My NX6010
/ My NX6010
Got to the bottom as to why my tractor smoked its first battery. The alternator was charging above 18v at 2000 rpm and dropping down to regular charging voltage as it approached idle. Eventually, the condition flagged a high voltage error code, but it was also flagging the check engine light. The check engine light would first come on at 2,500 rpm, then go off below 2,500 rpm. Then upon the the next cold start, the check engine light was flagging at 2,000 rpm and then off below 2,000 rpm. Then on the next start which was me loading onto my trailer to chase the tractor off to the dealer, the check engine light was flagging at 1400rpm.
The service manager was able to eventually figure out the alternator's integral regulator was screwing up, but he told me he had some time into it puzzling out the problem, as the fault would only occur when the machine was moving and so static testing didn't reveal the fault.
/ My NX6010 #1,162
Glad you got that resolved... voltage issues manifest themselves in many ways. My scissor lift starts, runs and drives fine, but for some reason if the battery is somewhat low all of the functions randomly don't work.
This thread reminded me on something I wanted to follow up on. My tractor popped out of M twice for the first time the other day. I was running the Harley Rake in 2wd and it made a rather big "bang" and popped out of gear. Took me a second to realize what had happened, initially I thought something very horrible happened to the hydro. After that, I switched to 4wd as I was slipping a bit and finished the job, not sure if it's not as likely to happen in 4wd or if it was just dumb luck. I am in love with the Harley Rake.
/ My NX6010
Okay, if your tractor is doing what my tractor is doing, the shift lever physically moves from low or medium forward to neutral as you sit in the cab.
When it pops out of gear it makes a loud bang noise and the shift lever moves itself from in gear to neutral.
I think it is either a lack of undercut on the gears combined with oil temperature, and loading-unloading issues creating the exact conditions to pop out of gear or it is a bent or wearing shift fork from new. My conjecture, nothing proven.
I'm using Mobilfluid 424 which has been fully changed out twice since I received my tractor with 7.7hours on it.
I still have a camera aimed at my shift lever to prove the fault, which is a major PITA, but I get it, there must be some type of evidence in order to justify lifting the cab off and splitting the machine in half to inspect the gears and shift fork.
/ My NX6010
I made the 170 mile round trip to pick up my now repaired tractor. Sadly, once I got it back to the new parcel, I immediately realized that when I press the brake pedal, the headlights now come on. I'll call the dealer in the morning. Hopefully, the tech that worked on the machine can shed some light on the issue.
/ My NX6010 #1,165
I know you like problem solving, Eric, but hopefully you won't have to sleuth this one out yourself! Curious to hear what happened.
BTW, was the shop able to repair the alternator, or did they replace it?
/ My NX6010
The alternator was replaced.
I have no shop or area to work on anything right now. The alternator was going full field sending over 18 volts into the machine when revved up. It set a high voltage code. I only became aware that something was happening when it started intermittently triggering the engine check light, at which point, lacking the computer scan tool and software, I brought my tractor into easiest-for-me-to-get to Kioti dealer. I had thought my battery died from vibration, but in hindsight, it was more likely cooked from high voltage. When I picked up the machine we were talking about what 18 volts into the electrical system could do to the rest of the electrical system.
For all I know, a relay is stuck on causing some kind of weird power or feedback loop.
/ My NX6010 #1,167
I wonder if one of the rear light bulbs got replaced with a single filament bulb, shorting the brake lights through the lighting circuit?
You know like an 1156 light bulb being used where an 1157 should be, I've seen it before on cars. Even though they are supposed to fit sometimes folks just seem to "jam" them in there.
Fred
/ My NX6010
Fred
Fred, as it turns out what you described is exactly what happened. Back in 2014 an oak branch popped the left rear taillight off. I had to remove the guts from the housing in order to drill two new bolt holes. The guts are symmetrical and somehow I got the 1156 and 1157 bulbs backward. After sending 18v through the system, I presumed that the problem was related and lacked motivation to chase down electric gremlins in a meadow.
The tractor was back in service for an hour and then this happened. I put in two hours of work after I made this video:
/ My NX6010 #1,171
Fred, as it turns out what you described is exactly what happened. Back in 2014 an oak branch popped the left rear taillight off. I had to remove the guts from the housing in order to drill two new bolt holes. The guts are symmetrical and somehow I got the 1156 and 1157 bulbs backward. After sending 18v through the system, I presumed that the problem was related and lacked motivation to chase down electric gremlins in a meadow. [snip]
Hats off to Fred on this one. :thumbsup: Well done!
Eric, clever work with the come-along and chain binder to straighten the hydro filter housing.
/ My NX6010
I was thankful I was able to get my tractor out of the area were it happened as I barely had any reverse pedal, and then to top it off, the tractor wanted to regenerate (which is odd since the dealer forced a regeneration one hour of engine time before--a�ll I can assume is that the tractor was idling at the attending dealer's shop never warming up and the DPF loaded up). Anyway, I got it out of the woods, got it on my trailer, let it run long enough to regenerate, shut it down, and that's about where I started making my video.
/ My NX6010
Back to making burn piles.
/ My NX6010
Eric, I enjoy your videos, you and I both know this was not one of your more intellectual vids. but I appreciate it, and got a good laugh :drink:
Thanks! That was the very first and last time I used the BXpanded pharanna toothbar (a sharp-edged toothbar made to cut brush on the ground) to take out saplings. Compared to doing it by hand it was awesome and my giddy laughter captured my glee with my new tractor!
/ My NX6010 #1,176
Kioti NX6�1� Land Clearing - YouTube
On that video, besides just being fun, you can get a good feel for the linked pedal function of his Kioti. He is just pushing on the forward and reverse hydrostat pedals, but if you will notice the tachometer, his engine speed is varying along with the forward and reverse motion. Unlike a typical hydrostat where you just set the engine speed with the hand throttle and leave it, with the "linked pedal" the tractor will vary it's own engine throttle as more or less hydro pedal is applied.
/ My NX6010
I'm speculating that Doosan and Daedong co-developed the engine management software or that Doosan developed the engine management while Daedong developed the engine. My conjecture is based on the Delphi diagnostic products where the same products work on both the Doosan and Daedong 1.8L product family. http://europe.delphi-dso.com/uk/downloads/DELPHI TEST EQUIPMENT.pdf
As well as the fact that Doosan just signed a new contract with Daedong to supply engines. Doosan Global : DI Signs Engine Supply Contract with Daedong Industrial, Korea's No. 1 Agricultural Machinery Manufacturer
Hard to tell with these industrial companies as they tend to pool resources together when it makes sense fort them to do so.
/ My NX6010 #1,178
Looks like Doosan will be providing not only engines for Daedong (Kioti) but Tong Yang Moolsan (TYM) and therefore Kukje (Branson) also.
Also these engines will not have DPF filters. That will be cool.
/ My NX6010 #1,179
Looks like Doosan will be providing not only engines for Daedong (Kioti) but Tong Yang Moolsan (TYM) and therefore Kukje (Branson) also. Also these engines will not have DPF filters. That will be cool.
These are all relatively big engines though (>3 liter) so unlikely to be for the CUT market.
/ My NX6010 #1,180
I haven't read through this entire thread (I'd need to take a week off work) but from what I have seen, I don't know whether to be encouraged or afraid of the durability and engineering of a Kioti NX series. Seems like every post I looked at was a discussion about a broken part or fixing a broken part:shocked:
Do all of the CUT's out there (JD, NH, Kub, ect) suffer from the same lack of protection to critical components?
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
8x8 Meyer X1206 Farm Wagon (A65579)
8x8 Meyer X1206...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
2011 18ft. Maxey Flatbed Utility Trailer (A64194)
2011 18ft. Maxey...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
