Grasshopper ZTR flail mower
/ Grasshopper ZTR flail mower #1
MultiMow
Gold Member
Wytheville, VA
Toro 325-D 4WD
After countless hours spent desperately searching for a flail mower deck compatible with my Toro mowers (325D and 455D 4wd), I've given up the search.
I found that Iowa Farm Equipment is now selling a Peruzzo Teg Special flail deck for Grasshopper front mount ZTRs
( Iowa Farm Equipment -- Peruzzo Teg Special Front Mount Flail Mower for Grasshopper 7 & 9 Series Tractors )
I was fairly impressed with the performance in the videos their rep sent me:
Grasshopper 14 Flail Mower Long Grass-4 - YouTube
Grasshopper 14 Flail Mower Long Grass 3 - YouTube
These videos are with a Grasshopper 722D power unit. I've found a reasonably priced 930D, and I'm more or less just wanting to hear experiences with Grasshopper mowers in general and model specific.
I already have a finish mower, so this unit will likely stay hooked to the flail mower and have chains or ATV tread tires upfitted. In other words, it will lead a rough life mowing rough areas where a typical ag tractor would either be inefficient or impractical... so unless the cut quality or productivity is worlds above/faster than my Toro, cut quality of the factory deck isn't an issue.
Alright, that's enough from me for now. What do you guys have to say?
/ Grasshopper ZTR flail mower #2
That would be nice to have on my 723 but I also have a few tractors and bushhogs so it probably wouldn't get used much.
/ Grasshopper ZTR flail mower #3
Same here...
I have a 721-D and a 725-D, that's what I mow grass with, although I do put a sno-blower on the 725 in the winter.
That flail looks like it kicks butt!
SR
I just found a couple more videos and lots of pics from the same weekend.
Turns out, the overgrowth in that meadow was far worse than the above video shows. Here are a couple from they first started:
Grasshopper 14 Flail Mower Long Grass 1 - YouTube
Grasshopper 14 Flail Mower Long Grass 2 - YouTube
According to the rep, a lot of the growth was over 5ft tall, and some over 6ft.
Here are some pics he sent me as well, including some AMAZING striped finish mowing, done with the same flail mower (pretty sure they changed the knives, though):
/ Grasshopper ZTR flail mower #5
Wow, that's a nice looking unit, thanks for posting. Any idea on pricing? I might have to pick up the 55" for my 721D...
/ Grasshopper ZTR flail mower #6
I know nothing about either Grasshopper or ZTR flails but if you are looking for a purpose built machine to get into terrain not suitable for a CUT, you might want to familiarize yourself with PowerTrac articulated tractors. The 422 or 425 models run a front mounted "bush hog" or finish mower and are excellent on slopes as well as being highly maneuverable.
/ Grasshopper ZTR flail mower #7
Cuts too slow. I wouldn't even try to cut what was in Video-1 with my 72" flail behind my 50hp tractor. I could buzz over that with the rotary in no time. If I wanted a cleaner cut after that, a quick run with the flail can be done and still be finished before you could with a lawnmower. :cool:
/ Grasshopper ZTR flail mower #8
Agree on speed but I cut several fields only once a year in the fall with my flail and the height of that grass is pretty typical for what I mow. I would travel at least double that speed on my 40hp tractor and 75" flail. Faster if I wasn't concerned about mulching the cuttings. Slower if it was June and the grass wasn't dry.
/ Grasshopper ZTR flail mower #9
$4699 with the "Y" blades and $5699 (USD) with the 4 different styles for the 55". I'll keep using my roughcut behind the 65hp. But neat to see.
Believe me, I'm not about to compare the productivity of this machine to a tractor/rear mount mower combo for open fields.
This machine does have it's merits for my use:
1- COMPACT
It's small enough to to drive into a step van.
2- LIGHTWEIGHT
It can be transported on a small utility trailer, in a step van, or on a utility bed truck.
3- FUEL EFFICIENT
Again, it wouldn't compare to a tractor in an open field... but for scrub mowing small areas, ESPECIALLY with lots of obstructions (example: reclaiming areas of undergrowth around a lot of trees)... this unit would be much more fuel efficient than a utility tractor, and worlds more efficient than a rotary mower.
3- PRODUCTIVITY
For its intended purpose, there's no match to the time saving maneuverability of a ZTR. Less trimming. More mowing. Less time performing unnecessary/nonproductive maneuvers. For a one man brush mowing operation, it would save a LOT of work with a handheld trimmer.
4- RETURN ON INVESTMENT
Given you can pickup a GH 930D for around $6k, or a 725D for around $4k with just over 1,000hrs... you're looking at a $10-11k investment for a single unit mowing solution of short and tall growth. That kind of revenue can be made in less than one season... and you're talking about a machine with 4,000hrs of service life left. If you do the math, at $20net profit per hour, that's $80k. Also, it's worth noting that scrub mowing extends your annual season, as it opens you up to customers beyond the growing season.
I've always preferred scrub mowing over finish mowing. The customers typically aren't nearly as picky, the competition isn't as tight, the margins are higher, and the pay is hourly.
I see this unit for what it is... a great scrub/rough mower for areas that require a high level of maneuverability.
If I can sell my my WAM (Toro 455D), I'll like have one of these in short order.
/ Grasshopper ZTR flail mower #11
Plus only one engine to maintain. I love my grasshopper. If the flail was $2500-$3000 I'd be all over it.
Agreed.
To each their own, but I've always preferred mowing with front mount equipment... and preferably without the engine and hood in the way.
I already have a utility tractor... but after mowing with the front mount Toro I bought last year, there's no comparison. Not having to look over my shoulder to trim or other places that require eyes-on mowing, was a real neck saver. I can only imagine the added 20% horsepower of the GH 930, combined with the ZTR mobility and lower CG.
I might miss the 4wd, but most everyone I've talked to says front mount Grasshopers are hill climbing beasts with the right tires.
/ Grasshopper ZTR flail mower #13
Agreed.
Check out the PowerTrac 422 and 425. 4wd and excellent on hills as well as very maneuverable articulated tractors.
/ Grasshopper ZTR flail mower #14
I have a Grasshopper 721D 61" and a Farmking 7' finish mower behind the MF 265. The Grasshopper is a better cut and way faster in and around the yard. If I just mowed open field than the 7' finish would be faster, but around the house, barn, garage, pole shed, firepit area, under corals, under bushes, the grasshopper can't be touched. Front mount rules. The grasshopper is also very comfortable and less fatiguing.
/ Grasshopper ZTR flail mower #15
When it comes to mowing small area's and around any obstacles, those power trac's don't even come close to keeping up with a front deck GH.
SR
/ Grasshopper ZTR flail mower #16
SR
For a suburban lawn that is undoubtedly true. I was thinking slope cutting and rough cut rather than maneuvering around scrubs. I thought the OP was focused more on that.
/ Grasshopper ZTR flail mower #17
I have a 2010 front mount Grasshopper 723K (gas). I mow 2 acres twice a week when it rains, and 5 acres once a month. Works way faster than a pull behind finish mower.
Indeed, that is my focus.
However, when it comes to reclaiming property (especially residential), many customers want to keep as many trees as possible. Many of them aren't even concerned with expanding turf area... they just want the undergrowth cleaned up. When maneuverability counts, accept no substitute for a ZTR.
Admittedly, if I could find a comparable flail mower for my small Toro (325D 4wd), I wouldn't have even found this machine.
The Power Tracs are nice, but they're huge compared to the Grasshopper.
They may be slightly more capable on hills... but given the trade-off, I'll take compact maneuverability over excess capability. Aside from the ability to run a boom mower, I really don't have a use for the PT.
Also, I've noticed some people talking about using a rotary cutter, and finishing with a different piece of equipment.
I like the single solution of the GH. I can drive this thing into my step van or straight truck, toss in the trimmer, and head to the worksite. The other suggestions require a trailer, two implements, tractor, and a LOT more time spent trimming.
Unlike most people, I prefer smaller equipment. The lighter weight means I can drive through someone's yard without fear of turf damage. It also means less soil disturbance/compaction in the areas I will be working. If the customer wants to expand their turf area, they won't be bothered with the expense of soil reconditioning (aside from a good broadleaf spray). Otherwise, they might as well have someone come in with ground engaging equipment to both clear and grade.
I've used rotary mowers. I have a bush hog and a finish mower for my Kubota. Even in open areas of tall growth, it usually involves mowing twice over... and I DISPISE doing something twice, when it could've been done right the first time.
I also hate trimming. It has to be done, but the more of it that can be eliminated, the better. Less trimming means higher productivity.
I'll put it to you this way...
My property is a long 26 acres. It lays in a creek valley. Most of it is featured... with ridges, rock outcroppings, creek banks, noles, and drainage ditches. Most of the properties in my area are mountainous and very similar (Blue Ridge Appalachians). Until now, I've been using a tractor/bush hog combo, and my lawnmower for the fencelines. I still use the bush hog for the creek banks. All in all, I spend an entire day just bush hogging the bulk of the open area, another day mowing the features, another day mowing the creek banks, and yet another day on fencelines, around the mill house/dam/etc. .
That's a LOT of time I'm wasting away from family, when I'm only home two days per week (truck driver). This doesn't include the side work I do for others, and any contract work.
For every two day's work outside of my occupation, that's an entire week away from my family... and equipment count is a whole other ordeal of time in maintenance.
The way I see it, this is pretty much a one and done solution for 95% of what I have been doing with five pieces of equipment (not counting the trimmer). Also, it's 100% of the side work I contract away from home... so I just eliminated a trailer (or at least, a lot of trailer size requirement), four pieces of equipment, 1hr of prep work before leaving to the jobsite, and a LOT of maintenance.
/ Grasshopper ZTR flail mower #19
I sold an open station NH TC45D tractor and all implements, including a NH 6' 918H flail mower last fall. Trying to decide what to replace them with for mowing and spraying. I do a 3 acre lawn and light field mowing now with a 60" cut Hustler Z. I also have a 10 acre hay meadow that I have been mowing about twice a year with the tractor and flail. I am 81 and no longer have the strength or energy to change heavy implements or do a lot of maintenance. I have been considering a new tractor with a cab to get out of the Oklahoma midsummer heat and the dust and pollen mowing stirs up. I would still have to use the Z to mow the tight areas. I was wondering how much dust and clippings a front mounted flail on a Grasshopper or Kubota would blow back on the operator in the constant Oklahoma summer wind? My tractor rear mounted flail would throw up a pretty large cloud of dust and clippings, but since the tractor was well above and in front of the mower very little got to me. I bought a Kawasaki Mule Pro recently that I plan to rig up with a sprayer and boom to take care of the spraying chores. Vic
/ Grasshopper ZTR flail mower #20
You don't need to convince me that small is beautiful. The deal maker that I see in your detailed reply is that you can drive the ZTR directly into your panel truck. That's a killer bonus for sure. Anytime you can eliminate a trailer you've improved productivity and quality of life. The PowerTrac 422 and 180 are modest in size but I don't know that they'd fit in a panel van. The 180 is only 42" wide but with the front mower attached must be at least 10-11 feet long so better suited for a small trailer. H Class
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2020 John Deere 470G Hydraulic Excavator (A64553)
2020 John Deere...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
2015 Hitachi ZX75US Midi Excavator (A64553)
2015 Hitachi...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
