Cannot keep the 422 running
/ Cannot keep the 422 running #1
MuncyBob
Platinum Member
N Central PA
PT 422
Last time I cut the grass it was very hot and at the end of the job(1 hour) the 422 just stalled out. Started right up and ran a bit and stalled again, figured it was so hot that after an hour it vapor locked. But today I'm getting the same thing and it's very cool and the engine is cold too. It does start right up again but won't run for long.
A friend said may be the gas cap. I have blown it out with the compressor and just as somebody else previously posted, I drilled the small vent hole just a bit bigger...makes no difference. Could it still be the cap or something else?
/ Cannot keep the 422 running #2
Id start with simple first, fuel filter, plugged fuel line or dirt in the tank. Disconnect the fuel line from the carb and disconnect spark plugs, crank the engine, see if you have good fuel flow, if not work backwards from there.
I had already looked into the tank but I must have missed it....earlier this year I pulled the cap flange out to clean it good and reseal. Recalling this is probably what told me to get a good strong flashlight and look into the tank again. I was pretty sure I could see the culprit at the bottom near the exit hole. After draining the tank and holding it up to the sun I could easily see a small bit of the caulk I used that was causing the problem. A cheap and not so hard fix...I wish life had more of those!
/ Cannot keep the 422 running #5
Also check your air filter.
Well, it ran for several minutes in the garage so thinking I had it licked I filled up and went to cut the grass. Only got about 100'....back to the drawing board.
/ Cannot keep the 422 running #7
A easy way to run out a fuel issue is to take a can of WD 40, have air filter open and with the engine wanting to stop, shoot short bursts into the air intake. Your engine will run fine on WD 40, works with gas or diesel engine. If it is fuel issue you can keep it running by shooting short burst of WD 40 if it will not run like that it is not a fuel issue.
If it's a vented cap issue, would the engine run w/o the cap on the tank?
/ Cannot keep the 422 running #9
Yes, but I would only unscrew the cap a turn or so, and I wouldn't move the tractor. I would be too worried about setting something on fire. Since you already drilled out the cap, I doubt that is your issue.
How old is your gas? If it is older, I might also suspect bad gas.
Based on other's experience, I would guess that you still have some foreign material in the gas line or carburetor. The easy bit is probably blowing out the fuel line, again. Then it gets interesting. Which engine do you have in your 422 and what kind of fuel pump do you have?
Good luck,
Peter
/ Cannot keep the 422 running #10
A less painful way of looking at throwing parts at it is sometimes the engine is ready for new filters, plugs, ignition coils, etc. anyway.
You aren't hurting yourself by cleaning the fuel system, changing the fuel filter, spark plug and trying new gas.
Could also be failing ignition coil or valves need adjusting.
Is there an hour meter on the engine?
Well, in hindsight I should have pulled the elbow fitting from the bottom of the tank yesterday because there was further debris in there. I was so sure the visible crud in the tank was the only problem. It's all good now.........Moss, que the songbirds and sunshine :)
/ Cannot keep the 422 running #12
You aren't the first, or I am sure, the last person to have that issue.
I am glad it is fixed!
All the best, Peter
/ Cannot keep the 422 running #14
I've been surprised at the amount of crud that I find in this fuel funnel filter after refilling my ZTR. I also use it to filter my diesel, too.
Amazon.com
/ Cannot keep the 422 running #15
I realize this thread is solved. However, a stuck fuel cutoff solenoid on the carburetor will also cause this problem, for any future troubleshooters. It lets just enough fuel in to start and run, but not enough to keep running.
I found this problem on one of my machines, even though I put in a lot of fuel conditioner at the end of the season. I had a spare carb laying around and the solenoid was stuck on that carb too. Easy to take off and clean the ethanol varnish out.
To diagnose, put your finger on the solenoid and turn the key on. You can feel (and usually hear) it retract from the main jet.
As of this year, I've finally thrown in the towel and only run ethanol-free gasoline. Costs about $1.50 more per gallon but I've wasted way too much time over the years with carb cleaning.
/ Cannot keep the 422 running #16
Honest to goodness, I've been running E10 since the 80's in everything I own. Vehicles, motorcycles, lawn equipment, IH2500B, and PT425.
I've had one carb issue on a 1970 Nova 1 barrel, way before E10. I had a weed eater I replaced the carb on for $15. That's it.
Every time I've thought it was a carb issue, it was something else. Fuel pump. Fuel filter. Fuel pickup in tank. Stuck/bad choke. Fuel solenoid. Fuel line. But never carb.
Of course, now one will fail tomorrow. 🙃
/ Cannot keep the 422 running #17
I think emission regulations forced carb changes, making them more sensitive to contamination. I have three Honda engines and ALL run rough (surging at idle). I've cleaned those carbs so many times that I just ignore it.
On some engines, a little extra choke helps them to run better. I cranked a Yamaha engine on a generator recently, and it wouldn't idle without cracking the choke open a bit. That engine has fuel treatment, and the carb was cleaned two years ago to fix same problem (which it did). But the generator sits unused for long periods.
I have a Chinese engine on a plate compactor that always starts, even with old gas. My dad has a Merry tiller that's the same. But it's 50 years old.
In my experience, carburetors on newer machines from reputable engine manufacturers (that are designed to meet emissions standards over the life of the engine) are very sensitive.
Since switching to e-free gas my 422 runs better, seems to use a bit less fuel than before and shuts down w/o a backfire...which previously happened a lot unless I let it run on low idle for at least 30 seconds before shutting down. Once when getting a refill a Mercedes owner told me that he only runs e-free in his car and said he gets better mileage. I thought to myself, you better for what it costs!
/ Cannot keep the 422 running #19
That's good news.
There is a slight difference in energy between Dino oil gasoline and E10. It is not a lot and may be up to 4% in energy. That arises because ethanol is about 76,000BTU/gal, and Dino oil is closer to 120,000BTU/gal, though it can be lower depending on the feedstock and refinery. However, ethanol has a higher ignition point and a higher flash point both of which tend to lower knocks.
https://afdc.energy.gov/files/u/publication/fuel_comparison_chart.pdf (the last lines on the first page are the ones covering energy) The higher energy per gallon (or per unit weight) is one reason why long haul truckers prefer diesel. More energy per gallon translate to greater range for the same weight on board.
FWIW: Many areas switch between higher volatility gasoline for winter use and lower volatility gasoline for summer. So you can get "performance hangovers" for using a winter fuel fuel in summer and vice versa if you use out of season fuel. Summer fuel is hard to start in the winter time and winter fuel is prone to knocking and backfires when used in the summertime. It is not usually a big effect, but can be especially noticeable on some engines, especially on smaller non-vehicle engines that don't have ECU computers with preignition sensors, aka knock sensors.
Fuel can be a constant challenge.
All the best,
Peter
2015 Ford F-450 Knapheide Service Truck (A66736)
2015 Ford F-450...
Unused 2026 CID SNLB84-S 84in. Snow/Ice Skid Steer Bucket Attachment (A66734)
Unused 2026 CID...
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2021 JOHN DEERE 333G SKID STEER (A65056)
2021 JOHN DEERE...
