Skidding Winches
/ Skidding Winches #121
What kind of Winches do you all have?
I've got a Farmi 351 with legs instead of a blade. Paid $900 for it after I found it mislabeled in a Craigslist post. rps20160311_202113_947.jpg
/ Skidding Winches #123
My Fransgard V3000
/ Skidding Winches #124
And my Sandvik/Norse 3081
/ Skidding Winches #126
Wallenstein FX90 here...
It's a good winch, I've skidded lot's of big sticks with it,
SR
/ Skidding Winches #129
Fransgard has really changed their design, mine doesn't look nothing like that, has no feet so I don't have to worry about it running away. How far back in the last century is that?
Awww jeez, mine's got feet too, and I never even considered it running away. Now I've got something else to worry about!
/ Skidding Winches #130
Tornado got them...and there were quite a few, down in that ravine... They are red oaks, and I cut two 17 footers and a 8' - 6" out of many of them!
Then I pulled the tops out and fire wooded them...
SR
/ Skidding Winches #131
I bet they "hobble" them, when they take them off their tractor! lol
SR
/ Skidding Winches #132
Not sure but early 80s maybee, the feet is a very good solution on a small tractor, it it had a blade I loose almost all ground clearance.
/ Skidding Winches #133
I have a Norse 350 -- new last fall. A god fit for my 40 HP CUT.
/ Skidding Winches #134
You have å hinged blade on yours
/ Skidding Winches #135
Hydraulic, a bit slower than pto operated but I am not in a race. I really enjoy the wireless remote being alone.
/ Skidding Winches #136
You might have the oldest working pto tractor winch. More ground clearance is always good, I have 16" and wouldn't want a inch less.
/ Skidding Winches #137
Should be all set if you have it well trained from being used often, but if you leave it in grown up field for too long, might run off then.
/ Skidding Winches #138
Mine old? This is old
/ Skidding Winches #139
An quite common older design
/ Skidding Winches #140
On this you see the very simple construction on the winch with the rubber wheel. Its a factory design.
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
John Deere 400 Rotary Hoe (A66408)
John Deere 400...
Bucket (A64194)
Bucket (A64194)
New/Unused 20 Ton Hydraulic Jack (A65583)
New/Unused 20 Ton...
2009 Wilson Hopper Bottom Trailer (A66285)
2009 Wilson Hopper...
