SSQA Hitch Ripper
/ SSQA Hitch Ripper #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
Has anyone tried one of these:
Titan Hitch Mounted Ripper
I have an SSQA to 3 pt adapter plate for my FEL with an attached 2" receiver. I'd like to use this hitch ripper to rip roots and loose red shale. At $48, It looks well made and is a lot cheaper than a ripper tooth for my BH. I realize most FEL's are designed to push, not pull but I've been back dragging heavy material with a bucket for years without a problem. The tooth is centered between the FEL arms so there is no side load. I suppose the ripper could be reversed to rip going forward as well
It might be worth an experiment. Any thoughts?
/ SSQA Hitch Ripper #2
Wow, thanks for sharing. That could be a great solution for me on getting up some small tree roots. Hopefully somebody that has used one will be able to chime in.
/ SSQA Hitch Ripper #3
I personally would feel much more comfortable pulling that with the 3pt hitch. I know buying a 3pt receiver adapter would add to the cost, but it might be cheaper in the long run.
/ SSQA Hitch Ripper
I also have a 3 pt hitch adapter and using the ripper there is always an option. I agree that a tractor is designed to pull but there is no down force on a 3 pt hitch. Using it on the FEL allows you to put some of the weight of the tractor on the ripper tooth. The angle of the tooth relative to the ground can also be adjusted using the FEL curl.
/ SSQA Hitch Ripper #5
Buy a simple 3-point sub spoiler. IMHO I think you’ll have a chance to damage your FEL doing it the way you suggested.
/ SSQA Hitch Ripper #6
I have used a subsoiler with cable burying attachment, the shank/subsoiler will pull itself into the ground with ease. I would not worry about down force.
/ SSQA Hitch Ripper #7
While you probably don't need downforce due to the tooth angle, if you have a weight box (I have the Titan model!) you can add a receiver and then the weight box will "power down" that ripper. The Titan box already has one.
But I also have a stand-alone sub-soiler, and it dives for the center of the earth, no problem! It only weighs 100 pounds or so.
/ SSQA Hitch Ripper #8
/ SSQA Hitch Ripper #9
/ SSQA Hitch Ripper #10
Yes to the pipe layer piece (although at the time it was back ordered and took months), but I got the sub soiler from northern, on sale for around 100$. Used it to lay 'rigid' 3/4" pvc electrical conduit
How deep could you get your conduit?
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
UNUSED X-STAR 101"x20' LOADING RAMP (A64280)
UNUSED X-STAR...
2004 John Deere 4720 (A60462)
2004 John Deere...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
2013 Hagie STS 12 Sprayer (A63111)
2013 Hagie STS 12...
2016 Tradewinds TG45-UL 45kW Natural Gas Generator (A61572)
2016 Tradewinds...
