Finally building my storage shed.
/ Finally building my storage shed. #22
Never been to neck of the woods but my parents vacationed there and had a great time... they were bumped off a flight and got a anywhere airline pass and Dad said let's go somewhere we have never been and Slave Lake was it... they met a lot of very nice folks.
/ Finally building my storage shed. #23
Nice work. I missed your location. I saw the wood plant in the background and thought, "Florida?" AND then the next picture with snow appears....
/ Finally building my storage shed. #24
I've been following this thread. My question is in regards to the trusses. Were those engineered units or were they something you designed yourself?
Well I was really hoping to at least get the sheeting and tyvek on but winter haul is going full bore so I guess this project is on hold until next year now. I haven't had a day where I was done work before dark yet but this is how it stands now. IMG_4513.JPG
/ Finally building my storage shed. #27
Neat picture with the snow and the lights. Will the snow affect the OSB on the walls?
/ Finally building my storage shed. #28
Nice project. Night photo makes it look ... cold!
Did you choose a tin roof because of durability, light weight, or ???. I have a garage on my property built long ago from wood milled at the property. Trusses were not engineered as it was a .... no permits required ... type of job.
I've been thinking about sheeting it with OSB and putting a composition roof on, but I don't want to put more weight than it can handle. I don't know how to figure out what weight is appropriate. Except the tin must be much lighter.
/ Finally building my storage shed. #29
Metal roofs are much lighter than composition. My homeowners insurance company also prefers metal for better wild fire protection and fewer wind damage claims.
/ Finally building my storage shed. #30
What is the spacing of your trusses and how steep is your pitch? One of the advantages to metal over shingles is that you can space your trusses out a lot farther. Shingles need trusses 24 inches on center, or closer. I personally space my trusses out 4 feet and then use 2x4's on the flat for purlins across the trusses so I have an easy target to screw the metal down. Pitch is how steep the roof is. For metal, you can get away with 2:12 without any issues, but for shingles, you should never be less then 4:12
/ Finally building my storage shed. #31
The pitch is pretty steep. Looks like 12:12 maybe. Whatever it is, much more than 4:12. But, I just checked and the rafters are 4' spacing.
/ Finally building my storage shed. #32
I seem to have trouble with metal roofs... just could be my size isn't a good match plus they sure get slippery in the Pacific Northwest.
So far a quality comp has been the best for me all around... I always use 30# felt and double coverage... my first complete roof done by me was in 1982 and not a single issue... 35 years now and these were bargain shingles at the time...
/ Finally building my storage shed. #33
I was considering a metal roof here in the Pac NW on my house but the roofers quoting the work talked me into a 30 year composite. Said too much moisture forms underneath.
/ Finally building my storage shed. #34
My tin roof keeps getting punctured from falling branches. I have numerous leaks to fix with buckets underneath. It's steep, slippery, and probably has large numbers of exposed screws to slide across if I ever lose traction. Doesn't sound like a fun repair project ...
Due to their size, I have to hire out tree trimming, which is expensive. I keep trimming the centuries-old oaks nearby but they keep dropping branches anyway.
/ Finally building my storage shed. #35
The pole barn room is metal and has a few "Punctures" from trees dropping things in windstorms.
/ Finally building my storage shed. #36
I've been trying to be Firewise and am constructing defensible space around my house and outbuildings. Wildfires are about the only thing that scares me. All my trees are at least 20-50 feet away from our buildings. Nothing is going to fall on the roofs and puncture the metal. When I remember how to estimate the height of the trees, I may increase the distance.
/ Finally building my storage shed. #37
"you should never be less than 4:12 "..... is not quite correct.
Manufacturers recommend not less than 4:12, for shingles, but....
WILL warranty a shingled roof down to, and including, 2:12 pitch, if Ice & Water Shield is used.
/ Finally building my storage shed. #38
I would need some major logging to get 50 foot clearance between my tin roof and trees ..... the building is 24x36.
/ Finally building my storage shed. #39
Awesome trees! As much as I love trees, those would be far to close for me. With wind, disease and the possibility of wildfire, I wouldn't be able to sleep at night.
It will be fine. I wanted to get the tyvek on to protect it from water but it will be ok till spring. There is 24" of eve so it does pretty good.
2018 Ford Focus (A61574)
2018 Ford Focus...
KUBOTA BT1973 - 17 1/2" EXCAVATOR BUCKET (A64280)
KUBOTA BT1973 - 17...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
Reynolds 18CR (A64119)
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A61572)
2017 Wacker Neuson...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
