Excavator control patterns
/ Excavator control patterns #1
sreeb
Member
San Diego, CA
Cub Cadet 7305 Bobcat ct2025
I just suffered a brief bout ebay madness and now find myself owning a mini excavator. I have basicly no experience running one.
The controls can be set to either "ISO" or "JCB". Is there advantage to one either in ease of use or popularity if I someday want to rent a bigger one?
Ed
/ Excavator control patterns #2
What did you buy, Ed? Did you buy sight-unseen and it is being
shipped? How has that worked out? I have sold equipment on eBay
over the years, but I recently made my first sight-unseen vehicle
purchase---a car I had shipped from St Louis.
As for the control standards, I am sure you will get used to whatever
you spend time with....I did not know JCB was different from ISO, the
"international standard". And is Caterpiller different from either?
/ Excavator control patterns #3
It is totally which your prefer.
/ Excavator control patterns #4
I would suggest you learn with the ISO controls . I did it the other way around as the first ex. i bought was different to ISO . When i bought my new ex. it was ISO , i had to UNLEARN and then relearn . It was harder than giving up smoking , when the truck driver delivered the new machine he asked me to unload it off of the trailer . I told him to stay clear so i didn't kill him , he must have thought i was Epileptic the way i was operating it . :D
Takeuchi TB016, 2003, 1750 hrs. Ex united rentals. I did buy it sight unseen but the listing had lots of pictures, a video, a detailed condition report, good feedback and a guaranty that I could return it if not as claimed. It only weighs 3300 lbs so I was able to rent a trailer and drive the 100 miles to retrieve it. It seems pretty much OK. No leaks, controls are real smooth. The only obvious slop is in the bucket quick attach and I suspect that may be mostly an undersized retaining pin.
ISO:
boom is on right joy stick v^
arm is on left joy stick v^
JCB:
boom is on left joy stick v^
arm is on right joy stick v^
Both:
cab slew is on left <>
bucket is on right <>
/ Excavator control patterns #8
ISO seems more natural to me or maybe it's just because it's the more common setup ?
/ Excavator control patterns #10
Ed;
The TB016 has a pattern switch control that allows you to pick the pattern you want. I have a TB015 and the owner's manual says the same thing exists for it. My only problem is that the manual doesn't describe where the switch is! I just learned the existing pattern which was set for SAE. I practiced in an open field for the first 1/2 hour to get it down. Now it doesn't feel like rubbing your belly and patting your head syndrome anymore. Have fun.
SimS
/ Excavator control patterns #11
Ed
Ed I have run equipment for years and one of the most aggravating things is having to change machines on a jobsite with different control patterns. Most excavators (tracks or wheeled) operate ISO, crowd(or stick) and swing on left and boom and bucket curl on right. I refer to the other pattern as backhoe controls, only difference being the crowd and the boom are opposite. I would suggest if you want to run bigger machines would stick with the ISO, but a lot of machines today are easy to switch. My personal mini does not change patterns but when I get off it and on my backhoe it doesn't take but 10 minutes or so and I am back accustomed to it. Hoped this helped.
/ Excavator control patterns #12
golfguy - that's a zombie thread. sreeb was last here in 2014.
2004 JOHN DEERE 750C LT SERIES 11 CRAWLER DOZER (A65053)
2004 JOHN DEERE...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2015 Honda Accord Sedan (A64557)
2015 Honda Accord...
2011 Tri Axle Frac Blender Trailer (A64194)
2011 Tri Axle Frac...
2007 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2007 Nissan...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
