Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #4,021
There can be float on 3pt hitches depending on the valve. I have a float in one position on my second set. In my case on my Maschio flail, when I set it down I position the mower in the mid point of the (float) position on the mower per the manual. There are slotted connections to allow it to follow terrain. The mower in the pictures above has room for the lower 3pt arms to move to follow terrain. In my testing my unit did pretty good with the 3pt fully lowered with the mower moving on the skids and rear roller. The mower design allows to to flex side to side to . When looking at selecting a mower, look as to how it is design to flex behind you tractor. Some are designed better than others.
Hope this helps.
/ Let's talk flail mowers #4,022
Thanks IslandTractor and Powerscol.
/ Let's talk flail mowers #4,023
The lift links on the Ford 917 & similar aren't solid. They move up & down 4-6" or so to get the flex you normally get on the toplink on a rotary cutter.
/ Let's talk flail mowers #4,024
Is there a proper procedure for shutting down a PTO implement so you don't damage your PTO ? So your flail mowing at 540 RPM'S, do you lift the implement off the ground then idle the RPM'S down then disengage the PTO. or can you disengage and engage the PTO at any RPM'S
/ Let's talk flail mowers #4,025
Just shut it off. You won't damage the PTO. Of course in general we typically slow down or come to a halt before disengaging but that is just a matter of work flow. It doesn't hurt the PTO to be disengaged at higher rpm.
The one issue that is a concern is if you have an older tractor without a live PTO, then a high inertial load can cause the tractor to continue to move forward even when the foot clutch is depressed, creating an unsafe condition. And overrunning clutch is often added in such a scenario so that by disconnecting the load from the PTO under these conditions, the overrunning clutch improves safety.
/ Let's talk flail mowers #4,026
Thanks Island Tractor, you talked about disengaging, can you engage the PTO at any RPM.
/ Let's talk flail mowers #4,028
With no attachment on your lowered three point, grab a lower link and pull up on it, both lower links will come up.
Thats what I thought but I haven't actually tried it.. I also just realized that I may have the 3pt bleed-down adjuster too tight.. The arms lower very slowly.
I'll have to see if the bleed down adjust also affects upward movement.
/ Let's talk flail mowers #4,030
It will have no effect on "up".
Up is usually mechanical,,, so once it goes up, it will again go down quickly to the set point.
It's usually called the ROD knob in manuals. Rate of Descent. It affects how big the hole is that empties out the cylinder is. No relation to hydraulic flow in. Idling down would slow down the lift speed, but that's about it unless you re-plumb things.
/ Let's talk flail mowers #4,031
No. You must engage at idle speed. Sorry if I misread your original question.
I'll disagree a bit...
You SHOULD always engage your PTO at idle speed. Engaging it at higher RPM is very doable but very hard on clutches, PTO shafts & the whole gear train.
I've never had issues disengaging PTO at any RPM. I always waited until there was no load on the PTO train or what not though.
In old machines with a live PTO something spinning the PTO would keep moving as if you had the clutch in gear regardless of the clutch being in or out. I don't think they have made machines like that in the past decade or 2 though. Some new HST machines are like that, but the HST intrinsically makes that problem moot as it won't transmit power unless you hit the go pedal. I think my L3200 was that way, but never actually tried to propelled with the clutch in & go pedal down based on the kinetic energy stored in my rotary cutter.
/ Let's talk flail mowers #4,032
All,
I feel I've achieved a milestone by reaching page 230 of this thread and feel confident enough now to ask a question or two and ask for some friendly advice.
Here we go. I will be taking delivery of an L6060 cab as soon as Kubota decides to ship it to my dealer. I currently have a Woods 72 inch rotary mower which I will be selling if a flail mower is in my future.
I cut the following: large yard, field edges, road edges with slight to around 18 degrees of slope. There are times I knock down undergrowth in portions of the woods that is primarily various weeds and starter saplings not exceeding a half inch diameter. There are times that limbs will fall from trees that may exceed that, however, I take the time to move them vs testing equipment capability. There are rocks that are always found but it's not terrible and I know most of the bad locations. I would like something durable enough to deal with the small saplings, small roots from cleared areas and not simply a finish mower.
I have considered used but the nearby inventory is limited (north west Illinois but the property is in southwest Wisconsin) The side shift would be important to me to avoid damaging the cab with field edge overhang and yet get reasonable cutting into woods on field edge.
Questions:
Based on the above I am considering this unit. FM-78H Flail Mower | Flail Mower Attachment | Tractor Mower | PTO Mower | -WoodMaxx™
Any thoughts on applicability? Alternatives?
What knives, based on the above, would you recommend? (Assuming a flail would meet my needs)
Also open to hearing "keep the rotary"
Thanks for any insight and advice. now, back to trying to finish this thread!:thumbsup:
/ Let's talk flail mowers #4,033
Innrkid, there are a number of TBN members with Woodmax mowers and my impression is that they have worked well. You might want to compare the Caroni TM1900 with hydraulic shift kit as an alternative. About the same price. The Italians make excellent flail mowers and have for a long time. The Chinese are much newer in this game.
/ Let's talk flail mowers #4,034
All,
Questions:
My 5' rotary ran off with my old L3200. Used my ancient Ford 917 once with my new L4060. Given the age of my 917 I've seriously been thinking about replacing it, or at least getting a backup & the WoodMaxx is high on my list. I keep eyeing the biggest Cat1 hydraulic sideshift they have.
Pretty sure the only difference in our machines is you have 20hp more & a Cat2 3pt, maybe bigger tires. You likely want to look at the 2 bigger Cat2 mowers if you go with WoodMaxx. Think the 78 is a Cat1. My 32hp 3,500lbs loaded L3200 ran my 7' 917 fine, although a bit slow in high dense stuff. My L4060 actually ran it as well as my L3200, but it was really tall winter grass with a touch of snow in places when I mowed the once so far. 20 extra HP & no altitude issues (turbo on the L6060 even if you are near my 6,500') means you'll be able to spin a fair bit more mower in denser stuff than me.
I really don't bother clearing branches & have intentionally ran & mowed over several dead Christmas trees & similar sized standing trees. The rotary ate them up better, but the 917 did an OK job despite a bit of noise. The grass side cutters just bounced off the heavier trunk making a little racket & mulched the rest. Duck foot hammers would have likely eaten a lot more of the trunk. If you go slow you should be fine mulching reasonable sized branches.
My 917 with grass side slicers has mostly heald up to occasional mowing of woody brush & occasional Yucca (imagine dipping 2-3 pair kid size blue jeans in plastic & calling it a cactus, would be slightly easier to mow than Yucca). I did blow a rotor bearing on a gig last year. But the flail is as old as I am, so I can't blame that failure on pushing it.
/ Let's talk flail mowers #4,035
Thanks. My rotary is potentially running off with my old L3130. A common occurrence? :)
Fallon, Great information! You are correct on the category 1 vs 2. I will be modifying other cat 1 attachments and or replacing as I go. It's very good to hear that some small brush will not pose a problem. Would you suggest duck foot for my applications?
Thanks. And by the way, I used to live in Parker when it was still small. High Praire Farms just south of the Pinery. Winter Park prior to that. I knew when you said 6500 ft we likely had something in common.
/ Let's talk flail mowers #4,036
Thanks, IT. I have noted you also own a Caroni and seem generally pleased.
/ Let's talk flail mowers #4,037
Yes, my Caroni is doing well after ten years in rocky New England soil. The rocks have taken a toll in that I have to replace lost knives/clevises more often than most but that has nothing to do with the mower. No other mower repairs and no maintenance other than regular greasing and a couple sets of drive belts in ten years. I don't have the hydraulic side shift but have manually side shifted a couple of times. I'd get the hydraulic if doing offset mowing regularly although the normal position of the mower allows about 18" offset to the right which I find adequate for mowing fence lines.
Nothing against the WoodMaxx at all but I do wonder why they cost essentially the same as the Caroni given the Chinese versus Italian manufacturer.
/ Let's talk flail mowers #4,038
Not many dealers around here for Caroni. I have a ways to go before a decision needs to be made....if at all.
/ Let's talk flail mowers #4,039
Actually only one dealer for Caroni I know of: AgriSupply. I suspect there are some other smaller ones but AgriSupply seems to be the biggest importer. They are based in SC if I recall correctly but they ship nationwide. Not much need for dealer support other than replaceable blades etc which have never been a problem. Most of us use less expensive and equally good Flailmaster replacement blades and Gates Kevlar belts to replace the originals.
There are a couple of other Italian made flails sold in the US and I believe they are just as good as the Caroni. Maschio (?sp) is one and is sold by a number of dealers.
/ Let's talk flail mowers #4,040
Keep the hog until you're sure you don't need to open new areas to be mowed.
Jim
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
