Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #3,501
Got some decent mowing done today and took some pictures of the area I'm having trouble with.. The first picture is what it looked like after I mowed days ago with the mower high and how the tall stalks are still standing...
Second picture is after I just went over it again with the mower dropped low, got a lot of them but a lot still standing. The pass I just made is to the right of the tractor, and wasn't as heavy as what is in front of the tractor..
I later raised the front of the mower more with the top link and it seemed to do quite a bit better as I had thought it might, I may raise it even more but have to check the max length on my top link as I have it out pretty far right now..
Dan
/ Let's talk flail mowers #3,502
Dan
On my FM,,, the top link could be removed during operation. it is literally doing nothing, it is only along for the ride.
The top link only comes into play when the mower is lifted, as during transport.
The three point hitch arms adjust the height of cut.
Hmmmmmm,,,,
Now, this is mine,, different FM's may be different in how you adjust height.
/ Let's talk flail mowers #3,503
Hmmmmmm,,,,
I think that is mostly true but may not be completely accurate. Think of the flail as pivoting around the rear roller while being dragged by the 3PT arms. If the 3PT arms are set so the weight of the flail is on the rear roller then the toplink length does allow slight adjustment of the position of the cutting rotor/blades. Lengthen it and the front of the flail will rise up a bit, shorten it and the flail will drop a bit. I don't fiddle with the toplink much as the difference in cut height it makes is measured in fractions of an inch. I just leave it in a middle position in the toplink mount slot so the mower can pivot as it likes.
/ Let's talk flail mowers #3,504
Hmmmmmm,,,,
My hydraulic system has no down pressure, so with the 3 pt dropped all the way down (which it is when I set the mower height with the top link) when the mower encounters a rise the whole system moves up and keeps the mower relatively flat (where it was set up). With no top link the roller would rise up, which dips the cutters down. I've only used a Bush Hog for a couple of hours on a neighbors compact tractor with a quick hitch and the top link unhooked, and found that I needed to keep a hand on the 3 pt height control and keep adjusting for changing ground. With my setup I drop it down and it just follows the ground. Per the directions on mine the roller height is changed for larger height adjustments, and the top link is used for finer adjustments. Also, as I described earlier with the tall stalks that weren't getting cut I believe mine will work quite a bit better with the back low and the front raised to expose the material to the cutters better and not allow it to be pinned down and stay under the cutters.
A question I forgot to ask last night, I'm having trouble with grass wrapping up on the roller and jamming the roller with the scraper bar. My scraper is off the roller a bit, are they typically set pretty tight? I need to try something different with that (either adjusting or removing the scraper) before I go out again today, had to stop several times in an hour last night to clear it..
/ Let's talk flail mowers #3,505
I will have to disagree with the above a bit. I have a hydraulic top link on my 3000 and by just adjusting the top link I can go from digging dirt to a 2+ inch cut with both my flail mowers. I put the roller adjustment in whatever holes positioned the roller just below the skid rails and set the 3 point so it was level. May not be the accepted way to adjust the cut height but works for me.
/ Let's talk flail mowers #3,506
If your top link is still hooked up and you are using the 3 pt arms to adjust height then to go higher you are lifting the mower off the ground instead of letting it ride on the roller, which is not how it was designed to work and probably quite hard on the tractor with ~800 lbs (whatever yours weighs) bouncing around on the 3 pt arms.
/ Let's talk flail mowers #3,507
Oh, well,,
I am willing to bet,,, that, with a FM, more people use a piece of chain as a top link,,,
than people who successfully use a top link in compression to control mower height.
If it works for you,,, enjoy.
/ Let's talk flail mowers #3,508
Dan, not going to be allot of help as I really do not understand why you are having so much trouble cutting that field. I just cut 3 acres I had let go all summer that was every bit as tall as yours and other than having to go slow it cut just fine. I think grass getting around the roller is a direct result of the mower not cutting the grass in the first place. I may have missed if you said and not sure exactly what I am talking about but if you have finish knives on that mower, that may be your problem. Both of my mowers have single spoon looking cutters that will chop up just about anything.
/ Let's talk flail mowers #3,509
This might be true after I rebuild the lift cover over the winter and maybe the reason I get away with it is because my lift isn't working as well as it should. It will only go about 1/2 way up with a load and my roller never comes off the ground. I have to pull the top link all the way in and go to full lift to get the roller off the ground.
/ Let's talk flail mowers #3,510
Which is better equipped to control the position of the (in my case 1,100 pound) weight of the FM?
Two massive 3 point hitch arms
or
One spindly top link
I do not lift the mower off the roller until transport,,, that is the purpose of the slot for the top link.
During mowing, the roller is in contact with the ground 100% of the time.
On another note,, my FM will mow hood height weeds, grass, etc,,, FLAT in one pass.
(Note: in that pic, the tractor is connected to a blade,,, no slot for the TL)
/ Let's talk flail mowers #3,511
If you are using a floating top link that wasn't previously mentioned that would of course make a difference, I thought those were more common on rotary cutters than flails as I didn't see them on flails as I shopped... With my mower rigidly mounted (no floating link) the whole system moves up and down to follow the terrain and keeps the cutting height where I set it, a floating link would allow the mower to pivot more so I don't see where I would benefit from it? A rotary cutter that sticks out much further needs to float so the back can drop as the tractor crests a rise, but then of course you can ground the **** out of it on the other side if you aren't actively messing with the 3 pt height as you mow.. Are others using a rigid or floating top link?
/ Let's talk flail mowers #3,512
Don't claim to be an expert, as the New Holland 918H is the only flail I've ever owned or used. Both the top link and bottom arm pin connections are slotted, presumably to enable float? The slots allow the mower to rotate slightly in use. Has worked well for 16 years! VicDSC_0006.jpg[ATTADSC_0008.jpg
/ Let's talk flail mowers #3,513
Don't claim to be an expert, as the New Holland 918H is the only flail I've ever owned or used. Both the top link and bottom arm pin connections are slotted, presumably to enable float? The slots allow the mower to rotate slightly in use. Has worked well for 16 years! Vic<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=480563"/>[ATTA<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=480565"/>
That's how the Caroni is set up too.
/ Let's talk flail mowers #3,514
Slots for the lower link arms would be perfect for a centered mower.
not so perfect for an offset mower,,,
On my tractor, the right arm can be raised by hand independent of the left.
if you raise the left by hand, the right will go up at the same time.
So, I have side vertical oscillation ( ? what would you call it ? ) in one direction,,, only.
So, if my mower hits a mound on the right side, the mower will tilt to follow the ground.
If I hit a mound with the left side, the entire mower goes up.
/ Let's talk flail mowers #3,515
The scrapers are always close to the roller to peel off wet sticky grass clumps if any to keep the mowing height accurate. Do not hesitate to remove yours for a while until you have ridden herd on your acreage and knocked everything down.
/ Let's talk flail mowers #3,516
Slots for the lower link arms would be perfect for a centered mower. not so perfect for an offset mower,,, On my tractor, the right arm can be raised by hand independent of the left. if you raise the left by hand, the right will go up at the same time. So, I have side vertical oscillation ( ? what would you call it ? ) in one direction,,, only. So, if my mower hits a mound on the right side, the mower will tilt to follow the ground. If I hit a mound with the left side, the entire mower goes up.
The Caroni lower attachment points are not exactly slots. There are short pieces of metal that act as a linkage between the mower body and the 3pt arms. It allows and inch or so of movement. When you offset the mower manually, you just move the linkage pieces so the same flexibility is present. The topping lift attachment point is a true slot.
/ Let's talk flail mowers #3,517
Here's the way my Mott SHD88 came, used to be owned by a town in NY state. Rigid top link but lots of leeway on the 3pt arms. Lift links are replaced w chains. Mows quite even, and I adjust the cut height w the 3pt arms. A bit of work to replace the std lift links, maybe 10-15 mins.
Many ways to skin a cat, evidently.
Jim
/ Let's talk flail mowers #3,518
Well....some frustration is setting in...partly weather related (keeps raining), partly mowing attempts... Sunday evening mowed for about an hour and a half with pretty good results, although with the mower dropped lower the tractor was working pretty hard (18-24" grass and weeds, mowing in 2L). Went out yesterday afternoon and wasn't having much luck, lots of grass wrapped up on the roller and the tractor seemed to be running a bit hotter (later cleaned the radiator off) and down on power as the mower kept bringing it to its knees...at times even in 1L. Rained last night so I waited until ~2pm to try a different area today and got about 200 ft before the entire roller was wrapped with so much grass it locks the roller against the scraper and I had to cut it off. The scraper doesn't adjust any closer than about an inch and is set to pivot a bit, so not really sure what it's purpose is... I've noticed the grass behind the tractor looks more cut than mulched also, don't know what it should look like but there's some pretty heavy stuff left behind (even after mowing when dry). Maybe the grass just can't be wet at all with this thing, which would be fairly limiting as we've had an unusually rainy year. Gonna hook up with a neighbor later who has a sub-compact Massey and 4' Bush Hog and maybe put the flail on his tractor and/or the Bush Hog on mine to try and determine whether my tractor or the mower is more the problem.. His is small hp-wise for the flail, but if it runs it pretty cleanly at slow speed then my tractor must not be healthy, same test if I put his small Bush Hog on I should be able to romp and stomp through fairly heavy stuff, if its pulls the tractor down then again diagnosis not healthy...we'll see... :confused:
/ Let's talk flail mowers #3,519
Dan,, I wish you would post some pics,,
I have never had a single blade of grass or anything growing wrap on any part of my FM.
(NOTE: I can NOT say that about the neighbors high tensile wire fence!! :laughing: )
I do not have any sort of a scraper,, :confused: so I am intrigued to see what that is,,
Tractor power may be the answer,, who knows what is happening at slow speeds.
My FM is getting seven PTO HP per foot.
The FM has only slipped the belt once ( I think the belt was a little loose ), BUT,,,
it has NEVER bogged the engine down at all.
I mow pretty fast,, 6 MPH most of the time.
I run about 4 MPH on a couple hilly places. The slower speed just feels more comfortable.
If you are bogging down,, at that slow speed,,
your tractor might only be producing less than 2-4 HP per foot. :eek:
A friend has a 4 foot MOTT trailer mower with a 10 HP Harbor Freight (maybe Northern??) engine,,,
He cuts like crazy with that little mower,, it will do pretty tall stuff.
Maybe you need spark plugs,, and a tune-up?
/ Let's talk flail mowers #3,520
Something sure isn't working properly. Either the belt is slipping and it isn't cutting or it is slowing the PTO down to where it isn't cutting. You should not have anything near long enough to wrap around the roller coming out the back of your mower. I would like to see a photo of the drum, knives and roller.
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
SDLanch SDLGC80 (A64127)
SDLanch SDLGC80...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
