Mowing Mowing a narrow sloped area
   / Mowing a narrow sloped area #11
I wouldn't mow it. If it gets mowed and looking nice like an extension of the yard, then the fence will be an eyesore. I think I would keep after it with 2-4-D and try to get a nice stand of knee high bromegrass going.
   / Mowing a narrow sloped area #13
I was getting the T shirts when I clicked the link. Some advertising outfit named viglink redirects to an ad page using javascript. I disabled javascript and now get the ebay page. I don't know what disabling it might have messed up yet though.
   / Mowing a narrow sloped area #14
The thing about a boom mounted flail is that you can use it on a ton of things OTHER than just this bank.
I've ordered an 86" boom mounted flail. I should be able to to use it as a regular flail behind my tractor, ditchbank both up and down. And pond edge.
I'm banking on the utility being worthwhile.
   / Mowing a narrow sloped area #16
If the links aren't working right, you can disable Viglink, just google how to do it.
   / Mowing a narrow sloped area #17
It doesn't look that steep to me. I've clipped steeper ditches with my 685 Case hooked to a JD 609 clipper. As long as I have roll over protection and a good seat belt.
   / Mowing a narrow sloped area #18
   / Mowing a narrow sloped area #19
I had a Kubota zero turn that I mowed a side slope like that on my lane, they will slide before they tip but that's not too steep at all. There was a section that was too steep that I used a 15' batwing mower on with the tractor on the drive with the outside "wing" on the slope. Both are very expensive solutions if that's your only job for it.
John Deere 3025E (A53317)
John Deere 3025E...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A57880)
2001 WORKHORSE...
2002 Frieghtliner Pressure Digger (A55973)
2002 Frieghtliner...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
