Box Scraper
/ Box Scraper #21
A couple of things here.
First, all these pictures in this thread show roll over box blades.(ROBB) I have to assume that you have NEVER used a ROBB. I hydraulic top link does NOTHING to facilitate the use of a ROBB.
Second, the blue and red tractors have complete top & tilt sets on them, so not sure where you get all these loaded box blades with no hydraulic top links? :confused3:
I understand all of that.....seams the two replies before you understood that. The OP sounded like he was on the fence with hydraulic TnT. I was simply giving my opinion or a gentle nudge in that direction.
I realize you make and sell TnT kits. In fact we have spoken and exchanged emails.
I understand you are confused- your post makes that clear.
/ Box Scraper #22
I just bought a Box Blade and have no experiance using it yet, and when I was at a rental yard I noticed how warn down this one was. So when does a box blade become unusable, and if they get ground down this much why don't they have replaceable edges or hard facing on the bottoms.
If the front is doing more than just touching the ground the top link is too short. By pressing down on front you are lifting the cutting blade.
You will need to verify the forward cutting edge length before you attempt to extend the side back to factory length. From the picture it looks like that cutting edges are about an inch or so below the side. That is about right. Raising the sides could pull the front cutting edge off the ground and it would ride on the back blade- not good for cutting.
/ Box Scraper
I'm not on the fence as far as the need for one. Just how to implement it. And how to pay for it, as it will end up costing more than the scraper.
/ Box Scraper #24
It might not have much wear. Look at some new ones, most side plate top and bottoms are not parallel.
Mine has some wear, but still works well. :thumbsup:
/ Box Scraper #26
You're the one that mentioned pictures and no top & tilt units.
As far as confused, yes confused as to your post in the 13th post. When you said all these pictures and no hydraulic top links when 2 of the 3 different tractors shown have hydraulic top links.
Makes no difference, hopefully everyone has the idea by now. :thumbsup:
/ Box Scraper #27
Probably should slow down enough to reread my post. I made no mention of the pictures not having top and tilt.
/ Box Scraper #28
You're right, you only inferred it with what you said.
"I'm seeing all these pics of loaded box scrapers and it has me again wondering how anyone gets anything done without a hydraulic top link!"
I apologize for my misunderstanding. ;)
/ Box Scraper #29
400# seems light for a 6 ft box blade. I've always heard to figure on 100# per foot of width for a good medium duty box blade. I've got the Woods HB72 that weighs in at around 600# and I've been happy with it. It has held up well. Not sure if they still make this model
/ Box Scraper #30
When you install a hydraulic top or side link dont you have to be careful that you don't do something like this. This was a photo I found on google images from another forum and if I remember correctly he said he was backing up and caught his blade on the ground and this was the result to his HF quick hitch.
/ Box Scraper #31
I've never had an issue. That looks like a brittle weld on a quick hitch. I've never used a quick hitch. I don't see how the hydraulics would cause anymore or less damage then a solid top link. Maybe someone else is seeing something I'm not though.
/ Box Scraper #32
Probably because it's from harbor freight....
But no, never had an issue. If you extend the top link all the way like that, the lower arms should raise up as well since they float.
/ Box Scraper #33
Catman8 - the only way I cold see that being CAUSED by a hydraulic TNT would be if your top link was able to extend way too far for the geometry of your 3 Pt hitch: so you'd tip the attachment or quick hitch plate all the way back, almost horizontal, then push even further, to the point where your top link is out further than your lower arms plus the length of the implement. I've never seen a top link that can extend that far. Even then, it should just stop and the relief valve lets go. The break shown in that picture had to be either a poor weld or abuse. I suspect a poor weld, since the type of abuse needed to rip a good weld of that size apart woudl have damaged other parts of the tractor as well.
/ Box Scraper #34
I saw a different quick 3 point hitch that was designed different. The top link came into the box tubing instead of cantilevered over the top like the one above. That would seem to cause less stress and the potential failures.
/ Box Scraper #35
My recommendation would be to get a ROBB. (roll over box blade)No hydraulics needed, heavy and hold up well. There are a couple of other manufacturers as well, none currently quite as good as Eagleline though.
Mine are Gannon, but are no longer made. :( I have a 65" @ 800lbs and an 81" @ 980lbs.
If you get a std type box blade, plan on getting a hydraulic top link at a minimum.
Good luck with your search and final decision. ;)
+1. I have a 72" ROBB at 710 pounds and when doing heavy work in my very dense, rocky soil, wish I had a couple hundred pounds more weight. This said, I get the jobs done but they just take longer. Concerning hydraulics, if you are not box blade experienced, a hydraulic top link with help you learn adjustments MUCH faster, along with being productive MUCH quicker due to not having to get off, on, off, on, off, on, the tractor many numerous times until you get the adjustments figured out. Another good thing about a ROBB is once you get the digging angle figured out, it usually works with only minor adjustments- if any, when changing from one function to another on the ROBB.
Case 580K Backhoe (A64047)
Case 580K Backhoe...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63118)
1986 Ford LN8000...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2007 KENWORTH T800 MID-ROOF SLEEPER (A63569)
2007 KENWORTH T800...
2022 J&M TF212 Rolling Harrow (A63116)
2022 J&M TF212...
