When is a Grapple a Tree Shear?
/ When is a Grapple a Tree Shear?
/ When is a Grapple a Tree Shear? #42
If you could only have one attachment what would it be?
Well that's a hard choice, but since there are still so many cedar trees here, it would be this one:
/ When is a Grapple a Tree Shear? #44
I'd pick my grapple. Then I would give the other implements to my Grandpa. Then I could still use them on his smaller tractor.
/ When is a Grapple a Tree Shear? #45
While I would agree a tree puller is valuable. It might come in a close third to a Grapple.
For me, I'd be aggravated at that type of Tree Puller all the time. Way too hard to get ahold of an object. A jaw type is easier to load and can carry multiple small trees with ease.
/ When is a Grapple a Tree Shear? #46
While I would agree a tree puller is valuable. It might come in a close third to a Grapple. For me, I'd be aggravated at that type of Tree Puller all the time. Way too hard to get ahold of an object. A jaw type is easier to load and can carry multiple small trees with ease.
It would be fine on a skid steer, but I see how that would be troublesome on a tractor.
/ When is a Grapple a Tree Shear? #47
Even on a SS, you gotta swing past the tree and then swing into it. V design is so much easier to use. And allows collecting more than one small tree before dumping on the pile.
I agree if it was on a tractor, but on the Versahandler, with 4 wheel steering and being able to see the jaws from the seat, it is easy to clamp on.
Just drive forward, turn right when the front jaw is at the trunk and clamp.
And pull.
/ When is a Grapple a Tree Shear? #49
I'd put tractor brake steering against the 4 wheel steering,
/ When is a Grapple a Tree Shear? #50
Doesn't matter what you hitch it to. It's not as easy to use as a jaw type. What exactly are the advantages of that type puller?
One advantage is being able to reach in between the oak trees and pull cedars.
Note the small oak tree trunk just to the right of the just pulled cedar tree roots.
The main advantage for me, is being able to see the jaws from the seat.
/ When is a Grapple a Tree Shear? #53
Why do you have it out for the cedars?
They grow like weeds and will completely cover the land.
Guess you have never seen news coverage of wild fires in this area, they explode like a bomb.
Used the Long Arm Tree Puller to pull all the cedars visible in the picture above.
Picked them up with the Monster Grapple
Added to the burn pile.
/ When is a Grapple a Tree Shear? #55
It came down to 2 choices when I got mine and I choose the Jaws or scissor type like an alligator mouth. If I choose the one you have (Which was my 2nd choice) I thought about adding a couple things to make it more useful for me. The pieces as shown in yellow wouldn't have to be but maybe 5" long so it shouldn't interfere when pulling but would help a lot if you needed to pick up a small log or maybe a pole
/ When is a Grapple a Tree Shear? #56
Here's the one I choose. I can tilt down and pick up a pole but have to carry it long ways with the skid steer. That's ok if you have to move something in tight quarters.
I considered that style, but the jaws would be out of sight from the seat.
This was what I was going to get if he would make one with the cylinder on the right, jaws on the left:
Then I saw his Long Arm: Buckthorn Puller - Custom built Skid Steer attachments to fit almost any need you may have.
Thanks, good idea. :thumbsup:
/ When is a Grapple a Tree Shear? #58
Jeez , you guys are really racking X FAX . Obviously an intelligent and working person . What gives , ya jealous ?
/ When is a Grapple a Tree Shear? #59
Nahhhh. He's a big boy an can take it.
He just always claims his "stuff" is best. Just pointing out it's not always. :)
Yep, I just consider the source, it is from guys that have never operated my equipment and are making assumptions based on their experience using tractors and skid steers.
I don't recall ever claiming that my machine is the best, but I can understand how you could get that feeling from looking at the pictures of what it can do. :)
Unverferth HT25 Header Trailer (A66285)
Unverferth HT25...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
Skeleton Backing Plate (A62679)
Skeleton Backing...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A65643)
2012 SOUTHERN 130...
