Harbor Freight Quick hitch
/ Harbor Freight Quick hitch #21
I thought my old AC 160 was American too, seen 'em/drove 'em since I was 13 - til I started tryin' to get parts together for mine to add more remotes - found out maybe English, probably French - considering those two countries haven't liked each other since the dawn of time, it's no wonder I STILL haven't found out what one of the connections is :confused:
Back on topic, I have HF's quick hitches on both the AC and the Long, no problems yet, and a couple of the implements I've used on 'em weigh over 1000 pounds - in fact, I bought 2 more when they were cheap, one's gonna get a mount fabbed so it can take the place of the hoe bucket on the 580, and the other will get extensions to mate with the QA I'm fabbing for the FEL on the 580... Steve
Do a quick search through the forums, you'll find lots of threads about it, as well as the modifications you will probably need to do to get it work to work correctly with your implements.
As I said I was looking for specific info on a JD 2520 they have always had the rear clearance issues between the tires and the 3 point and was hoping someone had specific information on using the quick hitch.
/ Harbor Freight Quick hitch #23
Is the 2520 tighter than the 2320? I've never had an issue with the QH on mine.
Not sure about the 2320. I have a 2006 2520 that I got with 29 hrs on it and it has about a 1" of clearance on the 3 point and rear tires at full height.
JD made (makes) a replacement 3 pt arm set to correct the issue that came out in 2007-8(?) that corrects the issue and was looking to see specifically if the quick latch works with that tractor.
Here is a picture of the 2520 with the replacement arms that John Deere uses below it are the original arms they replaced. 1510.jpg
/ Harbor Freight Quick hitch #26
I do have a Ventrac made in Orrville Ohio, and a Massey Ferguson made in somewhere USA
Ventracs look to be very cool, but not inexpensive- worth it if you need one though.
This post also prompted me to go take a closer look at your M-F tractor...
Very Interesting:
Massey-Ferguson were at first and until the 1990's continued to be IMPORTED into the US of A.
From Wiki: Massey Ferguson - Wikipedia, the free encyclopedia
The firm was founded in 1847 in Newcastle, Ontario by Daniel Massey as the Newcastle Foundry and Machine Manufactory-
They became an American corp as follows: In 1992, a management buyout of MF Industrial created the company Fermec, which finally ceased trading in 2001 when it was taken over by the Terex Corporation (Terex was formerly a unit of General Motors). This encompassed all construction equipment from Massey. It was then purchased by J. I. Case Company in 1997.[15]
Varity left Toronto and relocated to their head offices to the Williams-Butler House at 672 Delaware Avenue in the Millionaire Row area of Buffalo, New York.
Despite some of the company's hardships, Massey Ferguson was selling 25% more tractors than its nearest competitors at this time. In 1995 Massey Ferguson's worldwide holdings were purchased by the US-based AGCO Corporation. In August 1996, Varity merged with Lucas Automotive to become LucasVarity.
After a series of mergers and take-overs, the remains of LucasVarity were taken over by the US company TRW. Since 1962, Massey Ferguson has been the world's leading tractor brand.
Most interesting:
Currently, there are more Massey Ferguson tractors than any other, worldwide.
In June 2012, the Agco facility in Jackson, Minnesota, was expanded to start building Massey Ferguson and comparable AGCO "Challenger" models for the North American market.[SUP][16][/SUP]
Since production commenced at AGCO Jackson, the facility has produced "7600" series and "8600" series Massey Ferguson tractors for the North American market. Currently in production at the Jackson facility are the recently released 7700 and 8700 series Massey Ferguson tractors.
Thanks for sharing,
Thomas
Back to main thread topic:
Hi JRobyn,
Well, Is your new QH mounted and in use yet, or are you still awaiting delivery?
Freight can take so long, can't it...
Good luck!
Thomas
/ Harbor Freight Quick hitch #27
So where was mine made?
Ventracs look to be very cool, but not inexpensive- worth it if you need one though."
Nothing good is cheap.I liked the easy way to change attachments.
/ Harbor Freight Quick hitch #28
Technically, you asked generally if anyone was using it for implements, then mentioned that YOU wanted it for your specific JD model with several implements...
"Anyone using a Harbor Freight quick hitch on implements? Looking to use it on a JD-2520 for a bush hog,blade and rake .3-Point Quick Hitch for Tractors - 27-3/16" Clearance"
Just saying- but NOW of course you HAVE specifically asked that question.
Thomas
Thomas
What-ever,
The first post I said what I was using it on and for info on it's application with the 2520.
I got a generic "search the forum" answer from another member.
/ Harbor Freight Quick hitch #30
Thomas
Thanks. Was going to point that out, but didn't want to start an argument. Figured I'd let it drop.
As it is known the 2520 has issues with clearance on the rear arms and was asking if the 3 point from HF had any issues with it.
/ Harbor Freight Quick hitch #32
Mine shipped today. Specs say the spacing is 27-1/4". That matches my Bushhog 286 exactly, but looks like Ill need to space out the pins a little on my box blade. It's about 26-1/2.
/ Harbor Freight Quick hitch #33
Well, the hitch arrived. Bad news - NOT a Speeco. It's made in China by "Country Way". Good news is it seems to be made pretty well, although the lower pin retainer dogs are a little lightweight-looking.
Maybe it's the difference between SKU 14116 and the 14116000 I bought? I've complained to RK. We'll see what they have to say.
/ Harbor Freight Quick hitch #34
As I said, if you check the Q/A on the site, they specifically stated that it is a Speeco QH.
/ Harbor Freight Quick hitch #35
We have a 8320R and a 8335R both made in Waterloo Iowa. They're still made in the USA tractors just not what most people on here are in the market for.
/ Harbor Freight Quick hitch #36
I saw that Phys. And pointed that out in my feedback to RK. As I told them, I feel deceived. I expect they will tell me something like that "our "Country Way" hitch is made in the same factory to the same specs as the Speeco".
/ Harbor Freight Quick hitch #37
You're prolly right, but I wouldn't be inclined to acceptance of that excuse, either.
Good luck!
/ Harbor Freight Quick hitch #38
I picked up a genuine Speeco on CL last week for $100. They are out there. However, so far it doesn't fit any of my implements. Do most need to be modified to accept the quick hitch?
/ Harbor Freight Quick hitch #39
Most newish implements should be quick hitch compatible. Older stuff often needs to be modified.
/ Harbor Freight Quick hitch #40
I haven't done a lot of research on the speeco but there is a possibility that the hitch is the issue and not the implements. I think the only hitch I've read that doesn't need modified is the landpride and deer.
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
2017 Bobcat T770 Compact Track Loader (A63118)
2017 Bobcat T770...
2019 Kenworth T270 Flat Bed Dump Truck, VIN # 2NKHHM6X3KM358768 (A61165)
2019 Kenworth T270...
