Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #3,741
You would be better off to rent a true stump grinder. They do very fast work and can take them deep enough to have grass grow back over.
We had a guy out this summer to grind out 4 stumps (and what was the base of a large bush, probably 4' across) ranging from 6" to 3' across. Took him about an hour and a half with a self propelled tracked stump grinder to grind everything down to 6-8" below grade. IIRC, he charged around $400 and it was all in little pieces when he was done.
Aaron Z
/ Let's talk flail mowers #3,742
OK folks my search is almost over. I have found two units that will clear my rear tires to the pivot points. The only units that will work for me need to have an outboard gear box so I can sit on the road to mow down the bank. The two units are Maschio Giraffetta 160SE and possibly the Teagle (Berti made) TA/L 145. I know many of you have these brands, How are they holding up?
BTW if you are considering a ditch bank/verge mower, double check the pivot point location. My tractor is not that wide, but many brands and models fall far short of shifting wide enough to mow a ditch bank and stay on the road to be safe due to the inboard gear box arrangement.
Jack Yaun, just a suggestion and I hope you dont mind, but you may wish to look at your swing arm lengths to get your mower head out further. This may take an outboard gear box arrangement though. In my case I needed 32" (CL PTO to outside of tire) as I am running r4 tires. I hope this helps in bettering your product line. Uwe in California, was excellent to work with, but the units you provide him wont swing wide enough. Possibly take a look at the TA/L 145 geometry as it gets 10" to 12" further out than the Maschio if I read the information correctly.
Thanks for everyone's help, especially leonz. This man is a gem folks - you cant find better help here. Leon - I hope your hat fits in the morning :D
Well my little tractor passed the lift test with ease. I hooked up to a Kubota RA 1035 rotary hay rake (926lbs) picked it up with ease, then two guys climbed on the rear of the rake (about 500 lbs) and still no issue, so I can handle the weight reasonably. There is a little front end bounce, but with some ballast added to the front bucket I should be in good shape for transport mode. I remember seeing some old suitcase weights at a dealer in a big pile. Ill see what they run. I can tie them to the bucket through my clevis hooks so the will not bounce around.
I also want to say that Iowa Farm Equipment, Iowa Farm Equipment , has been a great help in working with me. If you have questions please talk to Andrew. he has excellent knowledge on his products. I will be ordering from them once we figure out which unit will be best for my needs . They have good pricing and answer their phones and emails. A+ on customer service in my book. More later on the final decision.
/ Let's talk flail mowers #3,743
I wouldn't DELIBERATELY grind a stump with a flail, although I have been known to bump a few stumps and take some chips out of them.
Same with the Harley rake, it will leave its mark but would take a long time and a lot of bump 'n jump to make a big difference.
They will both chew at surface roots a bit, but grinders are for grinding, mowers are for mowing and Harley rakes are for seed bed prep and LIGHT grading.
I think that's what I meant I don't plan to just sit on top of the stump and try to grind it but I have limbs that have fallen and been rotting and I may go over them like maybe Up to 3 inches but I feel like they're fairly rotten I just didn't like the way my rotary cutter was sounding lots of brambles and heavy Doveweed but there will be some sticks
/ Let's talk flail mowers #3,744
Most things like old rotten tree limbs hidden in the grass just make a racket as you "mow" over them. The only thing I ever had trouble with (other than pieces of metal or hoses) was a chunk of split firewood that found itself in the middle of a field. The mower lifted it and it jammed between the rotor and mower body stalling the tractor. Took a while to unjam it by manually counterrotating but there was no damage.
/ Let's talk flail mowers #3,745
Thanks
Have you ever changed the knives or blades mine has the medium I want the hammerhead
/ Let's talk flail mowers #3,746
Thanks
Until I switched clevis type, I lost knives routinely in my rocky terrain so there are relatively few original knives left if any by now. I've never switched knives though, I just replace the missing ones with Flailmaster knives and clevises.
/ Let's talk flail mowers #3,747
Ok
So it's OK to mix the type of knives mine look like a duck's foot
/ Let's talk flail mowers #3,748
Ok
I'm not sure if I would make that assumption. To keep proper balance all the knives/hammers need to be of similar weight. If you havent already done so, you should read the entire thread of posts as this has been discussed several times.
Hope this helps. I'm sure someone with more knowledge will explain better.
/ Let's talk flail mowers #3,749
Ok
NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! mixing knife types is not a good idea period.
It guarantee's premature bearing failures for the Flail Mower Rotor Bearings
because the G force created by the orbits of the two different knife styles which
creates huge uneven G forces along the Flail Mower Rotor that are transmitted to
the Flail Mower Rotor Bearings.
The heavy cast vineyard and orchard knives have a specific mounting system that is
either a Piano Hinge Mount or separate mounting stations for each hammer knife
using a nut and bolt.
The INO flail shredders and others either have a spiral mount circling the Flail Mower Rotor
or horizontal with overlapping rows hammer knives.
The scoop/duck foot knives are not hammer knives. They are formed steel knives that are
stamped and or heat treated and then ground.
The Cast Italian made hammer knives are heat treated with a sharp edge than can be
used for sod mowing or brush mowing.
The Chinese Made forged hammers are a "modified scoop knive" with a low weight and low
mass compared to the cast hammer knives made by the Italian metal casting companies that
make spare parts for agricultural machinery.
/ Let's talk flail mowers #3,750
Ok
No that is not what I said. I replaced lost knives and clevises with the same type from a different manufacturer. In my case the new clevises weighed a bit more but the knives were a pretty close match.
/ Let's talk flail mowers #3,752
I'm learning a lot from this forum thank you all so much
/ Let's talk flail mowers #3,753
Well my woodmaxx is on a truck in Nashville scheduled for delivery on monday. Sadly I'll be on a plane by then. It will be a week or so before I can pick it up...
/ Let's talk flail mowers #3,754
I'm very interested to hear how the Woodmaxx works for you. Which knives are on it?
I replaced all the side cutters on my Value Leader with scoop knives and while it does seem to cut a little bit better, I get some nasty shuddering with them too. It's not vibration due to imbalance or anything, almost seems like they are picking up too much material. Just mowed a couple of acres of 8-10" grass yesterday and it works smooth while going in the direction that the winds have laid the grass down, but coming back where the grass is laid towards the mower it seems to grab too much and I get this shuddering vibration at times that is no good.. I have it set fairly low right now and will try it a bit more raised up another inch or so, but for now it looks like the scoop knives will have to come back off..
/ Let's talk flail mowers #3,755
I ordered it with scoop knives, but also ordered a set of side slicers plus some spares of each...
It will be a week + before I can try it. I'll certainly let everyone know how it works. Things have been so dry that I don't have much grass to cut, but I do have a couple of acres of weeds Iabout 12in high to try it on.
I wonder if you should slow down more to allow the mower to cut more freely or are you already at the lowest speed? I haven't owned a flail before, but have been told not to expect high mowing speeds because of the finer mulch compared to a rotary.
/ Let's talk flail mowers #3,756
Yeah, what sidecarist said. I think you have to slow down. Not sure what kind of grass but I did some mowing for a neighbor this past summer and I was amazed at how much slower I had to run because the grass was MUCH more dense than anything that I have: not enough tractor power (23hp at PTO running 5' rotary) to keep the rotary spinning hard at a higher speed. Had to allow more time for the grass to be chopped up enough to settling down and under the mowing deck as I moved forward. I suspect stuff like I mowed would be like mowing sparsely spaced 1/4" brush in which you'd have to slow down (and know why). I don't think that I'd want to mow this way on a regular basis; if I had to I'd most certainly look for a different arrangement.
/ Let's talk flail mowers #3,757
You need to raise the cutting height of the mower to avoid what you have experienced as the pressure gradient created by the flail mower rotors reverse rotation is pulling up all the grass and brush and the full width of the scoop knives is contacting the brush as the mower advances and slicing as much as they can slice as the mower travels forward.
Your side slicers would have less difficulty when mowing but that depends strictly on the tractors forward speed and the PTO speed at the 540 RPM rear PTO engine speed to power the integral flail mower.
Until you have this acreage mowed to a 2 inch height you will have issues with the brush depth and height.
/ Let's talk flail mowers #3,758
I have used the side slicers and hammers on both my Value Leader and Farmer Helper (really same) and much prefer the hammers. Have wondered about scoops, but also if they could be mounted differently, like the Clovis mount. To be honest I mow slow, usually in low low. Speed just isn't a concern and and in some areas just too much slope for low high or whatever it might be called.
/ Let's talk flail mowers #3,759
Because we can buy gear box from professional gear box factory, so the rotor is the most difficult part for us mower manufacturers.
There is ISO international standard of mechanical vibration, flail mower rotor is G16 grade
so after calculation, your mower, I think you mentioned it is AG model, right? so I called it as BCS model in my factory.
it means the unbalance weight is totally 3 gram on the rotor. This international standard is quite harsh.
So I don't think any mower manufacturer could really make all the mower like this. I bought some foreign brand mowers these years, all of them are top brand in the market. Obviously, different factory set up different standard for their rotor vibration, from 50 gram to 200 gram. Because I don't buy hundreds of these famous brand mowers, and I don't have contact in these foreign factory, so I cannot know their exact standard. But I know the standard of the Chinese mower manufacturers, normally we define it as 100 gram on rotor, but I m sure very few of them execute this strictly. So I set up standard like this:
1. 30 x ISO standard, for example, BCS model, I define it as 90 gram this year(next step is 20X).
2. at most two pcs balance weight block on each rotor end this year(next step is one pcs each end)
3. fully weld balance weight block on rotor end
And the most important thing, I employ third-part person to inspect rotor balancing and record it, to avoid worker's mistake.
I m now use 1240 gram hammer on BCS mower.
For the hammer, I started to use forging hammer on all of my mowers two years ago, because at that time, I found the casting hammer has bigger weight difference than forging hammer. For example the gram hammer on EFGC mower, casting hammer has nearly 35 gram weight difference, forging hammer has nearly 20 gram weight difference. Because forging hammer doesn't increase much cost than casting hammer, so I decided to shift all the mowers to use forging hammer. For the price and technical reason, hammer factories cannot produce very small weight difference as I expected. So I turned to another solution, I set up weight different standard in my factory, worker weigh all the hammers before they assemble on rotor, so the rotor has the hammers in same weight range, each range has 10 gram difference. And I has record for all the mowers used which weight range hammer.
Anyway, I only started this business 3 years, I realize Chinese mower fall behind a lot than foreign top brand mowers, but I m trying to do my best and keep improving, wish I can catch up or get close in some years, there are still 3 or 4 decade before I retire. :):):):):):)
Thank you for the reply Jack. I have been away for a couple of weeks and thus my late reply.
Your information is valuable to show us how to evaluate and compare the quality of mowers. My mower and some similar mowers that appear the same as the Victory brand likely have rotors rejected by your inspector. The mowers on the Victory website look well finished and are no doubt higher quality than my "no name" mower. I think your friend at Victory mower should add a section to his website documenting items you stated here. His prices look very good but such quality control information could give his product another positive selling point.
My mower has cast hammers averaging about 1,040 grams and my sample size of 36 blades ranged from 1,000 to 1,070 grams. The blade cutting width is about 140 mm. My blades appear to weigh 200 grams less than yours.
I adopted a strategy similar to yours to get the weights within a few grams. I ground each set to within a few grams of the lightest blade in the set. I will likely put a maximum of 50 hours on the mower each season. I will change out the complete set at the start of the season and recondition the old set. As I gain experience I find I am getting better at avoiding blade damage.
Thanks again for showing us how to evaluate mowers. I think many would be happy with the Victory mower.
EDIT: I forgot to mention the Victory mower's very good manual which I copied for my mower (which had no manual).
/ Let's talk flail mowers #3,760
To be honest, I wrote those manual almost three years ago, although I spent complete 3 months to make them, but I think they are too old when I look them now, sooooo many mistakes in them. So I m working on new manuals and you will see them nearly 3 months later.
Most Chinese company would not like spend time on manuals, at least I didn't see any other Chinese implement company has better manual than mine, I m sure some of them will copy mine soon. I m fine with this, good ideas worth spreading.
Your AG mower is one of the heavy duty mower in all the Chinese mowers. Enjoy it.
3 Point Hay Forks (A62613)
3 Point Hay Forks...
(3) New 23X8.5-14 SS tires on 6-lug John Deere compact tractor rims, Coal Valley, IL (A65640)
(3) New 23X8.5-14...
2017 PETERBILT 579 (A65643)
2017 PETERBILT 579...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
2021 KUBOTA RTV-XG850 SIDEKICK RTV (A64277)
2021 KUBOTA...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
