Thinking of a solar back up for well pump
/ Thinking of a solar back up for well pump
I get the point, but all the references I see show 8 amps for 1hp at 230v, not 15. That is FL amps not LR. I'm sure LR is in the range of 30-35.
/ Thinking of a solar back up for well pump #32
My bad I didn't see this post before my post above. We must have been typing at the same time. I can draw up something and post it if that would help. It's hard to just type it out.
/ Thinking of a solar back up for well pump #33
That is still 20+ times the power of the rv pump. Why make this overly complicated?
Well just had dinner with some friends, one is a farmer with lots of solar. He told me how it can work combining the meters or getting an aggregate billing either way. I also spoke to my son (the solar salesman) about adding a few more panels to absorb both loads and he thinks it's doable.
So I may well end up with a totally self sustaining system. Will probably have to add 3-4 more panels, but that will only be $3-4K and still a lot less than my original idea would have probably cost. Plus I get a tax credit on the additional panels, since the Fed credit is 30% of the total system cost.
My son informed me cost to install will be a lot less than he estimated so the battery will be more like $5500 installed and not 7K. Am expecting a $5500 rebate on that from local power company.
Will most likely sign final contract in next day or two. Thanks to all for letting me know my $1000 idea wasn't going to be nearly that cheap. Made the upgrade seem a lot more reasonable.
/ Thinking of a solar back up for well pump #35
It is good to hear you have received lower quotes for the upgrade. Combined with the rebates and tax incentives that may be a viable route to take.
Just keep in mind if the price goes up too much that you can get a rv pump set up with one spare in box, a 210 amp hour 12v agm 7 year battery and a charger with timer as I mentioned for less than $1,000. Good to know if the solar price winds up higher than expected.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
2015 Chrysler 200 Sedan (A59231)
2015 Chrysler 200...
2002 WACKER RD25 ROLLER (A59906)
2002 WACKER RD25...
2012 HEIL (A60736)
2012 HEIL (A60736)
2017 ADDCO ROAD SIGN DH100-ALS (A60736)
2017 ADDCO ROAD...
