Gravel Yard Way Mud
/ Gravel Yard Way Mud #1
summit151
Drayton Valley Alberta
Massey 1135
Hey guys. I have another question regarding gravel issues. Since you guys were so helpful on my previous post. So I am fairly young I am 23 so I don't have much knowledge about this stuff or experience. I built a acreage about 3 years ago and built a large gravel yard. I live in Alberta Canada so we get a lot of snow and rain. I built the driveway and yard way out of clay and packed that down and then installed a couple inches of 1 1/4" crushed gravel which contained sand to help lock it in place. So each year I add more and more gravel to both the drive way and yard way. It does keep getting better and better each year but it is muddy in the spring. I'm just wondering if I should keep adding more and more gravel to create a base or what else to do? It is sloped well for the water to run off
/ Gravel Yard Way Mud #2
Good grief - you're just a pup. I know that in the spring my mile long driveway still has a couple soft spots and it was built by a road contractor. I have some thoughts on the manner in which you built the driveway but I will let those with a whole lot more experience provide guidance.
Ok what are your thoughts on how i built it? The actual driveway has a crown on it and seems to hold up well. I drive a 14000 lb service truck daily so it gets packed well
/ Gravel Yard Way Mud #4
In my opinion, you needed larger base material on the drive. 2-4" rock as first layer... did you remove the organic layer? ...was the stone just put down on the ground?
/ Gravel Yard Way Mud #5
You need to remove the imported material and add road fabric below. Then add 5-6" of imported material on top. Otherwise you are just going to continue to push your money into the ground.
If budget is an issue start with 50-100' sections that are bad and continue to add to it every summer.
No sense trying to do much now- too muddy.
Yes I do agree with a larger base rock. It was a after thought and yes I removed all the top soil. I actually dug a dug out in my back field and used that as a fill to get everything above the surroundings
/ Gravel Yard Way Mud #7
My thoughts - since this is a gravel yard - you are probably driving pretty heavy equipment in and out. The base layer, being clay, just can't hold up to the wet conditions and heavy equipment. I think what RNeumann suggests is the way to correct this condition.
You know - this time of year the county road dept has weight restriction on all county roads. They realize that heavy trucks and wet ground just don't mix well.
AND don't get all excited about my calling you a pup - what the written word can never show is the envy in my voice. I was just a young pup once too - it was back before God created dirt.
/ Gravel Yard Way Mud #8
Clay is nasty stuff when wet; stuff just get pushed down more. It is not a cheap process to build roads on it. We Seabees contended with it building roads in Vietnam. Roads had to be built up on top of the clay base. I was not directly involved ; but it seems they built up a layer of 4-2" minus rock/gravel well graded and with the crusher fines. It was laid in layers and mixed with the clay by windowing with a grader back and forth. Then the mix had cement mixed in that and vibratory roller compacted. This layer was over 12" deep and well sloped to the sides. Water content was constantly tested. No idea of the cement ratio but is was considerable. Then a standard road bed was laid on top of that topped with either a wearing surface of crushed gravel or asphalt. Word is that those roads are still being used today. However money was not an issue. those roads became up to 24" above the area top elevation.
Some lesser variation of that idea will probably work well for a farm road. The smaller the rock the faster it will disappear into the clay when wet. You will swear there is no bottom to it. State Highway Departments have standard designs for all types of situations. Those drawing and specification are public domain so available to the public.
Ron
/ Gravel Yard Way Mud #9
....I actually dug a dug out in my back field and used that as a fill to get everything above the surroundings...
I understand why you did this... how well did you compact this? I ask because of the roads I've built, anytime I fill a low spot with dirt, I can never compact it enough and it becomes a soft spot later on.
A friend had a soft spot and just dumped 3-4" rock in that spot... a bit rough for a while (he drove on it like that for a while) then he topped it once it was stable...
So the big question is how to BEST "fix" what you have? I have not had this problem in large area. In my soft spots, adding larger rocks worked fine. Your large area, I might:
Identify the problem areas... most likely the water has no where to drain. I would see if digging down; add and compact larger rock in (we have 2.5" crusher run) then spread the dug up gravel over it (lifting that area higher). Others might have better ideas...
Of course, my way might just move the problem some where else... Good luck.
/ Gravel Yard Way Mud #10
I agree with the above posts. Having been in the Drayton area I have seen what you are up against. I would write off the finer gravel you have put down, and I would pound the pitrun to it. 5-6" pitrun with fines and let that settle for a year, or just drive on it,then go to finer stuff IF and only if you don't turn muddy again. If the yard is still muddy, then put more pitrun in but go a little finer like 4-5"-.
22 years ago when I bought this place I had about 50' of driveway that I had to use 4wd to get through in spring. I pounded the bigger pitrun to that hole and the rest of the driveway for two springs, now I have a usable driveway and this year I am going to put down 3/4" granular 'A'.
After and only after you get a reasonably dry yard (no mud) I would go with asphalt grindings, but only if you can get them cheaply. Sometimes when road contractors do a shave and pave on the roads they have more grindings than they can use in the new mix design. When that happens they will sometimes sell them to locals, cheap.
Ok all good suggestions guys. Are you saying I should dig all my gravel up and then add the bigger rock? That would be very pricey to do. Can you put bigger rock down right now on top of the smaller 1 1/4"?
/ Gravel Yard Way Mud #12
The problem is the clay, whatever you put down will eventually sink down into the clay. The best would be to put down some road fabric and prevent any aggregate from migrating into the clay. Then you can put a layer of larger aggregate and then a layer of topping aggregate. This will keep the road base stable and stop the clay from allowing water to pool.
Experiment with a section of your road that is the worst. Get some road fabric (geotextile) put it down and the rock. I bet you will see a drastic improvement.
/ Gravel Yard Way Mud #13
The ideal bags of money to burn situation, (you picked the right 7 numbers) then dig it out. If you are like the rest of us on a budget, then the geotextile and pitrun.
If you are running a business out of your house, (14,000 lb truck) then talk to your accountant about how much of the money spent may be recoverable off your income tax.
/ Gravel Yard Way Mud #14
Unfortunately you made a rookie mistake,
I was a rookie once, and made LOTS worse mistakes (not driveways/roads).
Your problem is, and will always be ...... the clay base.
If you want to do it right, for a lasting solution, you need a stable base (no clay).
Your cheapest good fix, might be to scrape up as much of your clean used gravel as possible, and save it.
Then have at least a foot of the clay totally removed, and replaced with sandy pit run material.
Then put your used gravel on top, with some fresh 3/4" minus on top of that, and a significant crown.
You should also create ditches about 2' deep along each side.
It will be pricey to have done, but it will be solid!
/ Gravel Yard Way Mud #15
This is a good time of year while it's muddy to add some 2 or 3" crush while it will pack in . You've got a good start for a base now so don't be digging it up. Next spring it may be solid enough to get by with some 3/4" crush for a nice topping.
/ Gravel Yard Way Mud #16
I'm not sure you are understanding the road fabric or large rock base "problem".
First road fabric is relatively cheap. Much less than rock. Plus it's easy to lay out.
The second is the rock base. You can use 2" or 4" or 6" rock. The rock, to a point, will continue to sink into the ground and push clay up. This simply perpetuates your problem.
You don't have to remove anything that is on the road now. Folks were just offering that as a way to save material. You can add the fabric and then add "base" "class 2 base" "crusher run" "1" minus" over the fabric.
I do understand the concept of the fabric just was not sure if I could lay it over the existing base I have now. And clay is used a lot around here to build roads. The county builds up the road with it. If I were to lay down 3" or 2" crush on top of my base now would the larger rock sink in and create a base?
/ Gravel Yard Way Mud #18
Rock/base will continue to sink until it reaches the bottom of the clay. This has the inverse affect as well- it will push the clay up. This will not make the desired base.
If you have clay and it is used to make a road simply place the fabric between the clay and 5-6" of imported road material. 5-6" is a driveway quality driving surface. More imported material would be required for a public road or highway etc. I'm sure your municipality's road spec has the fabric layer.
/ Gravel Yard Way Mud #19
You're chasing your tail by putting more gravel down. The problem is that you did not build a proper base to put the gravel on top of. Once the dirt gets wet, the particles move apart and then the bearing capacity goes down.
/ Gravel Yard Way Mud #20
Ahh---the good old Drayton Valley mud yes. Slippery sticky stuff that. Come spring you got a couple of inches of it tracked all over the town streets. It even seems to follow one into the house after it sucks your gumboots off.
Notice the dually tracks didn't sink down? Just made marks in the grease.
Your all okay. Just keep adding crushed gravel as affordable. Keep the surface smooth and sloped so it drains. Come summer it'll look like concrete.
You may notice all the roads in your area are made from packed clay with crushed gravel on top. Large rock may be hard to come by or require long hauls. It wil not work as well as crushed in your area.
Worst time will be in the spring when the frost is going out. That's when the road weight restrictions come into effect.
