Show What Tool You Made*
/ Show What Tool You Made* #461
My imagination went into build mode again .I have a transmission to change in my pickup so I decided to build a jack .No test run yet so will wait and see how it works out .
/ Show What Tool You Made* #462
sorry that picture went in upside down not sure what I did wrong ,or why and can't figure out how to fix it.
/ Show What Tool You Made* #463
Your picture comes up alright. I like the idea of the hex bolt on the end of the screw.
/ Show What Tool You Made* #464
How does it tilt? Tranny jacks need to tilt two ways.
hugs, Brandi
/ Show What Tool You Made* #465
It was a spontaneous build ,no tilt was planned , if I get lucky it will have enough flex where the top rotates for the tilt
/ Show What Tool You Made* #466
Couple wood shims pushed in under the trans pan will tilt it , I am spontaneous also. I like it , sure beats dragging in up on your chest and knees and working it up there.
/ Show What Tool You Made* #467
YEP!! That's nothing you can't cure with some wooden shingles and a couple of ratchet straps
/ Show What Tool You Made* #468
Thanks for the compliments . I lost the ability to wrestle it by hand about30 yrs ago.
/ Show What Tool You Made* #469
Here is something I made a long time ago to hold onto a small screw in tight places to poke it through a hole.
/ Show What Tool You Made* #470
That's nice-
I usually make something on the spot- a piece of shirt cardboard, or use something like a hemostat, but it can be dicey- and your tool looks like it has a pretty positive hold on the machine screw- especially important in the usual locations I'm working in- where if you drop it, it's prolly gone for good...
Thanks for sharing,
Thomas
/ Show What Tool You Made* #471
That's interesting. Kind if like an extension of human fingers. Pretty neet.
/ Show What Tool You Made* #472
A handy tool, and no welder or power tools needed to make it.
Find a wire soap dish. This took the longest. No stores had them new. Success was at Goodwill.
Turn the dish over so the feet stick up, like a dead cow in the comics.
Now you can see what it holds.
Two of them in a tool box drawer, loaded. I probably have too many files.
Bruce
/ Show What Tool You Made* #474
Bruce
Nice Bruce,
I love re-purposing already made things too.
...and there is no such thing as too many files- unless you can't get into the tool box because they jammed up the drawer- which your re-purpose negates.
Thomas
/ Show What Tool You Made* #475
2" Square tube bender
2" Square tube bender using my wood splitter. You can see my first attempt with my push die it crushed the sq tube but my second push die did much better. I do need to make a 3rd die improvement with a larger radius. I used this to make my ATV log arch
/ Show What Tool You Made* #476
This great old thread seems to have fallen by the wayside. I am posting a minor contribution to bring it back. I learned a lot from the entries.
Photo 1 - A pile of deck railing posts. Each post needs two bolt holes in exactly the same place, and in alignment with the code required tensioning bracket.
Photo 2 - This simple jig took a few minutes to make. Using a thin center punch in the guide holes makes a good mark on the post that is easy to see and helps the bit get started in the right place. The jig can be used for both right hand and left hand setups.
/ Show What Tool You Made* #477
When we worked on aircraft our trick was to wrap tape on a finger tip sticky side out and stick the machine screw or nut on the tape.
Worked just fine.
/ Show What Tool You Made* #478
Worked just fine.
Old, hardened Crisco works great also.
hugs, Brandi
/ Show What Tool You Made* #479
SpannerWrench.jpgWhen you need a spanner wrench and don't have the right size.
2006 Freightliner Tuscany 4077 40ft Class A Motorhome (A64557)
2006 Freightliner...
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2019 KENWORTH T880 (A65643)
2019 KENWORTH T880...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
GUIDED FISHING TRIP FOR TWO (A64277)
GUIDED FISHING...
