Mowing on slopes maximum angle before tip
/ Mowing on slopes maximum angle before tip #61
Thanks for posting the video of the tractor fails.
I have some steep hills I bushhog. When I bought my Kioti ten years ago I knew the FEL would be a huge counterbalancing help going UP the hills. On the steep one I go up backwards as the video pointed out is safest. Someone in this threat pointed out keeping FEL's as low as possible can lower the overall CG of the tractor.
I also bought 4 inch wide aluminum spacers for my rear wheels. At 5:40 in the video widening a tractor's stance is discussed. I think the spacers make a big difference is sideways stability - and today they look as new as the day I had them put on. They came almost perfectly drilled to match the hub - the holes matched up but one hole had to be ever so slightly reamed by a machine shop for the supplied bolt to go through it. They were anodized black by the manufacturer AND I painted them Kioti gray to match the gray paint. There isn't a speck of corrosion so far. I had my tractor dealership install these spacers - my loaded rear tires are just too much for me to handle at home.
I considered adding spacers to the front wheels, but a discussion on this forum about doing that dissuaded me. Widening the wheel stance does put downward strain on any axle. For the meaty through rear axle, which doesn't have steering/turning wheels, widening the stance 4 inches on each side is not an issue. For the turning front wheels (my tractor can be 4 wheel drive with an electric switch) I didn't want to risk disturbing the axle's design stresses.
If anyone is interested in investigating buying spacers PM me and I'll be happy to share the company info where I bought them. Two spacers were about $400 ten years ago, and came with the bolts and nuts.
Are you able to or have you tried mowing without the FEL on the tractor? Mine having a cab makes it that much more unstable with the FEL on it. A couple years ago I removed the belly mower and have only used the rear discharge since. That change in addition to the loaded tires, wheel weights and rear spacers makes things quite a bit more manageable when mowing my steep uneven terrain. Since the FEL is removed while mowing, there are some areas where I will throw a couple suitcase weights on the front.
For the most part it’s pretty stable as compared to the first year I owned it and was running it without filled tires, weights or spacers.
/ Mowing on slopes maximum angle before tip #62
I haven't mowed without the FEL on the tractor. I was tempted to remove it, especially when the tractor started overheating. My "Wiley" Kioti has 41 HP and I should have bought the 45 HP same model. 41 HP works going up the hills, but truly the right speed (slow) to bush hog five feet high grass, bushes and saplings is the fastest it CAN go up the hills. In 4 wheel drive, FEL on, loaded rear tires (Rimguard, we have dogs and dogs love to lick anti-freeze if there was a leak), six wide foot hog, 2500 RPM. The video stressed how easy it is for our tractors to pull the front over on top of itself - especially on hills - so I've very leery of taking that FEL off. Plus, it is handy all year long.
The debris screen gets clogged with fine vegetative debris so I carry a leaf blower in the bucket. If the temperature starts climbing I blow it off. This is a whole 'nether story about the overheating. Last September before I get into fall bush hogging I finally bought a new thermostat, replaced the coolant with a 60% water/40% anti-freeze (water is better at cooling), and added a product called "Water Wetter". This has stopped the overheating. The mix still protects against freezing down to 7 degrees F. I keep the tractor in a garage that in Cincinnati winters (if the propane furnace doesn't quit) never gets below 40F.
I'm glad to hear you're putting weight up front without the FEL.
/ Mowing on slopes maximum angle before tip #64
I have one of those Harbor Freight 20 volt blowers and it fits behind the seat. I blow out my screens regularly when running hay.
I use a backpack blower to clean off the top of my mower deck and some of the loose grass on my tractor, but normally for cleaning out the radiator, coolers and air filter, I will use one of these “air combs”. I bought two different lengths and one of the 90° guns.
/ Mowing on slopes maximum angle before tip #65
I'll be mowing our fields next week. 20+ acres - 33 ponies - all engaged - all needed to mow the hills.
We run without the bucket but with the FEL on the tractor with our forks frame on the FEL (no forks). We also make sure that the turns up top are slow and easy. The FEL arms do enough to counter-balance the 5' hog on the back to keep all 4 planted on the ground if one takes their time.
2wd vs 4wd - I really do not have a preference. Have listened all the arguments and as a novice 300+ hours ago, I ran in 4wd always. Now? I like the lighter steering in 2wd. Yet there are places where the 4wd is needed to climb or descend the hill. My take: learn what works best and keep doing it.
33 ponies and a 5 foot cutter makes for long hours on the fields. The owner of the property doesn't want to invest in a bigger machine. So, we work this machine hard. Yep, we end up having to slow down depending on the amount of grass/brush to be cut in the field. Seems the grasses are much more difficult than is the brush.
The slope of the field is about 22 degrees. I just take it easy and plan to cut at about 1-1/2 acres per hour at best... conditions may drop things to closer to 1 acre an hour.
I opt for safe rather than fast. After all, I like riding on Missy Ferg!
/ Mowing on slopes maximum angle before tip #66
for 41 bucks you can buy the HF Bauer 20 volt blower and a battery and charger. I use mine for everything including blowing off the decks. Very powerful and very portable. Had mine for a year now and many hours on it without failure.
/ Mowing on slopes maximum angle before tip #67
Is there some way to reduce the amount of mowing debris that otherwise piles up on a rotary cutter deck or do you just have to clean it off?
/ Mowing on slopes maximum angle before tip #68
Depends on the height of the cut, again, I just use the HF blower, for me it's a must have tool and it fits behind the seats on both my M9's.
Just shredded a couple long rows of native long grass for a neighbor and that really piled up on the shredder but it was off in a couple seconds.
/ Mowing on slopes maximum angle before tip #70
Wow…really? You can’t beat that price. I debated buying a milwaukee since I have plenty of their 18v batteries already, but now you have me debating that idea. Usually I tend to steer away from HF because of their cheap knock of items, but I’ve been told about a couple things they carry that are as good if not better than the big name brand items. I’ll have to check it out the next time I’m in town.
Did it come with a battery and charger?
/ Mowing on slopes maximum angle before tip #71
You just have to clean it off. Same goes for the chaff that accumulates on the radiator, oil cooler and a/c fins (for those with a cab).
As @5030 mentioned, you don’t always park next to the barn when you shut your tractor off and therefore don’t alway have access to an air compressor or blower. Your reason for not parking at or in the barn maybe vary; whether it because you don’t have the room, don’t have the time to drive home, or are getting back at it that same evening following morning - in those cases having something lightweight and portable makes that job a breeze.
Sure is better than cleaning wet nasty grass clumps off the top of the deck and out from under the safety shields (for those who run them).
/ Mowing on slopes maximum angle before tip #72
Just another example of a 45 degree angle... a 12/12 roof pitch.
Think you could drive a tractor up or down that? How about across?
/ Mowing on slopes maximum angle before tip #73
Quite often I leave my tractors and implements parked in a field and have my wife fetch me home (dinner time) and get back to it this next morning.
Consequently that is why I have the Bauer 20 volt blower behind the seat so I can blow off everything and the rad screens when I park them and everything is somewhat dry and not in the AM when everything has dew on it and that especially applies to my round baler. Nothing worse than damp chaff sticking to a round baler to ruin a day. Besides, when I blow them off I can check the fluids and inspect the implements for any impending issues. Sure, I'd like to bring them home at night and use my compressor to blow them off but that isn't always possible and it wastes high priced fuel as well.
/ Mowing on slopes maximum angle before tip #74
I suspect it is more important than ever to blow off debris because of the heat from these DPF systems, and not to blow it off around where the tractor is stored where it can accumulate and become a fire hazard.
/ Mowing on slopes maximum angle before tip #75
Even ground conditions play a role. Soft ground versus hard ground, etc.
I find backing onto steep ground to be safer and more effective-even in the amount of ground you mow.
The reason is as has been stated by me and others, the upper back tire is the “tippy” tire. If you put the tippy tire ahead of the front tires by reversing the tractor, you get an earlier warning AND the mower mows more grass (if it’s a bush hog or rear mower like mine) because you are pushing it across/up the hill in front of you.
Having the mower “in front” of you when reversing has a stabilizing affect for MY steep mowing situations.
Experience has taught me these things.
If you read the safety guidelines published by tractors mfgrs. in their customer supplied brochures they recommend just that....back up the grade!
I had a neighborhood teen helping me yesterday and I was teaching him how to operate my equipment. The first thing I did was to get the safety pages out of my owners manual and had him read them.....I do recall seeing the back up for safety picture and verbiage. We had a nice safe day of his learning and us getting the job done....no accidents!
/ Mowing on slopes maximum angle before tip #76
OK, so I know there are multiple threads on this topic. But they all say the same about "pucker factor" and "if you don't feel safe". I do understand there are multiple factors, and no way to give a precise maximum angle before tipping that fits all tractors. That said, I'd like to try to quantify with some real data that could be used to derive general safe / unsafe angles in various scenarios.
To that end, I'm asking people to reply with specific information about their experiences, and to avoid replying with non-quantifiable information like how your butt feels or listening to the pucker factor. Also, please do not use this thread to post general safety information (safety first is *alwasy* good, but that information already exists in the other threads about mowing on hills). Instead, please post information such as:
1) What degree slopes do you mow / drive over sideways without experiencing any stability issues?
2) What is your setup relevant to stability (tractor type, ballasting, wheel width, etc.)?
3) If you have had the unfortunate experience of tipping over (or almost tipping over), what degree slope and were there contributing factors such as hitting a rock?
4) If you have specific angle guidelines from manufacturers / dealerships please share (along with the relevant tractor and setup information mentioned in 2).
Also of interest -- what degree slopes do you safely turn around on after having traversed uphill (and, of course, again info on the tractor and setup you use).
Hopefully we'll get enough good responses here for newbies like me to gain a better understanding as we try to understand the specific safety limits of our tractors.
Thanks!
Depending what machine I'm using. On the Massey, I'd be fairly careful doing my 15 degree slopes. On my Bradley stander, that's straight up fun...I'll wheelie that badboy up there just for kicks, mow it side-to-side, whatever, no fear.
/ Mowing on slopes maximum angle before tip #78
Sidehilling - it's not so much what you can see and expect - it's what you do not see and can not expect. I NEVER run my tractor to what I call the max side slope. There may be a hidden hole or rock that can upset the apple cart.
Even at that - there have been a couple times where the hidden rock almost got me. It's not a good feeling either.
Going up/down the slope. It may take more time but it's time spent on your tractor - not in the hospital.
/ Mowing on slopes maximum angle before tip #79
With my LS with R4's I am always running out of traction before I hit my limit. Also I always mow on contour not up and down. Also, I remove the loader to lessen compaction and because it is so darn fun mowing with steering brakes and no front end loader.
/ Mowing on slopes maximum angle before tip #80
Complete change of topic, but after watching that video my back hurts.
I’m not sure why anyone would choose to make their roof that pitch, especially going into it knowing they were the one who would be sheathing and roofing it. Even in my younger days, a 12/12 or even 10/12 was enough to give you a pretty good pucker factor. With the new ice/water and synthetic vapor barrier you can stick to the roof a little better than the ole 15lb felt from the yesteryears.
Hustler 943142 (A64912)
Hustler 943142...
2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
2021 HLA 48in...
Kubota L3901HST
Kubota L3901HST
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
Kubota 76" QA Bucket (A64912)
Kubota 76" QA...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
