Mowing Mowing a narrow sloped area
/ Mowing a narrow sloped area #1
gk527
Member
Kentucky
1974 Ford 3000 diesel / 2017 Kubota B2650
Looking for a way to easily mow this narrow slopes area between the driveway and fence. It's too steep to ride a tractor or any type of zero turn mower on it.
We have a 1974 Ford 3000 and my new Kubota B2650 will be here next week.
Suggestions? Thanks!!
/ Mowing a narrow sloped area #4
There will be boom mounted mowers for that type of situation. The cost may make them unaffordable.
/ Mowing a narrow sloped area #6
Just take your time w/sickle bar until you get the feel w/it.
/ Mowing a narrow sloped area #7
Doesn't look that large an area - how about a $75 Craigslist self-propelled traditional mower?
It's a pretty good area. It circles back up the driveway to the right.
/ Mowing a narrow sloped area #10
Some sickle bar mowers won't work on much of an angle. For angle cutting, avoid the ones with about a 2ft long wooden pitman arm operating the cutters.
Bruce
/ Mowing a narrow sloped area #11
I wouldn't mow it. If it gets mowed and looking nice like an extension of the yard, then the fence will be an eyesore. I think I would keep after it with 2-4-D and try to get a nice stand of knee high bromegrass going.
/ Mowing a narrow sloped area #13
I was getting the T shirts when I clicked the link. Some advertising outfit named viglink redirects to an ad page using javascript. I disabled javascript and now get the ebay page. I don't know what disabling it might have messed up yet though.
/ Mowing a narrow sloped area #14
The thing about a boom mounted flail is that you can use it on a ton of things OTHER than just this bank.
I've ordered an 86" boom mounted flail. I should be able to to use it as a regular flail behind my tractor, ditchbank both up and down. And pond edge.
I'm banking on the utility being worthwhile.
/ Mowing a narrow sloped area #16
If the links aren't working right, you can disable Viglink, just google how to do it.
/ Mowing a narrow sloped area #17
It doesn't look that steep to me. I've clipped steeper ditches with my 685 Case hooked to a JD 609 clipper. As long as I have roll over protection and a good seat belt.
/ Mowing a narrow sloped area #19
I had a Kubota zero turn that I mowed a side slope like that on my lane, they will slide before they tip but that's not too steep at all. There was a section that was too steep that I used a 15' batwing mower on with the tractor on the drive with the outside "wing" on the slope. Both are very expensive solutions if that's your only job for it.
