Now what's wronmg with my Robin engine?
   / Now what's wronmg with my Robin engine?
Re: Now what's wrong with my Robin engine?
That'sa big difference! I wonder how it will start when the temps start dropping?
Time will tell. I am about to order the Katz's hot pad to be on the safe side. The Mrs tells me we are in for a cold snowy winter(I hope she's wrong)!
   / Now what's wronmg with my Robin engine? #43
If they can read the voltage that is probably a good test. Better than I can do. Running on one cylinder is pretty good test. Thanks for the info. Very interesting.
   / Now what's wronmg with my Robin engine? #44
Check coil resistance with an ohmeter. Primary .5 to 1.5 ohms, secondary 7 to 15K ohms.
   / Now what's wronmg with my Robin engine? #45
That is a test, but it only applies a very low voltage. It is much more accurate to test at thousands of volts. They can behave very differently at different voltages. If there is a breakdown in the insulation if may not show up at a few volts, and yet disable the coil at a few thousands. Yes the Ohm meter can find some failures, but not all. I had a coil that created a good spark while cranking, but failed in a few seconds of running. It can also behave erratically. The best test is usually to test in operation, comparing a known good device to the suspect device.
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
