B7500 cracked engine block
/ B7500 cracked engine block #1
Tomtint
Elite Member
Boston
L3700SU
My sister owns a B7500.. I'm guessing a 2003-2005 era model. Well... They have not taken great care of it and at some point in the past, filled the radiator with water and not antifreeze. .. This past winter a freeze plug popped and I assumed it was just the plug. They replaced it but when they filled the coolant again..... It filled the crank case. ... Engine is all done. Any idea what a short block runs for one of those ?
Yes, that is the one she has.
/ B7500 cracked engine block #4
There is a complete engine on ebay for $1600 in PA. I'd think hard about buying something like that.
I not 100% sure I'm even going to get involved in the engine swap myself. I need to take a look at the thing and see how much is involved in a short block swap out. Last thing I want is to get it apart and screw something up installing the new one. .. Thinking its a trip to the dealer.
/ B7500 cracked engine block #7
If you work on it and screw it up, you own it for life. I would not make eye contact on a job like that other than maybe transport it for someone.
Lol..ain't that the truth.
/ B7500 cracked engine block #9
What a sad story. Having owned a B7500 in the past, it hurts me to think someone was so careless to destroy such a nice little tractor.
It was very careless for certain.
/ B7500 cracked engine block #11
I'd check to see if the block can be brazed... We have done it in the past on tractor blocks...
SR
/ B7500 cracked engine block #12
SR
+1. If that doesn't work this is likely a parts donor tractor unless they have tons of money to spend. The other option is to find a used engine, but locally used tractor parts are practically nonexistent. I hope you have better luck.
/ B7500 cracked engine block #13
I've had great luck with the bottles of sealant for blown head gaskets. Two vehicles had leaks that were so bad that I was sure being talked into using the sealer was just a waste of time and money. Years later, both are still going strong after having to redo the treatment after flushing the cooling systems during repairs.
2025 Wolverine ADB-13-1218R Hydraulic Auger Set Attachment (A66734)
2025 Wolverine...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
2016 Toyota Camry Sedan (A66738)
2016 Toyota Camry...
Unused HLA BRB84 84in. Hydraulic Rotary Pick-UP Broom Skid Steer Attachment (A66734)
Unused HLA BRB84...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
