Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #3,401
Hey Leonz,
Thanks for the reply. Here are a few more pics of the overall setup. These are all I have for now. This is how I pulled the mower out of the field where it'd been rotting for years. I have a brush hogging business and stay extremely busy and have very much enjoyed working the flail (the first I've ever owned) into the repertoire for the right jobs. Do you think at one time this model was supposed to have caster wheels? I don't see any mounting holes for them. That being the case, height adjustment advice will be appreciated! Great idea on tracing out the links and sending to FlailMaster. In fact, I got on their site and sure enough I think I see my links. Good thing I didn't order up a whole set of the wrong ones all at one time!
/ Let's talk flail mowers #3,402
If you used a piece of threaded rod you could just build a metal frame and use that for leverage. Bolt under mower then rod through the frame and a tightening bolt on the outside of the frame. That would allow very gentle but strong "persuasion". It would be ideal if you had a chunk of big steel square tube and just drill a couple of holes through that as the pulling frame. You could shim the square tube off the mower deck a bit so any spring back could be accommodated.
Another thought that may or may not work... Find a stump, back up to it. Brace a chunk of wood between the stump & the back side of the hood. Back up a bit more so the wood pushes the dent out.
Both also good ideas!
I'm not the best with this machine yet, so I'd likely have much more finesse with the force needed using metal and welding rather than brute force of using the machine to straighten it out.
/ Let's talk flail mowers #3,403
Hey Leonz,
Welcome to the Flail Mower Nations SgtBoz,
Your Ford Flail Mower does not have the mounts for caster wheels sadly.
OK, with that said you have to decide if your going to keep it as a rough finish mower
or rehang Side Slicer kinves on it to make it a better dual purpose mower/shredder.
The scoop knives will not allow you to recut material unless it so dry it shatters.
If you are intending to keep this beautiful flail mower you need to properly adjust it.
You need to adjust the top link using a torpedo level on the V belt guard assuming it is still in good shape and flat.
Normally this is done at the gearbox but as you have a bevel gear driven flail mower the round gearbox case will not let you do that.
Once you have the mower level-Providing the lower links are properly adjusted and locked and cannot move to affect the geometry of the quick hitch you will have it set up properly.
The rear roller must be in contact with the ground at all times unless you are transporting it.
You also need to make sure the hydraulic adjustment is "locked in place" while using the flail mower as well
otherwise the mower will nose dive and make break or damage a few scoop knives.
Your Ford Flail Mower has been used a lot. whats left of the skids is pretty much gone.
As long as you grease it and take reasonably good care of it checking for wire or garden hose snakes
wrapped around the bearing housings you will have it for a long time
Be very sure to dig out any rubber dust under the V belt guard to expose any hidden grease fittings and send an E mail or call Messicks to order a manual for it-they are very good with flail mowers and the various makes and models that have been made over the years.
As far as greasing goes no more than 5 to six pumps on the Flail Mower Rotor bearings every 6-8 hours-strictly depending on the conditions. I do not remember if the Ford Flail Mowers rear rollers have bronze or ball bearings on them.
Be sure the snubber pulley(flat pulley) moves easily. I do not see a spring for it in your pictures. There should be a spring with one end attached to a hole in the idler arm and the other end attached to an extended bolt mounted inthe side weldment as your flail mower does not have a crank tensioner for the snubber pulley.
If you have not changed the oil in the gear box be sure to change it in the spring or after mowing season is done.
Happy Mowing
Pronovost or not at all!!
Only 19,500 rotary cutter/mowers to go
Still looking for a three point hitch Mott Flail Mower with the Wisconsin V 4 engine in any condition.
/ Let's talk flail mowers #3,404
Excellent, excellent advice. Thank you. I've learned lots from reading all your other posts and have modified my use and maintenance accordingly.
Is this the side slicer knife to which you refer?
HEAVY DUTY BLADE - FORD 917 COARSE CUT
I hope so because they're lots less expensive than the single-piece blade I've been using (and mostly LOSING!)
/ Let's talk flail mowers #3,405
My old 917 came with mounts for some casters behind the roller. It wasn't attached when I got it & the rims in a box that came with it were rotted years before I got them. I've never installed any of those caster parts or felt the slightest need to do so. It cuts just fine & is a more compact unit without em.
/ Let's talk flail mowers #3,406
First time poster and new member of the nation here, I've read parts of this thread as I researched different types of mowers over the past couple of months, just finally settled on a flail for sure. Wanted a Caroni TM1900, but with $390 for shipping I didn't want to spend that much total ($2300). Ordered a Value Leader EFG-175 yesterday, Betst has too many in stock and they are actually cheaper than the EF-175 right now with heavier bearings and more volume. Came to about $1620 with liftgate delivery and $100 extra for 2 more years of warranty. Should be here early next week, can't wait! My questions are more about my tractor as it's my first and I haven't hooked anything to it yet. I bought a '53 Ford Golden Jubilee and I've been learning all I can about the pto, clutch, hydraulics, etc.. Since I have 3 pt. hydraulics with no down pressure, once I put the mower on the ground I'm thinking it will pretty much follow ground contours up or down? I'll have a lot of fairly flat areas, but there are a couple of ditches and septic mounds where I think if I back up and set the mower down either at the road edge or top of mound and drive forward it will hopefully just follow the curve of the ground. That sound right? The learning curve will ramp up sharply next week, but if anyone has any info or advice it would be appreciated. :thumbsup:
Thanks,
Dan
/ Let's talk flail mowers #3,407
Excellent, excellent advice. Thank you. I've learned lots from reading all your other posts and have modified my use and maintenance accordingly. Is this the side slicer knife to which you refer? <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=478482"/> HEAVY DUTY BLADE - FORD 917 COARSE CUT I hope so because they're lots less expensive than the single-piece blade I've been using (and mostly LOSING!)
Yes. And you need a pair for each station so they are cheaper but not that cheap.
/ Let's talk flail mowers #3,409
Since we're talking flails, here's what I did with crappy blades and a Kubota L3800 the other day.
/ Let's talk flail mowers #3,410
Also new kid here, actually old geezer but what the heck.
I have and use regularly two flail mowers to cut the big part of my 7.5 acres. An old Ford 6 foot and a John Deere 7 foot I pull with a Ford 3000. I rescued the Ford from the weeds of my neighbor property. He had written it off and gave it to me. I completely rebuilt it with new bearings all the way around and new flails where needed. It was badly maintained and abused.
Bought the JD at an auction for almost nothing because the roller was bent. Don't let anyone tell you a roller can't be straightened, just takes a little ingenuity. Got the I beam from the same neighbor I rescued the Ford from. It was left over from a shop build he had done years ago. Welded a couple plates to the ends so I could bolt the roller supports off the mower to. This allowed me to rotate the roller to check it for run-out between tweaks. Jack stands were used to support the roller when I removed the plates for tweaking. Held the ends with chains, cut slots in the I beam to hold the chain ends. A big jack and scrap piece of U channel under the roller finished off the straightening press. The string taped to the top was my is-it-straight-yet indicator.
The roller straightening process was successful and have been using the J.D. mower for the last two seasons.
/ Let's talk flail mowers #3,412
Hat tip to my fellow Okie in Catoosie. That straightening rig is ingenious!
/ Let's talk flail mowers #3,413
Thanks,
Dan
Dan
Can you please take close up photos of the units construction when you get it and let us know on the performance. I was looking at their units too, but was concerned on the Chinese quality. I was looking at this one http://www.value-leader.com/65-ditch-bank-flail-mower-w-hammers-installed-agl165/
Thanks
/ Let's talk flail mowers #3,415
Well I finally have a bit of good news on my project mower. I made sure all the bolts were tight that I had replaced and done a few more weld repairs yesterday along with changing out the gear box oil.
I had cut a little area with my rotary mower a few days ago and there was some places where the grass had stood back up and of course the windrows from the brush hog. I absolutely can't stand those windrows.
I thought I would hook up the flail and take it for a test run. I hooked it to the draw bar on the lift arms and checked the height of the cutters on the concrete. Went to the cut area and was pleasantly surprised at how smooth it ran. There still may be a slight vibration but it is much much better than before. It sure took care of the grass standing up and the windrows. I am still pondering adding the balancing beads to see how that works.
I am mostly going to use this machine for seeding food plots into killed grass or cover crops and I think it is going to do an excellent job. The even distribution of the clippings is what I'm after for a mulching effect. It will get tested on that in the next week or so.
/ Let's talk flail mowers #3,416
Ozarks, my Caroni vibrates and
Makes a racket so it's not like flail mowers are supposed to behave like sewing machines. They vibrate more than finish mowers because they have more rotating mass. I'm used to normal vibrations and can tell when I lose a couple of knife sets because the vibration changes.
/ Let's talk flail mowers #3,417
Ozarks, Glad you got your mower going I sure do like the cut quality of mine and sounds like you can see the difference too. It's slower operating than my rotary cutter or finish mower but I feel as you do about those wind rows, hate them. With the wind rows it's looks better before I cut but with the flail it's looking better everytime I cut. The old field roads are starting to look like runways almost.:thumbsup:
/ Let's talk flail mowers #3,418
Dan
Thanks
Will do. I was more concerned early on, but found enough info to not really be worried about it. Betst stocks repair parts, and as long as they stand behind the warranty it comes with 2 years and for $100 you can add 2 more years. Delivery is scheduled for Tuesday. :thumbsup:
/ Let's talk flail mowers #3,420
Well I could make it move with a small amount of weight. I cut all the weights off that looked like they were not factory to get it ready for the dynamic balancing I thought I was going to get. I imagine most of my problem was the wrong bearing. It was letting the shaft get up into the shroud even.
I put the new bearings on and installed the shaft today. I couldn't turn the rotor as one of the grass guards was bent and dragging on the rotor. I will work on that tomorrow sometime. I called all over today looking for someone to balance it with no luck. I'm going to start trying to static balance it and see how close I can get.
To be honest, the static balancing which you are doing is totally unacceptable for industry. This way cannot check out many other issues which will affect rotor shaft balance, like hammer bracket condition, aligned holes for the bolts on hammer bracket, weight and centrifugal force difference of hammers, etc.
207270 (A52708)
207270 (A52708)
2015 FORD F-350 XL SUPER DUTY 12' BOX TRUCK (A62130)
2015 FORD F-350 XL...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
