Overhead Garage Door
/ Overhead Garage Door #1
7mmrum
Berryville, VA
Anyone know any companies that provide overhead garage door kits. I'm trying to find a company that if I provide the measurements of the opening that they can provide all the hardware for the garage door. Opening is approx 15x15, and I'm thinking of an overhead door due to simplicity. I has hopening to find something where the garage door is in panel sections that is then bolted together during assembly.
Looking for something no frills of design and asthetics.
/ Overhead Garage Door #2
i bought a door for mine like the ones on the storage units,a 10 x8 was 230.00try your local door company thats where i got mine
/ Overhead Garage Door #3
Try this company: Overhead Door Dealer Locator
I have their doors in my shop and really like them. They are more expensive than "barrel" or roll-up doors, but you don't have the issues with the barrel not wanting to unroll and come down. I think I posted a link for you local dealer.
Chris
/ Overhead Garage Door #4
I purchased a couple clopay's a couple of years ago from these guys:
Roll-up Garage Doors & Metal Garage Kits Available Online
No problems, at that time I was able to get more door for my $ than trying order from HD or Lowes. I ordered the EZ-Set tensioning system on the doors.
I have also found the local garage door guys to be competitive as well, especially if you purchase the garage door opener and installation as a package deal. The guy I used, had several options from builders grade (good enough for a barn) to high end. When you figure they can install two doors in a couple hours without having to make the 3 trips for more pieces of angle iron etc. that I end up making.
Edit: The local guy came out and checked measurements before ordering the doors as they could come in custom sizes for roughly the same amount of money.
/ Overhead Garage Door #5
Is this Overhead Garage Door thread to old to ask a Overhead Garage Door question? Or should I start another >Overhead Garage Door< thread to get some input on a Overhead Garage Door >problem< that I have with my Overhead Garage Door, again? I cant wait to here from the >OTP> Old Thread Police.:eek:
/ Overhead Garage Door #6
I'd say bring it...It's only a 4 post thread...never understood the OTP...As long as the question is in context and not an old 500 post thread, who cares?
/ Overhead Garage Door #7
So, what's the question?:confused3:
/ Overhead Garage Door #8
Yeah, we need to know what the question is before we can give the clearance to post. :)
/ Overhead Garage Door #9
LOL:laughing: first the Overture, I have a 3 yr. old 12'x12' with a 8500 Liftmaster opener, guess they call that a Jack-shaft style, one problem or another every year IMO due to bad installation by the door Co. that gave a tail light guarantee.
Wake up time for the movie. What I did> Last week the door started binding when it got almost down then reversed because one cable spool slipped a little, I pulled the door down, unwound BOTH springs, got the door nice and level, put tension back on BOTH cable spools and really tighten down the bolts on the spools, re-wound both springs, tighten those bolts down good. Door goes up&down good, stays halfway.
Problem> With the door up, opener engaged, then push the opener button, the door starts to come down about 6", then the cable slacken's taken tension off the >Cable Tension Monitor< then the door reverses back up. Now the ten dollar Question, where is the cable slack coming from when the door starts to come down around the corner? When I pull the door down by hand, after the first 6-10 inches, the cable stays tight rest of the way down holding the full weight of the door.
Solution A> get free input from TBN) (Solution B> By pass the Cable Tension Monitor,) (Solution C> Get another door Co. to come fix it $3-$400.00,)
(Solution D>Elect Donald Trump, get a door Co. to fix it, and make Mexico pay for it.:thumbsup: Did I get the clearance to post?:laughing:
/ Overhead Garage Door #10
Can you post a picture of the cable tension monitor mounting location? I have that same operator and have had 0 issues (installed the door and operator myself)
Perhaps the monitor is mounted wrong
Jay
/ Overhead Garage Door #11
I have worked on a bunch of different roll up doors and while they are different the problems are usually similar.
I worked on warehouse, dock, semi trailer to name a few.
It sounds like it is binding as it starts down then when it gets past a point it shifts and is OK.
Check it when it acts up to see if it tries to shift sideways or when raising does it shift.
Some times it's barely noticeable so try it a few times and watch closely.
/ Overhead Garage Door #12
Is the door raised up /open too much? If so, the low tension point has been overtraveled.
/ Overhead Garage Door #13
Jack shaft openers don't really close the door by my understanding, they just release tension on the cable and let gravity bring it down. So you probably need to back off your springs a bit so the door is biased to close on it's own. If you think about it, it does make perfect sense - you are unwinding the cable reel, essentially. That generates no downforce, unlike a typical rail style which actually pulls or pushes the door both ways. So loosen both springs a half turn, try again, wash rinse repeat.
And why did you re-open this Zombie thread? :D
/ Overhead Garage Door #14
Another issue could be the rails are too level. Need at little downhill so as the jackshaft spins, gravity does its thing.
Dstig is spot on the description. A little binding, springs too tight, or track too level are most likely causes.
I would not bypass the sensor. If the door truly does hang up, you will have an unwound mess of cable, and a heavy door that could come down at any time. And them doors are really heavy without the assist of the springs
/ Overhead Garage Door #15
I have 2 of those openers. If the door catches just a little, it can mess up the cables. Been there done that. Raise the back end of the track a little, which I need to do also.
/ Overhead Garage Door #16
Gravity is your friend. When a door is sprung from the factory it is designed for a person to be able to open it. This will normally call for 10 -20 lbs. of lift force. Jack shaft operators did not have the safety built into them for years. Installers were smart enough to set and install the doors correctly. Take a half round out of your spring or better yet give the back of the track a small lift. You want your cables to always be tight so they wind and unwind without ever having slack to jump the grooves on the drums. The opener you have will last for years.
/ Overhead Garage Door #17
Jay
Re-positioning the C monitor is the first thing I tried, I dropped it 6", no difference so I put it back up close to the C spool. I'll mess with it some more this weekend.
Picture's would help, but my Photo Bucket has been disconnected and I cant figure that out either, and that's whole other ball of BLANK, have to wait for daughter to show up.
/ Overhead Garage Door #18
I have a pair of them and the doors just don't have enough weight on the spring when fully open to come down fast enough compared to the door opener. The doors are steel insulated and really don't weigh much. I put doors in that would allow as tall of a vehicle into the garage as possible. Had I not done this I could have put more of a slope on the horizontal tracks to help put more weight on the torsion spring to help the door start to close quicker. My solution was to put a hunk of steel on the bottom of each door. Actually I put a 2" x 1/2" steel bar about an inch up across the bottom of each door. I have two doors, one 12' and one 9' so I split a 20' length (8 1/2' and 11 1/2'). After doing this they both work a lot better.
/ Overhead Garage Door #19
Lot of good input here, possible door binding up top, not enough track incline>decline, spring tension to tight or not tight enough?
Door has been installed 3 year's now, it was working fine until the cable spool slipped a little, made the door un-level...... I never adjusted the track, yet.
The door dont seem to bind at the top, seems to pull down by hand easy but will recheck it tomorrow.
I thought maybe wrong spring tension might be the problem, but my son said that has nothing to do with causing slack in the cable, one thing I do is that I don't know. If anyone see's a hammer flying through the air tomorrow, you'll know why.
/ Overhead Garage Door #20
You should take care of the basics first. If you've never dealt with torsion springs then you really should hire it out. They can be very dangerous. The torsion spring and the hub the cable winds up on play a very crucial role. When set up properly (without a door opener) the door should feel almost weightless no matter if open, closed, or in between. My smaller door only has one spring while my larger door has two. Hopefully you only have one spring, having two adds an extra level of complexity. Chances are one of the hubs slipped. If you would like to repair it yourself I've done both of mine several times.
2017 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Wagon Wheel End Table (A65583)
Wagon Wheel End...
2018 P.J. Trailer Trailer, VIN # 4P5F82023J1283348 (A65563)
2018 P.J. Trailer...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
