Now what's wronmg with my Robin engine?
/ Now what's wronmg with my Robin engine?
Re: Now what's wrong with my Robin engine?
That'sa big difference! I wonder how it will start when the temps start dropping?
Time will tell. I am about to order the Katz's hot pad to be on the safe side. The Mrs tells me we are in for a cold snowy winter(I hope she's wrong)!
/ Now what's wronmg with my Robin engine? #43
If they can read the voltage that is probably a good test. Better than I can do. Running on one cylinder is pretty good test. Thanks for the info. Very interesting.
/ Now what's wronmg with my Robin engine? #44
Check coil resistance with an ohmeter. Primary .5 to 1.5 ohms, secondary 7 to 15K ohms.
/ Now what's wronmg with my Robin engine? #45
That is a test, but it only applies a very low voltage. It is much more accurate to test at thousands of volts. They can behave very differently at different voltages. If there is a breakdown in the insulation if may not show up at a few volts, and yet disable the coil at a few thousands. Yes the Ohm meter can find some failures, but not all. I had a coil that created a good spark while cranking, but failed in a few seconds of running. It can also behave erratically. The best test is usually to test in operation, comparing a known good device to the suspect device.
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
Adams 5 T Fertilizer Spreader (A61307)
Adams 5 T...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2019 CATERPILLAR 938M WHEEL LOADER (A60429)
2019 CATERPILLAR...
