrations where there is conduit, etc. Also designed to seal flue sections - see link below; and their website has numerous tabs to select info on other hearth care and solutions.
Also note that sealing the insert stack keeps unwanted cold air out and keeps lethal gases of combustion contained so they can only exit via the top of the insert to atmosphere.
I would definitely also use heavy duty metal pipe tape to further seal any air or gases from escaping the insert where they could leak into the house.
Rutland products: https://www.rutland.com/p/3/500-degree-f-rtv-high-heat-silicone-sealant
BTW, I would have the stacks checked annually, and I burned hot fires, 850-900 degrees, and had a fire temp gauge in the stack, AND on the stove surface to monitor the situation. The wood stove SS stack/insert NEVER showed any amount of creosote and only ever needed a light brushing with a chimney sweep brush.
Trust me, the extra expense is well worth the added peace of mind for you and your family, friends using your house/cabin. Chimney fires are preventable, so do what makes sence and learn from other's experience. A chimney fire is something that kills way to many people/families when it could have been prevented in most cases.....
/ Chimney Fire - Is it Possible with a Selaed Insert? #24
At the house my dad built in the mountains, he had a huge masonry/stone fireplace built by local craftsmen with about 30 ft. of conventional masonry flue liner up to his a-frame roof line. And he wasn't really aware of how chimney fires happen. A few years in, he had a MASSIVE chimney fire one night, with flaming chunks of creosote being carried high above the flue and landing on his composite shingle roof. Fortunately, he heard the characteristic sound of the fire and played a garden hose on the roof and the flaming chunks. Saved the house. Scary stuff.
I'm not sure if he ever had the flue checked for cracks after the event, but I bet they are cracked now.
/ Chimney Fire - Is it Possible with a Selaed Insert? #25
Well - in my one and only experience with a chimney fire. I had very heavy duty gauntleted leather gloves. When things sort of calmed down - a lot of the smoke had cleared out of the cabin - before the smoldering wood caught on fire again - I reached in and grabbed the logs - one in each hand and threw them off the porch - out into the snow. As I remember it took three trips.
A wee bit off topic, but, I have a pair of long-gauntlet welding gloves by the wood-heater and use them to add wood with them.
One 'slip' (naturally at 3 a.m.) gave me a nasty wrist burn... never again!
/ Chimney Fire - Is it Possible with a Selaed Insert? #26
This is a good idea ^^
/ Chimney Fire - Is it Possible with a Selaed Insert? #27
Correct, I have a secondary air burn and cat. My temps are not as cold as yours and my buildup on the cap is not enough to block the exhaust but still it is there. Worst thing is it drips on the masonary chimney cap (flue liner in masonary chimney) and stains. I am thinking of buying a second cap and swapping it out so I can clean one on the ground good and then just swap them out. Speaking of caps curious how many have a screen on them?
/ Chimney Fire - Is it Possible with a Selaed Insert? #28
Funny thing is the screen on mine is fairly large mesh opening....more to keep birds out than to arrest sparks. Diamond mesh that is like 3/4" at the wide point....but it still clogs up. I was thinking of making it taller, it's only about 4-5" tall on the mesh part....was thinking that much again, and it would have a hard time clogging up that much....maybe. My roof is really tall, and steep pitch....don't enjoy walking the ridge line !
/ Chimney Fire - Is it Possible with a Selaed Insert? #29
In some areas a screen is mandatory as a 'spark arrester'.
Sparks do fly and are known to start forest fires.
Same applies to exhausts on chain saws and ATV's.
/ Chimney Fire - Is it Possible with a Selaed Insert? #31
Baking Soda. We used to put it in a plastic bag (1 gallon size; about 3 or 4 cups of baking soda). Drop it down the chimney and when it gets to the hot spot, it bursts open and the baking soda puts out the fire. Sometimes took 2 or 3 tries to put out a big one. Someone told me that baking soda is the primary ingredient in dry chemical fire extinguishers. You could also just throw the bag into the woodstove.
/ Chimney Fire - Is it Possible with a Selaed Insert? #32
Yeah, I assumed it was a tight, small mesh screen the first time it happened, but when I got up there, found it wasn't
/ Chimney Fire - Is it Possible with a Selaed Insert? #33
I have a problem with little birds sneaking into the FP. Tried a medium screen but plugged up in a couple weeks and lost draft so I got rid of the screen. Steep roof and looking for answer too..
/ Chimney Fire - Is it Possible with a Selaed Insert? #34
1st; get a suitable harness and attachment system to be on your roof/ridge safely. Next buy a round or square or whatever shape your flue outlet size is cap with SS screen already built in. That should solve both issues.
/ Chimney Fire - Is it Possible with a Selaed Insert? #35
1st; rent a manlift. Next buy a round or square or whatever shape your flue outlet size is cap with SS screen already built in. That should solve both issues.
FTFY... A towed 35' manlift is $160/day around here and makes life MUCH easier.
Aaron Z
/ Chimney Fire - Is it Possible with a Selaed Insert? #36
One would think that. I have a round 6" pipe with cap. An option is for stainless screen to insert it. I had some same size galvanized screen so I tried that because of cost. Didn't work. Plugged up very fast. Burned Dry wood and hot fires. I am thinking as the smoke cools it accumulates. I took the screen out and will try to find a larger screen.
On 10/12 metal roof at peak so everything needs to be planned out well before I make a move. I installed a bracket on the roof to hook an extension ladder half to reach the thing comfortably and safely. Ext ladder to get on first level roof then another ladder to scale the long steep metal section. I just need to find a bigger screen than what the pipe company suggests and offers.
/ Chimney Fire - Is it Possible with a Selaed Insert? #37
Know a feller that uses a pellet gun to unclog the spark screen.
/ Chimney Fire - Is it Possible with a Selaed Insert? #38
Yeah...10/12 here as well. Shingle roof, but kinda high on the lower side. I usually walk up the valley intersection of the garage, the walk the ridge line back to the chimney.
Wife won't watch.... :D
enhance
/ Chimney Fire - Is it Possible with a Selaed Insert? #39
Aaron Z
For some maybe; A harness and rope setup will accomodate most any roof, and is a one time buy with countless future uses; a manlift may not be able to access the area, as in my case where the gable end is adjacent to a 2 bay garage, limiting access to the chimney altogether. And $160/day may be reasonable once but not 2x/year, every year, IMO.
On 10/12 metal roof at peak so everything needs to be planned out well before I make a move. I installed a bracket on the roof to hook an extension ladder half to reach the thing comfortably and safely. Ext ladder to get on first level roof then another ladder to scale the long steep metal section. I just need to find a bigger screen than what the pipe company suggests and offers.[/Q
Chimney Liners | WoodlandDirect.com: Chimney Liner Parts, Rigid Chimney Liner, Aluminum Chimney Liner Kits-Woodlanddirect.com is just one store that offers every possible solution to chimney lining. Note that any chimney liner should have an insulation wrap installed around its entire length to keep the SS liner consistently warm from top to bottom, and to protect the surface of the original chimney materials from becoming too hot. Also offered is a powdered mix that hardens after being poured between the exterior of a SS liner and the original flue material. This mix is easily used when there is low clearance between liner and flue. Caps with and without screens and high wind type caps are also offered.
BTW, I have a long length of screw together 6" dia. SS liner, in addition to a flexible section of SS, and some Metalbestos sections, both from when I retrofitted my chimney and went to gas insert fireplaces. They are for sale, also a Jotul woodstove and a (not sure of brand) wood fireplace insert that were removed from my main house and my flip property, when the renovations to gas heat were implemented. If interested send me a PM to find out more.
Thanks,
CM
/ Chimney Fire - Is it Possible with a Selaed Insert? #40
I'm not doubting your wood is dry, but i had similar problem with some oak i had harvested from a friend of mine. I thought it was pretty dry after a couple years in the wood shed, but i was having problems with my screen plugging up. Somebody on TBN said it might seem dry, but the results are the proof. So i tried again on the third year, and haven't had problems with the screen plugging up. It's much more humid on this side of Washington state then the east side that i was familiar with when burning wood. The softwoods like fir or pine dry pretty well after a year in the wood shed, but that oak was so much denser then our usually firewood. I burn some cherry, alder and maples, which are denser and take a little longer to dry then the fir and pine. Love the oak though.
