Now what's wronmg with my Robin engine?
   / Now what's wronmg with my Robin engine?
Re: Now what's wrong with my Robin engine?
That'sa big difference! I wonder how it will start when the temps start dropping?
Time will tell. I am about to order the Katz's hot pad to be on the safe side. The Mrs tells me we are in for a cold snowy winter(I hope she's wrong)!
   / Now what's wronmg with my Robin engine? #43
If they can read the voltage that is probably a good test. Better than I can do. Running on one cylinder is pretty good test. Thanks for the info. Very interesting.
   / Now what's wronmg with my Robin engine? #44
Check coil resistance with an ohmeter. Primary .5 to 1.5 ohms, secondary 7 to 15K ohms.
   / Now what's wronmg with my Robin engine? #45
That is a test, but it only applies a very low voltage. It is much more accurate to test at thousands of volts. They can behave very differently at different voltages. If there is a breakdown in the insulation if may not show up at a few volts, and yet disable the coil at a few thousands. Yes the Ohm meter can find some failures, but not all. I had a coil that created a good spark while cranking, but failed in a few seconds of running. It can also behave erratically. The best test is usually to test in operation, comparing a known good device to the suspect device.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
