What is the Easiest way to move 330 yards of pit run gravel?
/ What is the Easiest way to move 330 yards of pit run gravel? #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Came across this thread on another forum...
What is the Easiest way to move 330 yards of pit run gravel? Well, its easier than you think, especially when a tight area is the destination.
A B2620, a Polaris Sportsman 500HO and a Polaris trailer, some time and you are all set.
Enjoy. :)
/ What is the Easiest way to move 330 yards of pit run gravel? #2
Pit run must be what we call crusher run. Names change from place to place.
/ What is the Easiest way to move 330 yards of pit run gravel? #3
I moved 300 with my little BX23 one summer...
Just as soon as I had cleared 20 yards at a little more than a 1/4 yard at a time the next showed up...
Hey... it beat using a wheelbarrow!
Looking good!
/ What is the Easiest way to move 330 yards of pit run gravel? #4
I will raise you an RTV with a dump bed.
Around here Pit Run is straight rock from the pit that is blasted and fractured or some places ripped with a cat and not run through a crusher.
David
/ What is the Easiest way to move 330 yards of pit run gravel? #5
Unless I messed up the math, 330 cubic yards works out to 445 tons or over 20 loads at 20 tons each. That would be a lot of material to handle.
/ What is the Easiest way to move 330 yards of pit run gravel? #6
I'm guessing he's retired
/ What is the Easiest way to move 330 yards of pit run gravel? #7
No, I wish I was retired. Just play on the weekends. Used this to haul it all home. Legal for 42 tonnes.
You found my pics eh Will? Thanks for posting. I like to show that you don't need a big tractor to get stuff done.
/ What is the Easiest way to move 330 yards of pit run gravel? #8
Here's a few pics during the road work. The little B pulls a loaded 60" box blade up the hills no problem and medium range.
/ What is the Easiest way to move 330 yards of pit run gravel? #9
David
I would love to have an RTV with hydraulic dump. I was going to buy a Weber Lane Super Tilt hydraulic dump trailer and run it off the rear remote on my Kubota, but now I'm thinking about a tandem axle MUT's so I can pull and dump with my Polaris.
Up here we are legal to gross 63,500kg/140,000 pounds. It does not take too long. See Star pic above.
/ What is the Easiest way to move 330 yards of pit run gravel? #11
When we went out west I saw plenty of dump trucks pulling dump trailers, but I have never seen a single one here in TN.
/ What is the Easiest way to move 330 yards of pit run gravel? #12
They need more room to turn, and TN is a smaller state.
Bruce
/ What is the Easiest way to move 330 yards of pit run gravel? #13
They need more room to turn, and TN is a smaller state. :) Bruce
I think pulling it and more importantly stopping it on our less than flat ground is the bigger problem. It could be more strict regulations on weight.
/ What is the Easiest way to move 330 yards of pit run gravel? #14
Can do a lot with little tractors.
Scooping and spreading out gravel is a cake walk compared to digging, clearing, and scraping hard dirt.
I have found that it takes about an hour to spread a dumped pile of gravel, provided you dont have to travel too far. IE: if speading it 2-3" thick one load, working out from the pile, you dont have to go too far. And get a good idea of, say, covering 100' each side of the pile. By the time the next load shows up, you have him dump 100' beyone where you left off if possible.
I get 25 tons dumped at a time. Or about 34-35 yards.
With a smaller tractor, the #1's and #2's I use for base, (softball sized chunks of limestone), are slightly more difficult to scoop and spread. But the small stuff is like scooping sand:thumbsup:
/ What is the Easiest way to move 330 yards of pit run gravel? #15
What is the B's bucket volume? 1/2 yard?
660 trips? Time.
/ What is the Easiest way to move 330 yards of pit run gravel? #16
Pronanbly 1/3 yd at best. That's about what I can do with a heaping load in my 5' bucket on my L.
/ What is the Easiest way to move 330 yards of pit run gravel? #17
4570Man, I hear you on not flat. The Trans Canada Highway from my place north to Thunder Bay is continuous 6 to 12% hills. It's like a roller coaster. It's not nice on the fuel bill.
I can't remember how long it all took me. I dumped by my shed in my turn around area. Then surfaced the first hill in my back yard. That took a bunch. Then I would spend 6 hours or so hauling a bunch up to the next level. Then build more road. Then haul a bunch again to one landing and keep transferring it up further. It was really hot here this summer, so most of it was done from 5 or 6 pm and I'd work until 1am or so when it was cool just to be easier on the tractor.
That's how I relax. I like to play with the tractor. Helps me forget how horrible the trucking industry has become.
/ What is the Easiest way to move 330 yards of pit run gravel? #18
What is the B's bucket volume? 1/2 yard? 660 trips? Time.
No way. My LA724 loader might move 1/2 yard at a time. It might do a little better with a big heaping load. The L3800 which has a LA524 loader can't make a full height lift using the LA724 bucket full of dirt. Edit Kubota says my bucket holds 13 cubic feet and the BX25 holds 4.9 cubic feet.
/ What is the Easiest way to move 330 yards of pit run gravel? #19
Ya, it's nowhere near a half yard. I can't remember how many cubic feet it says, but it's only 51" wide.
/ What is the Easiest way to move 330 yards of pit run gravel? #20
Typically 7 Cu Ft on a 54" bucket so maybe 6-7 on the 51" or 1/4 yard.
BUNDLE OF 3'X30' SHEET METAL (A60432)
BUNDLE OF 3'X30'...
(1) KENMORE WASHING MACHINE (A60432)
(1) KENMORE...
2016 FORD FUSION SS (4) DOOR (A60430)
2016 FORD FUSION...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
