Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,641
Thanks for the input on the ground speed with a flail vs. a rotary cut. I'm just trying to get my ducks in a row and hopefully one of them will lay a golden egg. :)
/ Let's talk flail mowers #2,642
Just purchased used John Deere flail, about 7 foot wide and offset. It has the duck foot blades. Serial number is 436546. Any idea what model?
/ Let's talk flail mowers #2,643
Will try a picture. Looks very much like the red one on Ebay. It is not rusted through anywhere though. He says he uses it to mow 1"-2" brush.
How old is this mower? Where do I find info. on it? Any idea of value? Are parts available? He mentioned he reworked or replaced the pulley when he got it, also replaced the belt. Thanks.
http://images.craigslist.org/00t0t_3LRtvLOXHXD_600x450.jpg
/ Let's talk flail mowers #2,644
Try again. My eyes aren't that good!!
/ Let's talk flail mowers #2,645
/ Let's talk flail mowers #2,646
They are too small. Here they are copied directly from the Ad:
It is the same model as the one on eBay.
Looks good, go for it! :thumbsup:
/ Let's talk flail mowers #2,647
Will do Jack, Without getting notifications any more, I missed this request. Later today when I wake up properly....
Edit
Nipped out and had a look. Yes, It is a JCTT. If you want a photo I will do that later.
I have done quite a bit more with it already and love the way it shreds lantana etc. It really does a great job.
good, it is the best Chinese gear box which we can find.
/ Let's talk flail mowers #2,648
It is a very nicely molded box and has several mounting points on it to choose from. There is no sign of any oil seepage at all like I see mentioned from other types of g'box. Very happy with it.
/ Let's talk flail mowers #2,649
Yes, this gear box is good, according to my record, the defect rate is less than 2/1000. I notice there are some Chinese factory started to use cheap gear box to reduce cost.
Anyway, for personal customer's application, JCTT is good enough, but not good for commercial customer.
Alien, enjoy your mower. You can also talk with me if you meet problem with your mower.
/ Let's talk flail mowers #2,651
/ Let's talk flail mowers #2,652
View attachment 456746View attachment 456745View attachment 456747
The is my second flail mower. My first is a Vemvo 6 ft wide that I have had to do extensive repair to. Thats why i purchased this one. After cleaning off some of the dirt I did find a large 25 on the back side as two stickers.
Hello CTWright,
If I have not done it already; I want to welcome you as the newest member of the Flail Mower Nations"
Yyou can order replacement manuals for your flail mower from John Deere or your local dealer.
YOU are the proud owner of a JD 25A flail mower with 36 scoop knives which will give you a good over all cut in all conditions.
Your flail mower rotor can be equipped with the 36 pairs of side slicer knives if my memory is correct-my fathers 25A had 72 side slicers.
check for broken D rings and damaged scoop knives, Change the drive belt, change the oil in the gear box scrape and wash of all the rubber dust and grease out from under the V belt guard and be sure to grease the other fittings under the V belt guard.
Pump no more than six squirts of grease in the flail mower rotor bearing and 4 squirts in the rear roller bearings before you mow for 8 hours each time and have fun with your new to you toy.
/ Let's talk flail mowers #2,653
Any idea how old this is based on the serial #?
436546
/ Let's talk flail mowers #2,654
436546
Check with a local Deere Dealer and they will be able to tell you.
Your new to you flail mower is not that old that you cannot purchase parts for it.
If its like so many other manufacturers they simply mark each unit as
its built either as inventory or by order.
/ Let's talk flail mowers #2,655
I'm looking at getting a flail mower. I've found a couple of used Alamo 74" Super Heavy Duty mowers.
I'm concerned about HP requirement.
I talked to a dealer about buying new, he stated I'd need at least 35HP PTO.
I looked at Alamo's website, 25-50hp PTO, that's kinda vague.
Alamo's Literature states for the 74" mower 35 Tractor HP Min, 43 Tractor HP Recommended.
Alamo's owner manual says 35 Tractor HP for the 74" mower.
According to Alamo I'm good to go, Ive got a 43 HP tractor that has a 33 HP PTO.
I plan on using it to cut a field that is over grown with Goldenrod a couple a times this summer. Then planting it with native grasses and forbs in the spring of 2017 and mowing with the mower raised to 6" to keep the weeds at bay till the plantings get a hold.
So I think a 74" mower should work for me. But the dealer made me nervous. I know that the 62" mower is OK but I have found some used 74" that are alot less than new. So I'd like to go with the 74". What says the wizards of Flail?
/ Let's talk flail mowers #2,656
I have a 75" Caroni. It cuts just fine with a 41hp gross and low 30's PTO tractor. With any mower the power required depends on how thick the grass/brush is. In springtime with lush grass and first cut I need to slow down. In the summer and fall I can pretty much cut at whatever speed I'm willing to drive. I wouldn't worry at all about a 74" mower on a 43hp tractor.
/ Let's talk flail mowers #2,657
Hello Weedy Fields. Second what Islan Tractor said. Also, the SHD74 is what I have and have no problems with mid 30's PTO HP. Curious as to which model you are looking at, the fine cut or coarse cut? Mine is the fine cut with 92 pairs of knives and I have cut some pretty tall and thick weeds with no problem.
/ Let's talk flail mowers #2,658
Although I got delivery of my new flail a couple weeks ago, I just got it assembled:
Hydraulic Offset 78" FlailMower EFGCH+195 HD
Tomorrow I'll get some gear oil, grease it and probably a new top link.
In the AM I have a buyer coming for my old flail. Thinking a good use of the funds will be a 2nd function switch.
/ Let's talk flail mowers #2,659
Thanks for the replies.
Hoochy, Some of both. I'm looking to get a fine cut one. I'd like to chop the grass/stems as fine as possible so they rot away as quick as possible.
/ Let's talk flail mowers #2,660
Thanks for the replies. Hoochy, Some of both. I'm looking to get a fine cut one. I'd like to chop the grass/stems as fine as possible so they rot away as quick as possible.
To chop as fine as possible just travel slowly with a rough cut mower.
2012 WESTERNSTAR 4900FA (INOPERABLE) (A65643)
2012 WESTERNSTAR...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2016 JCB 507-42 (A64126)
2016 JCB 507-42...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
Kobelco SK135SRLC-1E, Cab, Heat/Air, Manual Thumb8 (A62679)
Kobelco...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
