Going on the Grid-How much?
/ Going on the Grid-How much? #41
I'd suggest getting the easements established now. All you need is one neighbor to say no and this could kill future electrification. I got my easement established just a month ago. The utility established it, but I had to pay for surveying. It was easy to layout the route because it would follow a established trail. This wouldn't be true if you were just cutting through a woods. It took nearly a year to get the easement established because the utility doesn't have income to motivate them. There was probably a dozen e-mails where I gently pushed them. But I got it done and there is a future route for the line to follow.
/ Going on the Grid-How much? #42
How many amps do you think you will need? If you only need 40 amps (well and power tools) and you only need 120 volts, maybe you could have them put the transformer and meter on the public road (for free) and use one insulated 000 aluminum wire and one bare aluminum wire and run your own line the 1200' feet to your place.
Wild idea- could you have the power company do their "free" installation on the power pole by the road and put your meter there. Next, find a "step up" transformer and run your own high voltage line 1,200ft to your place, then install another "step down" transformer there. Yes- you would need to pay for two "extra" transformers but maybe you could find them used for a reasonable price.
This was how it was done on a small cay I was caretaker on in the Bahamas. We had the power generation via solar and diesel and distributed around the buildings/houses with step up/step down transformers. The cay was 18 acres and had one step up and two step downs at the point of uses.
/ Going on the Grid-How much? #43
There are 3 other land owners that will have poles on their properties which involve easements that I didn't mention. I will most likely get a diesel water cooled 1800 rpm generator for back up. But running a generator 24/7 with low hr. warranties is not going to happen.
Once your inverters are sized for max intended load, then it's mostly a teeter-toter tradeoff between battery-bank size and generator runtime/frequency. Agreed, constantly running a generator is neither desirable nor economical.
Pls let us know what you end up with, I'm sure I'm not the only one who is interested.....
Rgds, D.
/ Going on the Grid-How much? #44
I recently checked on the cost to run power to our Tennessee property. The nearest power pole is 3500' from our property line at the top of the hill, in a neighbor's pasture next to a barn. Our access road is about a mile to get to the same spot on our land, from the main road with power lines.
The power company charges $8/ft, with the first 500' "free". Getting power across the pasture would be about $24,000 plus the cost of the easement. That neighbor won't sell an easement unless the court demands it. Getting power down our access road would be about $38,000, plus the additional easement to make room for the lines. The neighbors along the access road would be willing to sell easement at a reasonable price.
So, it would be in the neighborhood of $40,000 to bring in power. We can put in all the solar we need for less than 1/2 of that. I am leaning toward solar.
/ Going on the Grid-How much? #45
Battery cost will kill you, that's why I,m still connected, even with a big solar array.
/ Going on the Grid-How much? #47
This is so true and did happened. I hired the same lawyer that did the original title search when I bought the property almost 40yrs. ago. Turned out I always had the right of way to erect power lines written into my original deed. Lawyer cost was minimal, happy about that. Power is going in after mud season. Contract from power co. is in the mail for me to look over and sign. It appears my cost is not as bad as I thought. Thank you all for your input...Ken
/ Going on the Grid-How much? #49
Congratulations Ken.
So did that old Right of Way reduce the connection distance quite a bit, or did the utility finally get reasonable with their charges ?
Rgds, D.
/ Going on the Grid-How much? #50
My problem is our system is 5X bigger and battery cost to cover that just freaked me out, still on the darn grid. I hate making all that juice and practically just giving it back to the ELECTRIC CO-OP
Big system you have there.
For off-grid, I'd run the numbers on using an auto-start diesel gen to keep the batteries up. Over time, you can scale back generator use as you build up your battery array.
..... just one scenario to consider......
Rgds, D.
Rgds, D.
No, the distance is the same and price is still shy of $20k. Also, if they don't hit ledge they will rebate me close to $2k.
I received the contract today. Just have to sign and return with full payment. Yes it hurts to pay out this coin, but I don't believe or don't want to believe they are gouging me. I'll have to get a new camera and post some before and after pic's....Ken
/ Going on the Grid-How much? #52
Last month we made 300KW than we used, it was a light month only about 1500KW hours used. When we use the stock heaters a lot, the KW can be 2400-2500KW. With the meter charge, distribution charge, and about 5 more silly charges they add, it looks like a Cable TV or Cell Phone bill!
Our bill was $93, typical bill for that about of KW would have been a bit less than $250.
/ Going on the Grid-How much? #53
If I was already off grid I would spend that 20K to bolster that system.
If you could get by with a solid 10KW generator the MEP-803A military surplus units are dang good. I picked up a 2007 model last December. I got lucky and won the bid on it for $975 which turned into $1185 after fees and tax. By the time I built a good load bank to test and exercise it and all the stuff to hook to the house I was right at $2000 in the whole deal. Most of the good ones go for over 2 grand at auction but that is still a deal for a 1800RPM Diesel that will run at 10KW 24/7 in any weather. You can pick up a sorted unit ready to run for under 4K if you aren't into taking a chance on a unit that has been drained and decommissioned. I just completed my 3rd monthly test run for 2 hours at 40 amps and it just purrs like a kitten. Consumes about .7 GPH.
Obviously you can't run a generator of any type 24/7 but with a decent solar system with battery storage you can live pretty comfy with little to no expense after the initial setup.
Up in the NEK of Vt., in my opinion, solar bites. Unless you have a $20-30k system in panels and batteries. Regardless you will be running a generator for hrs. to maintain your batteries. NO sun, no free power. I have looked at and listened to those mep generators and they stink like **** and are to noisy but are great units. I still may buy one for back up. Also there is no cell service up here and I need to put in a land line for safety reasons. K
/ Going on the Grid-How much? #55
little late to state. but cost to put the wires in the ground vs on poles. with statement of easements and other hookups, and clearing of trees. along with statement of you putting in your own vs power company....
putting in the ground might be better. if you own the poles, and wire from road to home.
how ever if power company putting in, and they own the poles and wire from road to your home (up to the meter). and if something happens they are responsible for dealing with down wires / tree cutting etc... maybe a different story.
for years had lots of issues with trees nailing power lines and causing brown outs, to just killing power all together. and there are some others folks that needed to get the power put in ground vs on poles. every time a big wind storm would come through, the wind would whip the lines causing them to short out.
generally if in ground they will take shortest route between what is on the road to your home. if your driveway follows that path, then get a trench off in a ditch.
mowing / weed eating around fence lines and poles, just another chore to do that takes extra time.
I am rethinking about going underground up my driveway because there will be a transformer on the last pole 30ft from the camp . Under ground it would be at bottom of drive. Again this will have to be encased in concrete. I don't want to listen to a humming trans. next to bedroom window,let alone an explosion.
/ Going on the Grid-How much? #57
One thing about the military generator's is that a 10KW Military generator is not rated 10KW peak, 8500 W continuous, its rated 10KW at 8500 Ft altitude, so it is more like 13KW continuous at sea level and God knows what it is for peak KW.
/ Going on the Grid-How much? #58
Yep, it has a "Prime" (ie: the load it can power 24x7x365) rating of 10KW at 8500' and at something like 120F ambient. Just a little different than a box store genset that is rated for 10KW peak (for 30 seconds in the freezer on the test bench before it blows up).
Aaron Z
/ Going on the Grid-How much? #59
Perhaps I'm just stupid. How does a generator produce more electricity at a given elevation? I understand how, through the density of the air, a combustion engine has more power at sea level than high elevation, but how does a generator? They're made to produce "up to" a certain level of current at a fixed RPM, as long as the engine has power to turn at that RPM, adding more power to the engine does nothing for you. Changing the RPM changes the voltage, but that's not what you're talking about. Please explain.
/ Going on the Grid-How much? #60
Less oxygen in the air at higher altitudes means that a non-turbo engine will produce less power as it has to burn leaner to keep the same air to fuel ratio and that means that it cannot make as much power.
A turbocharged engine will feed in more air to compensate, so it doesn't care what altitude it is at.
Aaron Z
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Rol-Air gas powered portable air compressor, Coal Valley, IL (A65640)
Rol-Air gas...
John Deere 328E (A63689)
John Deere 328E...
Log Chain (A65640)
Log Chain (A65640)
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Skid Steer 3 Point Plate (A65640)
Skid Steer 3 Point...
