Wondering why one couldn't slide pipes through the holes in the existing slats. For sure, it would add weight, but it would be fairly easy: right diameter and some caps on threaded ends would hold the pipes in there. Seems that that could fill in a lot of the gaps and allow picking up rocks and the like.
Quick comment on the notion that pallet forks can suffice for grapples: do some stuff with your hands w/o using your thumbs.
I really would like to have intermediate tines. They would be great for scooping up rocks and firewood and other smallish objects that are likely to fall between the 8-9" distances of the main tines. Not necessary for brush or logs or stumps etc but boy would they be nice for picking up rocks.
EA might consider making the welded tabs an extra cost option. Many folks aren't prepared to take on a welding task.
Offering the slats as a customer installed option is the most economical method, for EA and the customer.
Yes, offering them as a factory made option is something Ted and I are pondering/discussing, BUT....
It would require either:
1. Having extra "slat ready" grapple inventory on hand.
2. Welding the tabs to all grapples whether they'll get slats or not.
3. Special order production.
I think #3 makes the most sense, but we'd need to take this into consideration:
In this case, if someone wanted a 60" grapple with slats, we'd have to build another 60" grapple, even if one without tabs is already in inventory.
Travis
What do you have on the back of that machine in the second photo? looking like a flail. Which model ?
Still loving my grapple from you guys!!!!
From my point of view, just put the tab and slat together and fit in the grapple and tack it. It would be pretty easy to get it lined up right that way it would seem to me. Of course if they all came with the tabs welded in from the factory and the slats were just a bolt on kit you either ordered with the grapple or at a later date, that would be easiest of all. But this is bound to add cost to the base grapple to have those tabs fitted to all of them whether a person wanted the extra slats or not.
Travis
Interesting idea. The problem would be if that expanded metal behaved a bit too much like a bucket and held dirt like a sieve where lots of vibration would be necessary to clear the loam. I guess there are probably various grades of expanded metal though so maybe if the "holes" are big enough it would work.How about a sheet of heavy duty flattend expanded metal, framed on the top and bottom with flat stock so it lies just behind the back the last tine barb. You can add some kind of fastener or welded loop that could line up with the holes in the tines and be bolted into place. This way it could be removeable. IF, the distance from the rear tine barb to the back of the lower frame is the same on all the grapples then you would only need to customize the width based on the grapple size. This could help pick up the smaller wood scraps, stones, etc. Just a suggestion.
Agree. It's always a pleasant surprise when an old stump just surrenders without a fight. The other circumstance is when lateral roots have been ripped with BH ripper and there is a long enough section of trunk remaining to push the stump over before grabbing with the grapple.Some sort of root rot on that tree if you pulled it out?
