B7500 cracked engine block
/ B7500 cracked engine block #1
Tomtint
Elite Member
Boston
L3700SU
My sister owns a B7500.. I'm guessing a 2003-2005 era model. Well... They have not taken great care of it and at some point in the past, filled the radiator with water and not antifreeze. .. This past winter a freeze plug popped and I assumed it was just the plug. They replaced it but when they filled the coolant again..... It filled the crank case. ... Engine is all done. Any idea what a short block runs for one of those ?
Yes, that is the one she has.
/ B7500 cracked engine block #4
There is a complete engine on ebay for $1600 in PA. I'd think hard about buying something like that.
I not 100% sure I'm even going to get involved in the engine swap myself. I need to take a look at the thing and see how much is involved in a short block swap out. Last thing I want is to get it apart and screw something up installing the new one. .. Thinking its a trip to the dealer.
/ B7500 cracked engine block #7
If you work on it and screw it up, you own it for life. I would not make eye contact on a job like that other than maybe transport it for someone.
Lol..ain't that the truth.
/ B7500 cracked engine block #9
What a sad story. Having owned a B7500 in the past, it hurts me to think someone was so careless to destroy such a nice little tractor.
It was very careless for certain.
/ B7500 cracked engine block #11
I'd check to see if the block can be brazed... We have done it in the past on tractor blocks...
SR
/ B7500 cracked engine block #12
SR
+1. If that doesn't work this is likely a parts donor tractor unless they have tons of money to spend. The other option is to find a used engine, but locally used tractor parts are practically nonexistent. I hope you have better luck.
/ B7500 cracked engine block #13
I've had great luck with the bottles of sealant for blown head gaskets. Two vehicles had leaks that were so bad that I was sure being talked into using the sealer was just a waste of time and money. Years later, both are still going strong after having to redo the treatment after flushing the cooling systems during repairs.
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2008 MACK CHU613 (INOPERABLE) (A67714)
2008 MACK CHU613...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
