Making Nicer Torch Cuts ???
/ Making Nicer Torch Cuts ??? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
In the past when I make torch cuts I just hack it off and say well there that was easy. But now I would like to make some cleaner cuts like I have seen others do that will be in the root of a weld and places I can't get my grinder. Here are some of my hack cuts I made the other day in 1/2" plate. I would like to experiment to get them better but do not have a clue what to change. I have an old PUROX CW200 torch. Book says 6 psi Acetylene 30-40 psi Ox for 1/2" - I run 35. I have ground the top and bottom of these cuts but anything you can tell me would be good. Thanks
gg
/ Making Nicer Torch Cuts ??? #2
Looks to me like your tip is plugged. Acetylene is dirty, and every time I use my torch I run the tip cleaner through the center hole. Also, if the tip is worn down and angled, might be time for a new one. Sometimes you can file them back flat and extend the life a bit.
Steady hand and even speed is the secret to to good edge quality. There are some decent videos on youtube that will help.
/ Making Nicer Torch Cuts ??? #3
The machine shop down the road from me uses a cutting table with an acetylene torch that cuts beautiful square edges so i imagine its a practice thing.
/ Making Nicer Torch Cuts ??? #4
I've never really been that good with a torch. Over the years I have worked with guys who were amazing with a torch.
When adjusting the torch, you want a neutral flame. Then slowing press the oxygen lever. Find the spot where the cutting cone goes out from the tip the farthest. Remember that spot! Another big help is a magnetic burning square.
/ Making Nicer Torch Cuts ??? #5
When using my torch and I want a cleaner / straighter edge I clamp a piece of angle on my cut line then run the torch along the angle. Freehand cuts are never straight for me.
/ Making Nicer Torch Cuts ??? #6
X2...
Young fella I used to work with was d@mn good with a torch... we hired in about the same time, he was only 23 yo at the time, didnt last long, quit after a few months. I had been using torches longer than he had been alive, but he could freehand some of the nicest cuts I've seen, straight or curved. Good welder too...
I need a guide to cut anything nice.
/ Making Nicer Torch Cuts ??? #7
I could teach you in 30 mins what I couldn't explain in 10 days on this here interweb. Nothing replaces hands on teaching.
Thanks, I'll clean my tip and see what I can do with some guides.
gg
OK I will look for that sweet spot-thanks again. I do occasionally here a whistle but never paid attention to it.
/ Making Nicer Torch Cuts ??? #11
Every torch and tip has it's sweet spot. That's why I said slowly push the oxygen lever down, when the cutting cone goes out, and the flame sounds like a jet engine. You found the sweet spot for cutting.
/ Making Nicer Torch Cuts ??? #12
The cut is louder too when everything is perfect too. Make sure you have a nice long straight cutting jet like in Shield Arcs pictures. One thing that wasn't mentioned is what size tip you were using? It's also a good idea to run the torch over the plate to preheat it slightly. This also lets you make sure you're in a comfortable position to do the cut and the hose isn't going to get caught on anything. Sometimes I put the hose over my shoulder and have a short loop so it won't get caught. I'm pretty good with a torch but I forget to breath because I'm concentrating too much on the cut. On steel over 3/16" I prefer an Oxy torch over plasma.
/ Making Nicer Torch Cuts ??? #14
I like to make sure the blow out area on the back side of the cut is free and clear. Haveing something too close to the cut prevents a smooth flowing cut.
/ Making Nicer Torch Cuts ??? #18
I found my cuts improved when I learned how the torch actually worked. What holes do what.
But in general (and sadly) as with the plasma, I tend to make my best cuts when it doesn't matter, and am nervous and jerky when it does!
Bobcat T590 (A60462)
DSP 900 Balancer with Split Weight (A63118)
DSP 900 Balancer...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2016 DRAGON 150 BBL VACUUM TRAILER (INOPERABLE) (A63569)
2016 DRAGON 150...
Bobcat T650 Compact Track Loader (A64047)
Bobcat T650...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
