My NX6010
/ My NX6010 #1,181
Do all of the CUT's out there (JD, NH, Kub, ect) suffer from the same lack of protection to critical components?
I think those other manufacturers have blacklisted Eric, so we may never find out..... :D
/ My NX6010 #1,182
I haven't read through this entire thread (I'd need to take a week off work) but from what I have seen, I don't know whether to be encouraged or afraid of the durability and engineering of a Kioti NX series. Seems like every post I looked at was a discussion about a broken part or fixing a broken part:shocked: Do all of the CUT's out there (JD, NH, Kub, ect) suffer from the same lack of protection to critical components?
The NX is reliable. It isn't a bulldozer or combat vehicle however and like other CUTs is likely to suffer when used as such.
/ My NX6010
I've never used my NX as a bulldozer. Not even once.
At any-rate, I had to armor up the underside of my tractor in order to be able to use my rotary cutter in reverse without damaging anything from the underside.
Proper technique for rotary cutting is coming at brush in reverse in small bites so as to not expose the tractor's sides to branches and being wary of running over any uncut brush.
I cannot speak to the other OEMs other than I thought the Massey was built just a little more robust. Even so, the NX represented a better value and has the best control layout of all the cab-on models in the class. Control lay-out was a major factor for me as I have a really bad back and do do well leaning forward or twisting to reach controls.
/ My NX6010 #1,184
I can see you'd wonder that. :laughing: It's quite a thread, that's for sure! Well worth the read, though, IMO.
As I recall, Eric bought his NX after a lot of research to commercially develop some heavily-wooded lakefront property in Nevis. He's done a lot of clearing and cutting in of new access roads and drainage, most it single-handed as time allowed. Plus more routine work like snow removal and rotary cutting. As another NX owner, I like to follow the thread because it pushes the envelope on what can be done with a cabbed CUT, as well as some of his attachments and implements in some pretty demanding use.
/ My NX6010
Speaking of, the clapped-out dock is in. :thumbs:
And the property is getting pretty.
/ My NX6010 #1,186
We always took the brush head on with the 50's tractors, if you could drive over/push the tree/brush the cutter would finish the job. My favorite tractor for brush cutter was an old MF 85 but we cut plenty of brush with AC wd's. These tractors didn't have any wires underneath and lots of iron. The mowers usually have heavier iron at the leading edge.
/ My NX6010 #1,187
Looks like Doosan will be providing not only engines for Daedong (Kioti) but Tong Yang Moolsan (TYM) and therefore Kukje (Branson) also. Also these engines will not have DPF filters. That will be cool.
TYM has been buying Doosan engines for their 105 hp tier IV tractors all along. Branson does not have a 100 hp tractor.
/ My NX6010 #1,190
Something new arrived.
If you want those times to stay straight, be careful using it in land clearing. I've bent the crap out of mine accidentally snagging stumps and rocks. Even bent the frame.
I think rakes are great as finish tools to gently spread loam or gravel but keep it away from rough areas.
/ My NX6010 #1,191
Very nice. Should be especially good for clean-up and maintenance of the beachfront at the lake. :thumbsup:
It is amazing the work they can do. I agree with Island on being careful about what you snag. I've used a six-foot, lighter-tined model for years on my little B2150. Only around 2800 lbs with FEL and loaded tires, and I've bent tines. They can be straightened, and replaced if necessary, but they are spring steel.
Look forward to a video.
/ My NX6010 #1,192
We have been running a 7foot land pride non hydraulic model and it does a great job. Like most things, my wife likes to stress test the implements. So far so good.
/ My NX6010 #1,193
He's not gonna bend our frame!!
Well, this is Eric, so.......I hope he doesn't bend our frame. :laughing:
It would take some serious effort!
Travis
/ My NX6010 #1,194
He's not gonna bend our frame!! Well, this is Eric, so.......I hope he doesn't bend our frame. :laughing: It would take some serious effort! Travis
Mine is a Woods SR 72. I've since straightened and reinforced the beam. My rake looks like it needs an orthodontist though as the tines have been bent every which way.
Maybe Michigan soil is more forgiving than rocky New England.
/ My NX6010
I've noticed two new noises. The first noise sounds like a working bearing (like running a wet finger on an empty wine glass) when standing outside with the engine running at idle. I will check the belt tension on the new alternator, and if that doesn't reveal anything, I guess I'll need to get out my stethoscope and listen to everything.
The second noise is noticed inside the cab off of idle to 2,000 rpm. It sounds like an engine nock, but the engine isn't knocking. I'm at a loss to explain it.
Meanwhile, I cleaned up the area around the dock today and moved the piles of wood on the island over to a winter burn site.
/ My NX6010
I popped out to the new parcel today with maintenance on my mind.
If anything both belts were a little slack. I tightened both. There belt noise is from a failing idler pullie. 300 hours is like 50,000 mile on a car for reference. I still have no idea what the second noise inside the cab off of idle to 2,000 rpm is. As I said, it sounds like an engine nock, but the engine isn't knocking and I'm at a loss to explain it. Everything is working fine, yet the noise is something new.
Making piles of straw jacking timber is hard on the blind front end. After taking the following photo, I took note of all the front end part I need to replace to renew the front end of my tractor.
An OEM grill insert should be made available as a factory option so as to prevent this type damage.
24" BUCKET (A64277)
24" BUCKET (A64277)
Mini Skid Steer (A60352)
Mini Skid Steer...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2008 HEARTLAND RV CYCLONE 40 FOOT TOY HAULER (A59914)
2008 HEARTLAND RV...
