Now what's wronmg with my Robin engine?
   / Now what's wronmg with my Robin engine?
Re: Now what's wrong with my Robin engine?
That'sa big difference! I wonder how it will start when the temps start dropping?
Time will tell. I am about to order the Katz's hot pad to be on the safe side. The Mrs tells me we are in for a cold snowy winter(I hope she's wrong)!
   / Now what's wronmg with my Robin engine? #43
If they can read the voltage that is probably a good test. Better than I can do. Running on one cylinder is pretty good test. Thanks for the info. Very interesting.
   / Now what's wronmg with my Robin engine? #44
Check coil resistance with an ohmeter. Primary .5 to 1.5 ohms, secondary 7 to 15K ohms.
   / Now what's wronmg with my Robin engine? #45
That is a test, but it only applies a very low voltage. It is much more accurate to test at thousands of volts. They can behave very differently at different voltages. If there is a breakdown in the insulation if may not show up at a few volts, and yet disable the coil at a few thousands. Yes the Ohm meter can find some failures, but not all. I had a coil that created a good spark while cranking, but failed in a few seconds of running. It can also behave erratically. The best test is usually to test in operation, comparing a known good device to the suspect device.
CAT Chassis Only (A59076)
CAT Chassis Only...
2004 Komatsu HM400-1 (A60462)
2004 Komatsu...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2011 Ford Escape SUV (A59231)
2011 Ford Escape...
2021 CATERPILLAR 299D3 XE SKID STEER (A60429)
2021 CATERPILLAR...
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
